Nolaan
GUI to find raspberry IP address
Tue Jun 16, 2015 1:09 am
I've made a Graphical User Interface here => https://github.com/Nolaan/pyIpFinder in qt4. I couldnt find such a tool for a project I'm currently working on so I decided to write it, and share it with the community.
This tool will help you find ALL Pis on the network of your computer, and display it in a window. You may be root to execute it.
Let me know if you have any question of issue with the program
Thanks ;)
Prerequesite : install pyqt4 and nmap
http://www.jetsonblog.com
twitter : @nolaan_boy
Re: GUI to find raspberry IP address
Tue Jun 16, 2015 7:57 am
It doesn't work on my network. Doesn't find the four raspberry pis that are wired.
This shell script does a better job
#!/bin/bash
IP=$(ipcalc `hostname -I` | awk '/Network/{print $2}')
MAC=$(sudo nmap -n -sP $IP | awk '/Nmap/ {if (x) {if (x ~ /B8:27/) {split(x, m); print m[5] " " m[13];} x="";}} {x=(!x)?$0:x" "$0;}')
echo $IP
echo $MAC
needs ipcalc installed to convert a discrete IP address into the CIDR for my network.
It's not difficult to discover the network in python
#!/usr/bin/python
import socket
import nmap
testIP = "8.8.8.8"
s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
s.connect((testIP, 0))
ipaddr = s.getsockname()[0].split('.')
ipaddr[3] = '0'
network =""
for dot in ipaddr:
  network += dot+"."
network=network[:-1] # remove the trailing dot.
print network
This is a doctor free zone.
elParaguayo
Tue Jun 16, 2015 8:15 am
Slightly off-topic, but you could replace:
network =""
for dot in ipaddr:
  network += dot+"."
with just
network = ".".join(ipaddr)
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
Nolaan
Tue Jun 16, 2015 9:22 am
@DougieLawson : Thanks, I've forgot half the files. I've uploaded the nmap library ;)
PS : I'll try to package it this with (deb and rpm)
Tue Jun 16, 2015 9:42 am
The new version still fails to find any Raspberries on my network.
[email protected] /tmp/pyIpFinder # DISPLAY=:1 ./pyIpFinder.py
Launching threaded scan
Scan init done
Launched threaded scan
Scan started!
Scan ended!
The scan returned an empty list
Emitted
updating :D
Nolaan
Tue Jun 16, 2015 9:49 am
You just have to relaunch the app.
What happened is I'm trying to avoid people exit and relaunching the program, so I'm reloading the library path dynamically which fails since root user doesn't have /home/root directory.
I've corrected it ;)
Tue Jun 16, 2015 9:55 am
Still doesn't work.
I tried running it as root and as pi.
Nolaan
Tue Jun 16, 2015 10:00 am
Try to pull the latest and provide me with a screenshot please.
PS : Do you have the python-nmap directory in the tree?
ktb
Tue Jun 16, 2015 10:42 am
It didn't work for me without modification. I just tried it on Ubuntu 15.04 x86_64.
It seems to work after this change:
    addresses_list = re.findall("inet addr:\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3}",ifconfig)
    addresses_list = [re.sub("inet addr:","",fname ) for fname in addresses_list]
And sudo/root was required:
sudo ./pyIpFinder.py
Nolaan
Tue Jun 16, 2015 10:56 am
My bad :(
The assumption was that ifconfig was portable and the output the same with all distros, apparently not. I'll convert this portion in python to make it more portable. Then it might even work on Windows.
Thanks for the testing.
ktb wrote:It didn't work for me without modification. I just tried it on Ubuntu 15.04 x86_64.
Your change still fails for me
  File "./pyIpFinder.py", line 55, in run
    rpi_list = filter_results(scan_list(get_networks()))
  File "./pyIpFinder.py", line 170, in filter_results
    if 'mac' in nm[device]['addresses']:
KeyError: 'addresses'
Note: I'm running it on an A+ which does NOT have an eth0 interface.
ifconfig -a gives me
[email protected] /tmp/pyIpFinder # ifconfig -a
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:15 errors:0 dropped:0 overruns:0 frame:0
TX packets:15 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1100 (1.0 KiB) TX bytes:1100 (1.0 KiB)
wlan0 Link encap:Ethernet HWaddr c8:3a:35:xx:xx:xx
inet addr:xxx.xxx.xxx.xxx Bcast:xxx.xxx.xxx.255 Mask:255.255.255.0
[... global IPv6 address redacted ...]
inet6 addr: fe80::ca3a:35ff:fexx:xxxx/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:268579 errors:0 dropped:17 overruns:0 frame:0
TX packets:78903 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:97003416 (92.5 MiB) TX bytes:14973166 (14.2 MiB)
If you use my python program to determine the network address it's 100% portable.
Nolaan
Tue Jun 16, 2015 11:13 am
Is it Open Source??? :?: :?: :?:
Just kidding ;) I will since it'll save me time.
ktb
Tue Jun 16, 2015 11:41 am
Dougie, I wonder which version of nmap you are using.
Mine:
$ nmap --version
Nmap version 6.47 ( http://nmap.org )
Platform: x86_64-pc-linux-gnu
Compiled with: liblua-5.2.3 openssl-1.0.1f libpcre-8.35 libpcap-1.6.2 nmap-libdnet-1.12 ipv6
Compiled without:
Available nsock engines: epoll poll select
What do you get from adding in a print(nm[device]) ?
        for device in nm.all_hosts():
            print(nm[device])
{'status': {'state': u'up', 'reason': u'arp-response'}, 'hostname': '', 'vendor': {u'E4:F4:C6:XX:XX:XX': u'Netgear'}, 'addresses': {u'mac': u'E4:F4:C6:XX:XX:XX', u'ipv4': u'192.168.X.X'}}
{'status': {'state': u'up', 'reason': u'arp-response'}, 'hostname': '', 'vendor': {u'00:D0:2D:XX:XX:XX': u'Ademco'}, 'addresses': {u'mac': u'00:D0:2D:XX:XX:XX', u'ipv4': u'192.168.X.XXX'}}
{'status': {'state': u'up', 'reason': u'localhost-response'}, 'hostname': '', 'vendor': {}, 'addresses': {u'ipv4': u'192.168.X.XXX'}}
{'status': {'state': u'up', 'reason': u'arp-response'}, 'hostname': '', 'vendor': {u'60:BE:B5:XX:XX:XX': u'Motorola Mobility'}, 'addresses': {u'mac': u'60:BE:B5:XX:XX:XX', u'ipv4': u'192.168.X.XXX'}}
{'status': {'state': u'up', 'reason': u'arp-response'}, 'hostname': '', 'vendor': {u'B8:27:EB:XX:XX:XX': u'Raspberry Pi Foundation'}, 'addresses': {u'mac': u'B8:27:EB:XX:XX:XX', u'ipv4': u'192.168.X.XXX'}}
{'status': {'state': u'up', 'reason': u'arp-response'}, 'hostname': '', 'vendor': {}, 'addresses': {u'mac': u'90:68:C3:XX:XX:XX', u'ipv4': u'192.168.X.XXX'}}
{'status': {'state': u'up', 'reason': u'arp-response'}, 'hostname': '', 'vendor': {u'E0:CB:4E:XX:XX:XX': u'Asustek Computer'}, 'addresses': {u'mac': u'E0:CB:4E:XX:XX:XX', u'ipv4': u'192.168.X.X'}}
Tue Jun 16, 2015 11:42 am
[email protected] ~ # nmap -v
Starting Nmap 6.00 ( http://nmap.org ) at 2015-06-16 12:42 BST
Read data files from: /usr/bin/../share/nmap
WARNING: No targets were specified, so 0 hosts scanned.
Nmap done: 0 IP addresses (0 hosts up) scanned in 0.99 seconds
           Raw packets sent: 0 (0B) | Rcvd: 0 (0B)
that's the stock standard Raspbian Wheezy version.
My Jessie systems have
Starting Nmap 6.47 ( http://nmap.org ) at 2015-06-16 12:43 BST
Nmap done: 0 IP addresses (0 hosts up) scanned in 0.51 seconds
Tue Jun 16, 2015 11:50 am
Adding a print get
{'status': {'state': u'up', 'reason': u'arp-response'}, 'hostname': ''}
File "./pyIpFinder.py", line 171, in filter_results
Nolaan
Tue Jun 16, 2015 12:22 pm
Okay guys, just pushed a more portable version using python. Thanks Dougie I also had to use netifaces, another python module, since I need to search all cards addresses.
Tue Jun 16, 2015 3:04 pm
The new netifaces code works. The problem is with parsing the XML that nmap outputs. I'm still getting
  File "./pyIpFinder.py", line 75, in run
  File "./pyIpFinder.py", line 177, in scan_list
    nm.scan(hosts=trunk, arguments='-sn')
  File "/usr/lib/python2.7/dist-packages/nmap/nmap.py", line 241, in scan
    raise PortScannerError(nmap_err)
nmap.nmap.PortScannerError: u'RTTVAR has grown to over 2.3 seconds, decreasing to 2.0\n'
  File "./pyIpFinder.py", line 190, in filter_results
when I run it on my Aplus.
It worked perfectly OK on my Pi2B running Jessie. So I wonder if it's the missing eth0 that's killing it on the A+ (although I can see it doing the NMAP because it takes a long time to scan my network which has 21 hosts on it).
I learned a new trick today. I didn't know nmap could emit XML as it's output.
Nolaan
Tue Jun 16, 2015 4:08 pm
Could you provide the output of the following code executed on your A+ ?
(directly invoking python from the terminal)
import netifaces
netifaces.interfaces()
Tue Jun 16, 2015 4:52 pm
[email protected] /tmp/pyIpFinder $ python
Python 2.7.3 (default, Mar 18 2014, 05:13:23)
[GCC 4.6.3] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import netifaces
['lo', 'wlan0']
Nolaan
Tue Jun 16, 2015 5:21 pm
Ok, I will write a version with a debug flag. It's puzzling me since all interfaces are discovered. Maybe your wifi isn't associated :cry:
Tue Jun 16, 2015 6:13 pm
Nolaan wrote:Ok, I will write a version with a debug flag. It's puzzling me since all interfaces are discovered. Maybe your wifi isn't associated :cry:
My WiFi is associated, because I'm running it with a VNC session from my laptop.
Nolaan
Tue Jun 16, 2015 7:41 pm
You can pull the last code, it's now traceable ! Use ./pyIpFinder -l debug .
Tue Jun 16, 2015 8:02 pm
Nolaan wrote:You can pull the last code, it's now traceable ! Use ./pyIpFinder -l debug .
I've sent you a private message with a couple of pastebin URLs.
Nolaan
Tue Jun 16, 2015 9:22 pm
Thanks you found a bug in the filter_result function.
Tue Jun 16, 2015 9:36 pm
Still not working here's the console log
[email protected] /tmp/pyIpFinder # DISPLAY=:1 ./pyIpFinder.py -l debug > /tmp/ipFinder                                       .log
  File "./pyIpFinder.py", line 100, in run
  File "./pyIpFinder.py", line 232, in filter_results
    if 'mac' in nm[ip]['addresses']:
and the tail of the log
2015-06-16 22:33:27,876 - scan_list - DEBUG - Found device with ip addr : 10.1.1.9
2015-06-16 22:33:27,878 - scan_list - DEBUG - We return this device list : ['10.1.1.101', '10.1.1.11', '10.1.1.13', '10.1.1.138', '10.1.1.17', '10.1.1.230', '10.1.1.249', '10.1.1.251', '10.1.1.26', '10.1.1.27', '10.1.1.32', '10.1.1.40', '10.1.1.41', '10.1.1.43', '10.1.1.44', '10.1.1.47', '10.1.1.49', '10.1.1.6', '10.1.1.9']
2015-06-16 22:33:28,423 - filter_results - DEBUG - nm.all_hosts() gives : [u'10.1.1.101']
2015-06-16 22:33:28,425 - filter_results - DEBUG - Inspecting device : 10.1.1.101
2015-06-16 22:33:28,427 - filter_results - DEBUG - nm[10.1.1.101] : {'status': {'state': u'up', 'reason': u'arp-response'}, 'hostname': ''}
Return to “Python”
