Stop Button to stop active thread
Posted: Mon Jun 15, 2015 12:42 pm
hi all, im trying to make a program and id like to add a stop button which will stop the code and reset the form but im having issues getting the stop button to work as I intend.. what id like to do is have "button" start and stop the code, which for this example is a countdown from 5.
import Tkinter as tk
root = tk.Tk()
from Tkinter import *
import threading
import time
root.geometry("720x100")
root.title("Countdown Tester")
stop = threading.Event()
def reset():
button["text"] = "Begin Countdown"
label["text"] = "Countdown Finished"
label.config(bg='dark red', fg='white')
label2["text"] = ""
label2.config(bg='black', fg='white')
root.timer = root.after(1000, label.update)
root.update_idletasks()
stop.set()
def script():
if not stop.set():
label["text"] = "Countdown Began"
label.config(bg='blue', fg='white')
time.sleep(1)
label2["text"] = "5"
label2.config(bg='orange', fg='black')
time.sleep(1)
label2["text"] = "4"
time.sleep(1)
label2["text"] = "3"
time.sleep(1)
label2["text"] = "2"
time.sleep(1)
label2["text"] = "1"
time.sleep(1)
label2["text"] = "0"
reset()
def toggle_text():
if button["text"] == "Begin Countdown":
button["text"] = "Stop Countdown"
label.config(bg='green', fg='black')
stop.clear()
t1 = threading.Thread(target=script)
t1.daemon = True
t1.start()
else:
label["text"] = "Countdown Stopped"
label.config(bg='red', fg='white')
label2["text"] = ""
stop.set()
canvas = Canvas(width=720, height=100, bg='black')
canvas.grid(rowspan=26, columnspan=20, sticky='W,E,N,S')
button = Button(root, text="Begin Countdown", font='-weight bold', width=17, command=toggle_text)
button.grid(padx=10, pady=10, row=10, column=0, sticky='W,E,N,S')
button2 = Button(root, text=" Quit ", font='-weight bold', command=exit)
button2.grid(padx=5, pady=10, row=10, column=1, sticky='W,E,N,S')
label = Label(root, text=" ", width=20, font='-weight bold', background='black')
label.grid(padx=5, pady=10, row=10, column=2, sticky='W,E,N,S')
label2 = Label(root, text=" ", width=11, font='-weight bold', background='black')
label2.grid(padx=5, pady=10, row=10, column=3, sticky='W,E,N,S')
root.resizable(width=FALSE, height=FALSE)
root.mainloop()
