Aneeshnit
Python from PHP Button
Sun May 24, 2015 1:43 pm
i have this bit of code in python.. i wanted to run it from a php page runnin on pi... its been like weeks i've read all d related post nothin seems to work... can som one help me.. :| i have all the codes saved at /var/www
Python code: Leaf.py
from time import sleep
import RPi.GPIO as G
G.setmode(G.BCM)
G.setwarnings(False)
G.setup(20, G.OUT)
G.setup(21, G.OUT)
G.setup(16, G.OUT)
G.output(20, True)
sleep(1)
G.output(20, False)
G.output(21, True)
sleep(1)
G.output(21, False)
G.output(16, True)
sleep(1)
G.output(16, False)
sleep(1)
Leafpy.php
<?php
exec("sudo python3 /var/www/leaf.py");
Control.php
<!DOCTYPE html>
<html>
<head>
<meta charset="UTF-8">
<script src="//code.jquery.com/jquery-1.11.3.min.js"></script>
<script type="text/javascript">
$(document).ready(function()
$('#clickTEST').click(function()
var a=new XMLHttpRequest();
a.open("GET","leafpy.php");
a.onreadystatechange=function()
if(a.readyState==4)
if(a.status==200)
else alert("HTTP ERROR");
a.send();
</script>
<title>Pi Controller </title>
</head>
<body>
<button type ="button" style="width:200px;height:100px" id="clickleaf">TEST</button><b$
</body>
</html>
Massi
Re: Python from PHP Button
Sun May 24, 2015 2:43 pm
Aneeshnit wrote:its been like weeks i've read all d related post nothin seems to work... can som one help me..
lol, ok, so tell us what you did..
what does "nothin seems to work" means? what's the error?
Aneeshnit
Sun May 24, 2015 3:22 pm
the button!!!!...it does'nt work... the python prgrm alone works... but d php file to execute it does not..
i've tried everythin.. :cry:
tried adding #! /usr/bin/python3
tried adding all des files to sudoers
bt still nothin..
Massi
Sun May 24, 2015 4:02 pm
Aneeshnit wrote:the button!!!!...it does'nt work... the python prgrm alone works... but d php file to execute it does not..
What
error
do
you
get?
what?
Aneeshnit
Sun May 24, 2015 4:06 pm
No error as such...it simply does not run the python prgrm...
Der is a "favicon" not found..wen i chk d php log..
Massi
Sun May 24, 2015 4:51 pm
a proper answer to "doesn't work" can be "mine works"
you don't see errors simply because you are not looking at them.
Your php code has no error checks at all
start from there. Write proper php code and you'll see what's the output of your command.
I also asked you about what you added to sudoers, but even that was too much.
So my code works, good luck with yours.
Aneeshnit
Sun May 24, 2015 4:58 pm
hey hey...sorry ..sorry... am travelling..
i added www-data ALL=(ALL) NOPASSWD: ALL to sudoers.
am not an expert in php... i found dat
<?php
exec("sudo python /var/www/leaf.py")
should run s python file... but it does nothin..
Sun May 24, 2015 9:08 pm
Aneeshnit wrote: i added www-data ALL=(ALL) NOPASSWD: ALL to sudoers.
That is an enormous security hole.
Giving www-data sudo is a bad idea.
Giving www-data sudo for any possible command or program is an incredibly bad idea.
You need to find any other way to do that stuff. Clue: look at Joan's pigpiod.
Aneeshnit
Sun May 24, 2015 11:57 pm
I've read abt dis..bt jst tryin to get d code to wrk frm php/html button... Is it even possible?
mattrix
Mon May 25, 2015 4:49 am
What I would do is run a small server in the python code.
Look at bottle.py (http://bottlepy.org/docs/dev/index.html)
pip install bottle
GPIO-API.py:
from bottle import route, run
import RPi.GPIO as GPIO
PIN = 12
GPIO.setmode(G.BCM)
GPIO.setwarnings(False)
GPIO.setup(PIN, GPIO.OUT)
@route('/on')
def on():
    GPIO.output(PIN,True)
    return("ON")
@route('/off')
def off():
    GPIO.output(PIN,False)
    return("OFF")
@route('/status')
def status():
    return GPIO.input(PIN)
run(host='localhost', port=8080)
This will run a small server on port 8080.
So, if you called http://localhost:8080/on it would run your GPIO ON function.
Run this python code on system boot so it's ready to accept requests.
You can usually do this by adding the command to /etc/rc.local
eg: python /var/www/GPIO-API.py
It will run when the Pi boots, setup the GPIO's and then wait for requests.
Then all you need to do is call those URLs from your PHP code or even via Javascript (AJAX request)
index.php
<?php
$result = file_get_contents('http://localhost:8080/on');
echo($result);
$status = file_get_contents('http://localhost:8080/status');
echo($status);
This way, you don't need to worry about permissions etc for Apache / NGINX.
Essentially you have just setup a nice little API wrapper to do your GPIO functions :)
You could easily expand it to do many other things.
www.matthuisman.nz
Mon May 25, 2015 7:55 am
mattrix wrote:What I would do, is run a small web server in the python code.
That's one option and certainly a lot less of a security risk than adding www-data to sudoers.
Aneeshnit
Mon May 25, 2015 6:16 pm
thnks a ton.... DougieLawson and mattrix... i was looking for d solutin for weeks..thnks again..
Aneeshnit
Sat May 30, 2015 3:03 pm
mattrix wrote:What I would do is run a small server in the python code.
pip install bottle
hii... :? i ran this code...the php code that contains the url of leaf python executes well from any pc in d network... but wen i call this php from another file nothin happens.. is der any special permsions?
Lombra
Mon Jun 01, 2015 11:41 am
Not strictly on topic, but thanks for that great introduction to using Bottle, mattrix! Everything I've read about it (and similar methods) before now have been or seemed so needlessly complex.
I would be interested in a simple solution to executing it remotely, too. I don't want to go through any other ports over the internet, so to speak, but have it handled locally on the server. PHP and file_get_contents would do that, but that seems a bit clunky. I've read all these guides on how to setup nginx to do similar things, but again, have seemed needlessly complex. I've not understood how it really worked and given up eventually.
Edit: Now I'm thinking, even something as simple as having nginx locally redirecting requests to a certain folder to localhost:8080 instead. Would that be possible, would that be a suboptimal solution for this purpose somehow?
example.com/app/light -> localhost:8080/light
Edit2: Well I've just added this to my server config and it works! So unless there are serious flaws with it I'm gonna stick with it.
    location /light {
        proxy_pass http://localhost:8080;
mattrix
Thu Sep 03, 2015 1:09 am
That's how I would do it :)
I was going to say, just run bottle.py on port 80, but you obviously have another site running already.
I use proxy-pass a lot for services that run on different ports.
www.matthuisman.nz
Return to “Python”
