paveliche
Kill Pygame process by another script
Sat May 16, 2015 10:26 pm
Hi all
I'm trying to make a script which start / stop another script with button. Second script ia pygame screen with graphics.
The problem: after killing process screen of my second process freezing.
This is my script with button:
import RPi.GPIO as GPIO
import time
import subprocess, os
import signal
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO_switch = 18  # pin 18
GPIO.setup(GPIO_switch,GPIO.IN)
print "  Press Ctrl & C to Quit"
try:
   run = 0
   while True :
      if GPIO.input(GPIO_switch)==0 and run == 0:
         print "  Started"
         rpistr = "sudo python dht-display-v.0.2.py"
         p=subprocess.Popen(rpistr, stdout=subprocess.PIPE, shell=True, preexec_fn=os.se$
         print "pid : " + str(p.pid)
         run = 1
         while GPIO.input(GPIO_switch)==0:
             time.sleep(0.1)
      if GPIO.input(GPIO_switch)==0 and run == 1:
         print "  Stopped " + str(p.pid) + " : " + str(signal.SIGTERM)
         run = 0
         os.killpg(p.pid, signal.SIGTERM)
             time.sleep(0.1)
except KeyboardInterrupt:
  print "  Quit"
  GPIO.cleanup()
Return to “Python”
