dchapma1
Control USB port Enable / Disable
Thu Apr 16, 2015 4:49 pm
All,
I am wondering if I can enable / disable the USB ports programmatically using Python, or a script I can call from Python on the Pi?
I have a DSLR camera attached via USB. Typically when the camera sees it is attached via USB it goes into "PC" mode. I want to be able to enabled the USB - then copy the camera photos from the camera, then disable the USB to allow more photos to be taken.
I found the following:
# disable external wake-up; do this only once
echo disabled > /sys/bus/usb/devices/usbX/power/wakeup
echo on > /sys/bus/usb/devices/usbX/power/level # turn on
echo suspend > /sys/bus/usb/devices/usbX/power/level # turn off
where usbX is the appropriately numbered port, i.e. usb1, usb2, etc.
Anyone think this will work on a Pi? I haven't had lab time to try this yet.
Thanks,
Don
TheMiddle36
Re: Control USB port Enable / Disable
Wed Jun 14, 2017 5:10 pm
I think this is a very good question - I have a use for it myself but so far unable to find any other answers
Wed Jun 14, 2017 5:41 pm
There is a way to control the power to the USB ports on most Pis (B+, 2B and 3B), but it is an "all or nothing" situation. You can't switch on and off individual ports.
If the camera presents itself to the Pi as a Mass Storage Device you may be able to use the "eject" command to tell the camera to logically disconnect itself from the port. That may work.
davef21370
Wed Jun 14, 2017 5:51 pm
You could get into the true spirit of the Raspberry Pi and stick a couple of transistors on the GPIO to switch the USBs VCC and DATA+ lines.
Would that work?
Dave.
Apple say... Monkey do !!
sameenashaikh29
Mon Apr 09, 2018 11:08 am
Have you figured this out.. I am trying to do the same thing. I want to disable the usb ports, clic photos through the camera and then enable the usb port to access the sd card.. I want to do it through python programming on my raspberry pi. Can you help me with this
Hoping for a quick response
Thanks & Regards
Sameena Shaikh
B.Goode
Mon Apr 09, 2018 11:16 am
The person who originally asked this question in 2015 did not apparently receive a straightforward reply and has not logged on to the forums for 24 months. A quick response is unlikely.
sameenashaikh29
Mon Apr 09, 2018 11:44 am
Anyone else on the forum who has resolved this issue or who has worked on this might be able to help me
pcmanbob
Mon Apr 09, 2018 2:38 pm
Well the quickest way to find out how to do this is to do a search of the forum to see how people have done it.
https://www.google.co.uk/search?client= ... 04&bih=986
assuming you are using a pi3B and raspbian as you have not provided that information, then this thread has the commands you need to do it from the command line.
viewtopic.php?t=172313
But as has already been said will disable all USB ports and the Ethernet port.
Return to “Python”
