rtarb41323
GPIO and Interrupt speed
Sun Apr 05, 2015 5:32 am
Hi all!
I'm using an r-pi2 with python to read an analog-digital converter. Right now, the r-pi2 receives the "ready" signal from the ADC at a rate of 10Hz (I'm using GPIO-4 as the input pin), but in my interrupt function (associated with the rising edge on GPIO-4) is only activating about once a second.
Does anyone know the speed of the rpi2 and interrupt processing? It seems like I should be able to process interrupts a lot faster than I'm seeing.
import RPi.GPIO as GPIO
import spidev
import time
import numpy as np
import math
GPIO.setmode(GPIO.BCM)
#Define our constants and global variables here:
interrupts_rec = 0
inter_func_counter = 0
#Since this is an interrupt function, it MUST take an arguement in
#called "channel":
def busy_to_ready(channel):
        global interrupts_rec
        global inter_func_counter
        GPIO.output(17, not GPIO.input(17))
        interrupts_rec += 1
        inter_func_counter += 1
        print "interrupts received: ", interrupts_rec
        print "interrupt function call: ", inter_func_counter
#GPIO4 = input = !BUSY
#GPIO24 = output = !RD
#GPIO25 = output = !START_CONVERSION
#GPIO17 = debug pin
_RD = 24
_start_conv = 25
GPIO.setup(4, GPIO.IN, pull_up_down = GPIO.PUD_UP)
GPIO.setup(_RD, GPIO.OUT)
GPIO.setup(17, GPIO.OUT)
#Initial output pin states:
GPIO.output(_RD, GPIO.HIGH)
GPIO.output(17, GPIO.HIGH)
#Attach interrupt to "ready - _busy" pin (which is pin 4):
GPIO.add_event_detect(4, GPIO.RISING, callback=busy_to_ready)
while True:   #Infinite program loop
        nop = 1
pretoriano
Re: GPIO and Interrupt speed
Wed Mar 16, 2016 4:09 pm
Wow no answer for almost a year.
I am looking for an answer too. Did yo figure it out?
mikronauts
Wed Mar 16, 2016 4:26 pm
- 10Hz is not fast
- use pigpio for the interrupts
If you need > ~5000 samples per second, use C
croston
Thu Mar 17, 2016 7:02 am
Your infinite loop is using up all the CPU and that is why your code is running slowly.
Replace:
    nop = 1
with:
while True:
    time.sleep(1)
Return to “Python”
