KV4LQ
Python GUI?
Wed Apr 01, 2015 4:32 pm
Hi everyone, it's me again.
I was wondering if anyone could help me (or preferably teach me how to) build a GUI interface to a python program. I only need a few items, like buttons that execute code, and a slider (0 to 100) that executes code for every integer step it is moved. I also need some indicators, basically, if in1 == 1: {turn on virtual LED (as well as switch a hardware relay, but I can do that on my own)}. I'd also like to know if I could put this in a web interface, so that I could use my iPhone/Mac/PC/Android/etc to control from around the house (or the world if I set up port forwards :geek:).
If anyone asks why, I'm building a 400 Watt software-defined audio amp, network enabled, onboard media centre, etc, using the Pi2.
"What if soy milk is just regular milk introducing itself in spanish?"
Daniel Smith, KV4LQ
kusti8
Re: Python GUI?
Wed Apr 01, 2015 4:41 pm
There are plenty of tutorials on the two that I would recommend (pygame & tkinter).
Both work well and there are plenty of resources about them.
KV4LQ
Re: Python GUI?
Wed Apr 01, 2015 5:06 pm
I've tried Tkinter, but the button commands seem to execute on program runtime, not button click. Pygame sound like overkill.
Daniel Smith, KV4LQ
riklaunim
Re: Python GUI?
Wed Apr 01, 2015 6:24 pm
If it executes on runtime then something is wrong with the code. I use PyQt for GUI apps. Very high quality, good documentation and so on. If you want a web based GUI then the libraries and design will be quite different from a singal-slot driven GUI application. WeIO board uses a Tornado web server running on the board which offer GUI-pages with websockets for efficient handling of events (from server / to server).
scotty101
Re: Python GUI?
Wed Apr 01, 2015 7:04 pm
Tkinter is pretty easy. Button presses work when they are pressed. I posted some example code at the below link which used multiple buttons.
If you need any help, post your code and I'll help you debug it.
http://www.raspberrypi.org/forums/viewt ... 72#p712472
This code used a few different widgets to control gpio http://www.raspberrypi.org/forums/viewt ... 32&t=41639
TrevorAppleton
Re: Python GUI?
Thu Apr 02, 2015 7:03 pm
I have created a few tutorials in the past on how to create a GUI with Python and Tkinter.
This one creates a game of Rock, Paper, Scissors!
http://trevorappleton.blogspot.co.uk/20 ... e-gui.html
Let me know if you have any questions.
Check out my blog post for Raspberry Pi and Python tutorials.
RogerW
Re: Python GUI?
Fri Apr 03, 2015 8:44 am
This is yet another attempt to give some starting point code for a GUI. It has a menu which you can delete if you do not need it and one button. Clearly you can add more widgets.
http://www.raspberrypi.org/forums/viewt ... 2&t=105749
Roger Woollett
KV4LQ
Re: Python GUI?
Mon Apr 06, 2015 5:00 pm
OK, I'll see if I can find my code (I may have trashed it out of frustration) and I'll post it when I can.
Daniel Smith, KV4LQ
KV4LQ
Re: Python GUI?
Mon Apr 06, 2015 6:09 pm
I have attached a compression of the main folder for this project. Let me know what's wrong...
KV4LQ.zip
(8.13 KiB) Downloaded 54 times
Daniel Smith, KV4LQ
dddomodossola
Re: Python GUI?
Tue Apr 07, 2015 6:26 am
Hi KV4LQ,
Have you seen this GUI? https://github.com/dddomodossola/gui
It allows to build web interfaces in an easy way, without writing HTML nor Javascript. Only Python code, and your graphic interface can be accessed locally and remotly.
KV4LQ
Re: Python GUI?
Tue Apr 07, 2015 3:24 pm
Does the client (when coming over http connection) need python as well?
Daniel Smith, KV4LQ
scotty101
Re: Python GUI?
Tue Apr 07, 2015 4:04 pm
KV4LQ wrote:Does the client (when coming over http connection) need python as well?
With what dddomodossola is proposing: no. Any web browser enabled device should be able to access it.
dddomodossola
Re: Python GUI?
Tue Apr 07, 2015 4:16 pm
Scotty101 is right. The simplest way to try it is to run the simple_app.py. It shows a button and a onclick event.
KV4LQ
Re: Python GUI?
Tue Apr 07, 2015 9:12 pm
OK thanks guys! I will let you know how things work out!
As a side question, what did you think of my code? Was it wrong coding, wrong libs, or just plain wrong?
Daniel Smith, KV4LQ
KV4LQ
Re: Python GUI?
Tue Apr 07, 2015 9:14 pm
Oh, also: side this is a GUI interface, how difficult would it be to use with a touchscreen, say for instance, an 8" attached to the Pi? (Of course, I don't know how to hook up an 8" touchscreen for the Pi, if there is such a thing)
EDIT: I did find a 7" display on amazon, but I didn't like the $60 price tag. Anybody out there who knows of something wayyy cheaper, please let me know. I'd love to use a salvaged item. The touch is optional: just a screen would work (but be less functional obviously)
Daniel Smith, KV4LQ
dddomodossola
Re: Python GUI?
Wed Apr 08, 2015 6:29 am
I think that your code is complicated by the intensive use of "os.system" calls. You do not need this.
The right way is to write functions, and not single executable modules. Also you have to remove the "while 1" in each module... You do not need this intensive "multitasking" execution.
Let's restart the project, step by step. Try with this code:
import RPi.GPIO as GPIO
import gui #github.com/dddomodossola/gui
from gui import *
# Set input and output pin designations
input_pin=8
output_pin=7
class App( BaseApp ):
	def __init__( self, *args ):
		super( App, self ).__init__( *args )
	def main( self ):
		#the arguments are	width - height - layoutOrientationOrizontal
		wid = gui.widget( 100, 60, False )
		self.lbl = gui.labelWidget( 100, 30, "Hello world!" )
		self.bt = gui.buttonWidget( 100, 30, "Press me!" )
		#setting the listener for the onclick event of the button
		self.bt.setOnClickListener( self, "onButtonPressed" )
		#appending a widget to another, the first argument is a string key
		wid.append( "1", self.lbl )
		wid.append( "2", self.bt )
		self.output_pin_value = False
		#returning the root widget
		return wid
	#listener function
	def onButtonPressed( self ):
		self.output_pin_value = not self.output_pin_value
		if self.output_pin_value:
			GPIO.output(output_pin, 1)
		else:
			GPIO.output(output_pin, 0)
		self.lbl.setText( "Output pin value: " + str( self.output_pin_value ) )
#starts the webserver
start( App )
In the gui you will see a button. When you will press it, you will see the output_pin switching between 1 and 0.
I didn't tested this code, in particular for the GPIO. Let me know the result of the execution.
Furthermore, do you really need to use bash scripts? Try to convert that code in python.
KV4LQ
Re: Python GUI?
Sat Apr 11, 2015 7:37 pm
Well, your code is all fine and dandy, but I need a lot more than what you coded. I'm using the Pi to control an audio amp, including PWM for volume control (controls gain on an LM386 preamp). I need buttons to control relays essentially, as well as a slider to adjust the duty cycle on one pin. I'm also using hardware controls via GPIO, which the Pi needs to monitor and respond with the same actions as via the GUI. Does this gui lib have a slider, or will I have to improvise? Also, the values could be changing while the page is up, meaning a user would need to refresh to get updates.
Daniel Smith, KV4LQ
dddomodossola
Re: Python GUI?
Mon Apr 13, 2015 6:46 am
Now I added new widgets, and a sliderWidget just for you. ;-)
The refresh is not a problem, You do not need to refresh manually the page. You only need to call the function 'setUpdateTimer' for the widget of which you would like to get auto-updated content.
A complete example is available in the library, I suggest you to start the widgets_overview_app.py.
Let me know if you encounter difficulties.
KV4LQ
Re: Python GUI?
Mon Apr 13, 2015 2:33 pm
Will do. Thanks!
Daniel Smith, KV4LQ
dddomodossola
Re: Python GUI?
Thu Jun 25, 2015 6:09 am
Update:
New widget have been added to the GUI library.
Improved stability.
Improved speed adopting websockets.
gkreidl
Re: Python GUI?
Thu Jun 25, 2015 6:33 am
dddomodossola wrote:Update:
Improved stability.
You should create your own project thread and update the first post each time an update becomes available (and add an update message at the bottom so people using it get a message).
Minimal Kiosk Browser (kweb)
KV4LQ
Re: Python GUI?
Sat Jun 27, 2015 1:35 am
Improved stability.
I've kinda put this project on hold (at least software wise) since I'm having some hardware issues that I'm trying to work out. I'll do your suggestion, but I need to make sure I can make my concepts work.
Daniel Smith, KV4LQ
Return to “Python”
