timl
PyQt5 wheezy
Tue Mar 31, 2015 10:06 pm
I am trying to follow a tutorial which codes a minimal web browser written in python. This covers 2 bases for me - a simple browser would be good on the Pi and it can ease me into Python. I also tend to use more redhat oriented distros so I need to get up to speed on apt-get.
The first problem I run into relates to PyQt5 which I expect needs to be installed. My efforts thus far have not got me anywhere:
pi@resurgam ~ $ sudo apt-file search *pyqt5*
E: No config file found
If anyone could suggested how I install this package I would be grateful. I am using Wheezy.
Cheers
MarkHaysHarris777
Re: PyQt5 wheezy
Tue Mar 31, 2015 11:08 pm
in lxterminal
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install python3-pyqt5
If you run into errors, fix, then retry.
marcus
:ugeek:
DirkS
Re: PyQt5 wheezy
Wed Apr 01, 2015 9:00 am
timl wrote:The first problem I run into relates to PyQt5 which I expect needs to be installed. My efforts thus far have not got me anywhere:
To search the repo use 'apt-cache search':
apt-cache search pyqt5
I don't think python3-pyqt5 is available for Wheezy though.
ktb
Re: PyQt5 wheezy
Wed Apr 01, 2015 9:11 am
$ sudo apt-get install python-pip
$ pip search pyqt5
python-qt5                - PyQt5
cheesemaker               - A minimalistic image viewer using Python3 and PyQt5
pyqode.qt                 - Provides an abstraction layer on top of the various Qt bindings (PyQt5, PyQt4 and PySide)
qutebrowser               - A keyboard-driven, vim-like browser based on PyQt5 and QtWebKit.
qt_backport               - Makes PySide/PyQt4 code work with Qt5 (using PyQt5)
PyQtX                     - Mimics the structure of PyQt5 but provides PyQt4 as a fallback solution.
QtPy                      - Provides an abstraction layer on top of the various Qt bindings (PyQt5, PyQt4 and PySide) and
                            additional custom QWidgets.
QtStuff                   - Compatibility layer and helper classes for PySide/PyQt4/PyQt5
PyQt5                     - Python bindings for the Qt cross platform GUI toolkit
$ sudo pip install PyQt5
Note: I don't know if you want python-qt5 or PyQt5. Is there a difference? That seems a bit confusing to me.
timl
Re: PyQt5 wheezy
Sun Apr 05, 2015 1:20 am
thanks for the suggestions. I have hit a few problems so I'll have to work through them but I think I am on track now
Return to “Python”
