racpi
pigpio callback
Tue Mar 24, 2015 12:21 am
I'm writing a python pgm to use a rfm12b or a rfm69cw module,I'm thinking I can use a callback from the rfm12b int output to trigger spi read or xfer , I'm pretty sure this is doable for rx. (especially using a rfm69 with its bigger buffer)
problem I envision is that rfm modules also generate interrupts on tx/cmd xfers too , I want to be able ignore these interrupts when needed .
question is ..... how can I enable/ disable a pigpio.callback (similar to disabling the interrupt on a pic /avr )
scotty101
Re: pigpio callback
Tue Mar 24, 2015 10:12 am
Have you tried looking at the Pigpio documentation?
http://abyz.co.uk/rpi/pigpio/python.html#callback
racpi
Re: pigpio callback
Tue Mar 24, 2015 11:55 am
thanks for the reply ,but it was in fact the first place I looked . I see nothing there to pause,cancel,stop or even remove a callback once initiated . unlike notify but notify has no edge control .
anewcomb
Re: pigpio callback
Fri May 25, 2018 1:28 am
In case anyone else runs into this, it is clearly documented in the pi.gpio documentation pointed to above.
def cbf(gpio, level, tick):
   print(gpio, level, tick)
cb1 = pi.callback(22, pigpio.EITHER_EDGE, cbf)
cb1.cancel() # To cancel callback cb1.
Return to “Python”
