MadCow42
Re: Using RPi.GPIO to drive stepper motors
Thu Aug 02, 2012 3:10 am
h121 wrote:Hi and thanks for this info! It'll be very useful when I get my motors from Ebay :)
Anyway, I tried to use your code and ran into some minor problems. First of all, I think there are a few typos in the average error calculation, line 308 or so. However, Python allows us to calculate the average without using a loop to add the error values. You can simply replace lines 305-308 with this:
        errorValue = sum(errors) / len(errors)
I'll post more comments after I get to use it with some actual hardware.
Thanks for the feedback (and bug fix!)
Kevin.
onlyjus
Tue Nov 20, 2012 10:10 pm
Why not just use an easyDriver? I think you just need to hook up two GPIO pins to the Step and Dir inputs? Then you are off and running.
maecki
Wed Sep 25, 2013 1:45 pm
Don't forget the pins for sleep or enable to save energy. Easydriver normaly works with 5v but there is a solderpad to change to 3.3 V.
MadCow42
Wed Sep 25, 2013 4:12 pm
onlyjus wrote:Why not just use an easyDriver? I think you just need to hook up two GPIO pins to the Step and Dir inputs? Then you are off and running.
Current. I need to drive >1 amp per phase (including during a prolonged hold / lock) for max torque. Also - for the joy of building something from the bare bones upwards. :).
Return to “Python”
Who is online
Users browsing this forum: asavah, Billybobs and 9 guests
