Fugazi1978
Keystroke detection without drawing a window...
Tue Jul 03, 2012 9:22 pm
I'm trying to get keystroke detection without a window (I want a purely command line driven jukebox).
My code is poor and I'm trying to code without using def etc:
if pygame.event.get(pygame.KEYDOWN) == pygame.K_b:
	pygame.mixer.music.pause()
if event.key == pygame.K_n:
	pygame.mixer.music.stop()
if event.key == pygame.K_v:
	track = track - 2
Basically I want to detect a keystroke and do something dependent on the key.
Any ideas? This is without drawing a window etc, this is purely command line driven.
pyglet or pygame or purely python or ANY other source that'll run on Linux (debian).
Thanks.
jmacey
Re: Keystroke detection without drawing a window...
Tue Jul 03, 2012 10:18 pm
you could try curses which is installed with the default python, something like this
import curses
#init the curses screen
stdscr = curses.initscr()
#use cbreak to not require a return key press
curses.cbreak()
print "press q to quit"
quit=False
# loop
while quit !=True:
	c = stdscr.getch()
	print curses.keyname(c),
	if curses.keyname(c)=="q" :
		quit=True
curses.endwin()
http://docs.python.org/library/curses.html
tcstyle
Wed Jul 04, 2012 7:34 am
Pygame is a good choice for this task. It can run without display and the event manager should handle your specified events.
Example:
import pygame
pygame.init()
finished = False
while not finished:
  for event in pygame.event.get():
    if event.type == pygame.QUIT:
      finished = True
   if event.type == pygame.KEYDOWN:
      if event.key == #specify your keys and actions here
This should be your main loop for catching the key events. (Please correct the indents when copying this code snippet.)
Fugazi1978
Wed Jul 04, 2012 2:47 pm
Here's the code for the media player with keystroke detection, unfortunately it plays slowly (anyone any ideas):
[code]
import os
import sys
import pygame
import curses
#pygame.init()
loop = 0
esc = 0
os.system('clear')
# music files (ogg) must be in a folder, 'music', in same folder as program
os.system('ls -1pR music > files.out')
# open list of files
f = open('files.out', 'r')
# create a list C[ ]
C = ['this','is','a','list']
# empty c
C[:] = []
# read first line of files.out
A = f.readline()
# reads all lines of files.out, places full path to each file in C[ ]
while esc == 0:
if A[-2:-1] == ":":
while loop == 0:
B = f.readline()
if B[-2:-1] == ":":
A = B
if B[-5:-1] == ".ogg":
C[len(C)+1:] = [A[:-2] + '/' + B[:-1]]
if B == "":
esc = 1
loop = 1
else:
A = f.readline()
curses.cbreak()
track = 0
breaker = 0
# set up the mixer
freq = 44100 # audio CD quality
bitsize = -16 # unsigned 16 bit
channels = 2 # 1 is mono, 2 is stereo
buffer = 2048 # number of samples (experiment to get right sound)
pygame.mixer.init(freq, bitsize, channels, buffer)
# optional volume 0 to 1.0
pygame.mixer.music.set_volume(1.0)
# starts pygame clock
clock = pygame.time.Clock()
while breaker == 0:
pygame.mixer.music.load(C[track])
pygame.mixer.music.play()
pz = 1
# check if playback has finished
while pygame.mixer.music.get_busy():
clock.tick(30)
# python curses to 'get' keyboard input
k = stdscr.getch()
# press b to pause/play track
if curses.keyname(k)=="b":
if pz == 1:
pz = 2
else:
pz = 1
# press n to move to next track
if curses.keyname(k)=="n":
# press v to go back a track
if curses.keyname(k)=="v":
track = track -2
# press q to quit
if curses.keyname(k)=="q":
pygame.mixer.quit()
breaker = 1
curses.endwin()
track = track + 1
# check track number isn't less than first track
if track < 0:
track = len(C) + track
# check track number isn't more than last track
if track > len(C) - 1:
track = 0
[/code]
It plays ogg files, anywhere from within the 'music' folder that is in the same folder as the program.
Any improvements to the current script greatly appreciated. Requires pygame.
Aim of the program is a command line jukebox with keystroke detection for moving through tracks.
Matthew
Yam
Thu Jul 05, 2012 2:02 pm
If you dont draw a window you need to manually 'pump' the event que
Its in the documentation pygame.event.pump()
http://www.pygame.org/docs/ref/event.ht ... event.pump
Yam
Fri Jul 06, 2012 6:46 pm
Been experimenting today can't really get the pump to work.
Its kinda hinted that its not a good idea to try so the other suggestions are proably a better idea.
I'm guessing the pump in conjuction with pygame.event.set_grab / get_grab will probably work but i dont even want to think about the problems that might cause.
Fugazi1978
Sat Jul 07, 2012 12:22 pm
Curses is brilliant in conjunction with the pygame check for end of track.
Return to “Python”
