A really basic tkinter question
Posted: Sat Feb 21, 2015 4:50 pm
by P_Monty
This probably is really basic, but here goes...
I'm trying to learn python by reading books and checking online resources and doing OK so far. My next step is to put a small graphical wrapper around what I'm doing.
So far, I've got this:
#!/usr/bin/env python
#Import anything necessary
from tkinter import *
#define some functions
def OKaction():
        print('Pressed OK')
def Quitaction():
        print('Pressed Quit')
window = Tk()
window.title("Control Panel")
buttonOK=Button(window, text="OK", command = OKaction)
buttonOK.pack()
buttonQuit=Button(window, text="Quit", command = Quitaction)
buttonQuit.pack()
mainloop()
I'm editing this in an IDLE3 window. If I hit 'run' from the window, the code behaves as expected. If I bring up a text terminal and type 'python filename.py' I get an error that there's no module called tkinter.
can someone tell me what's happening and how toi fix it so I can run my code from the command line?
Paul
Re: A really basic tkinter question
Posted: Sat Feb 21, 2015 4:55 pm
by DirkS
You're using python3 in IDLE3, but Python 2 on the command line. In python 2 the module name is Tkinter.
It's best to stick to one version, so I would use
python3 filename.py
Posted: Sat Feb 21, 2015 4:59 pm
by P_Monty
That was quick and easy - thanks :D
I was wondering if it was something like that, but couldn't find a way of telling what version of python I was using on the command line.
Cheers
Posted: Sat Feb 21, 2015 6:55 pm
by B.Goode
P_Monty wrote:couldn't find a way of telling what version of python I was using on the command line.
Cheers
Too late for you, but for the next person who might need to know
pi@RPi2B ~ $ python --version
Python 2.7.3
or simply
pi@RPi2B ~ $ python
Python 2.7.3 (default, Mar 18 2014, 05:13:23)
[GCC 4.6.3] on linux2
Type "help", "copyright", "credits" or "license" for more information.
