zero10
Error when running GPIO.cleanup()
Thu Feb 19, 2015 2:18 pm
I have written a program to output data to a WS2803 LED controller that is connected to GPIO17/GPIO18. The code itself runs properly, which is to say that the one LED I currently have connected does exactly what I expect, but I am getting an error when I CTRL+C the program to get it to stop. I think this pertains to my GPIO.cleanup() call which I added inside a try/except block to stop the "this channel is already in use" warnings when I run the program multiple times.
Here is my code:
import RPi.GPIO as GPIO
from time import sleep
GPIO.setmode(GPIO.BCM)
clock = 17
mosi = 18
GPIO.setup(clock,GPIO.OUT)
GPIO.setup(mosi,GPIO.OUT)
GPIO.output(clock,True)
GPIO.output(mosi,False)
counter = 0
def writeByte(value):
        # do something to write the byte
        mask = 0x80
        for i in range(8):
                GPIO.output(clock,False)
                if (value & mask):
                        GPIO.output(mosi,True)
                else:
                mask >>= 1
while True:
        try:
                sleep(0.0005)
                for i in range(3):
                        writeByte(counter)
                for i in range(15):
                        writeByte(0)
                counter = counter + 1
                if (counter > 255):
                        counter = 0
        except KeyboardInterrupt:
                GPIO.cleanup()
And here is the error i get when I stop the program:
 ~/spi $ sudo python test.py
^CTraceback (most recent call last):
  File "test.py", line 32, in <module>
RuntimeError: Please set pin numbering mode using GPIO.setmode(GPIO.BOARD) or GPIO.setmode(GPIO.BCM)
Without the GPIO.cleanup() I get the following errors when I run the program more than one time:
test.py:8: RuntimeWarning: This channel is already in use, continuing anyway.  Use GPIO.setwarnings(False) to disable warnings.
test.py:9: RuntimeWarning: This channel is already in use, continuing anyway.  Use GPIO.setwarnings(False) to disable warnings.
Clearly I am doing something wrong. I have general familiarity with embedded systems (some arduino/pic experience) but usually do my development in .NET, this is my first ever time using python. Can anybody spot my mistake? Thanks in advance for any help!
zero10
Re: Error when running GPIO.cleanup()
Thu Feb 19, 2015 2:45 pm
D'oh! I found the error. The try/except is inside the loop when it should be outside! Pushing that up one level fixes the problem. Here is the solution:
clock = 17
mosi = 18
counter = 0
        mask = 0x80
        for i in range(8):
                if (value & mask):
                else:
                mask >>= 1
try:
        while True:
                sleep(0.0005)
                for i in range(3):
                        writeByte(counter)
                for i in range(15):
                        writeByte(0)
                if (counter > 255):
                        counter = 0
        GPIO.cleanup()
Return to “Python”
