americantrain
How do I implement a Linux shutdown -h now command from pyth
Tue Feb 17, 2015 9:32 pm
I am trying to safely shutdown Pi using a button signal through the GPIO. When I include the command "shutdown -h now" in the python script it either gives me a syntax error or says that "shutdown" is not defined. What am I doing wrong and how can I fix it.
A sample of the Code is attached:
.[import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(23, GPIO.IN)
While True:
If GPIO.input(23):
shutdown -h now]
elParaguayo
Re: How do I implement a Linux shutdown -h now command from
Tue Feb 17, 2015 9:39 pm
shutdown is a shell comand, not a python one.
To use shell commands in python you should use the subprocess module. e.g.
import subprocess
subprocess.call(["shutdown", "-h", "now"])
I would suggest, however, that you replace that line with a print statement (or something similar) so you can check the rest of the code is working without shutting down your pi every time. Once it's working, then use the subprocess line.
You may run into permission issues depending on how you're running your python script.
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
kusti8
Tue Feb 17, 2015 10:13 pm
elParaguayo wrote: You may run into permission issues depending on how you're running your python script.
You have to run the python script as root anyway if you are using GPIO. Anyway, yes, that is the way to go.
elParaguayo
Tue Feb 17, 2015 10:14 pm
Well, yes, that was dumb of me to miss that. Thanks for putting me straight!
Ace Rimmer
Sat Sep 24, 2016 4:19 am
Hi, I've been trying to use the above code to shutdown my pi when python script finishes. When the script finishes instead of shutting down I get the following
TypeError: 'str' object is not callable
What am I doing wrong?
There must be an easier way!!!!!
I hope there is.....I haven't found it yet.
Ace Rimmer
Sat Sep 24, 2016 6:11 am
I just tried
os.system('shutdown now -h')
and it works a treat :D
elParaguayo
Sat Sep 24, 2016 6:25 am
Ace Rimmer wrote:Hi, I've been trying to use the above code to shutdown my pi when python script finishes. When the script finishes instead of shutting down I get the following
Post your code and we'll find the problem. It would be good to fix this as using subprocess is preferred over os.system.
tom.slick
Sat Sep 24, 2016 7:09 am
The shlex will give you the correct args to pass to subprocess.call
import subprocess
import shlex
cmd = shlex.split("sudo shutdown -h now")
subprocess.call(cmd)
elParaguayo
Sat Sep 24, 2016 7:21 am
tom.slick wrote:The shlex will give you the correct args to pass to subprocess.call
import subprocess
import shlex
Indeed - it's a very good way of doing this when you have a command line that you know works.
I don't know if that would cause the error described though.
Ace Rimmer
Sat Sep 24, 2016 10:01 pm
Hi again, the code I used was exactly as the above example
import subprocess
.#my code
I tried several variations, all to no avail. I don't know if it makes any difference but I'm using Python 2 under Wheezy.
elParaguayo
Sun Sep 25, 2016 5:08 am
That shouldn't give you the error message you saw. Can you paste the full error message (it should refer to the offending line) and paste the rest of your code.
tom.slick
Sun Sep 25, 2016 6:35 am
import subprocess
import shlex
That advise is for the OP, just to make things a little easier for the future.
To Rimmer:
elParaguayo wrote:That shouldn't give you the error message you saw. Can you paste the full error message (it should refer to the offending line) and paste the rest of your code.
As stated, give the entire error message and code used. A string error should not be happening.
Ace Rimmer
Sun Sep 25, 2016 9:32 pm
Thanks Tom & elP' , may take a while to get things back the way they were in order to replicate the error.
Cheers.
Ace Rimmer
Fri Sep 30, 2016 12:05 am
Better late than never. Below isn't the original bit of code I was using but it produces the same errorcode.
 #!/usr/bin/env python2.7
print ('   INITIALISING >>>>>>')
import datetime as dt
from time import *#time
import subprocess
GPIO.setwarnings(False)
GPIO.setup(18, GPIO.OUT) # Red LED
def blinkescape():
    x=0
    while x < 10:
        GPIO.output(18, GPIO.HIGH)
        sleep(1)
        GPIO.output(18, GPIO.LOW)
        sleep(1)
        x=x+1
blinkescape()
print ("goodbye")
sleep(1)
and the result....
WELCOME TO MY NIGHTMARE  Fri Sep 30 09:50:40 AEST 2016
[email protected] ~ $ sudo python2 blinkescape.py
   INITIALISING >>>>>>
goodbye
  File "blinkescape.py", line 26, in <module>
and there you have it!
As I said in my earlier post I'm using Python2 under Wheezy on a B+.
tom.slick
Fri Sep 30, 2016 1:21 am
I see the problem
Your RPI is upside down.
But seriously the script works for me. Do you maybe have a file called subprocess.py in the same folder.
Add these lines to just before subprocess.call(["shutdown", "-h", "now"])
print subprocees
print type(subprocess)
print subprocess.call
print type(subprocess.call)
Ace Rimmer
Fri Sep 30, 2016 2:05 am
Thanks tom, you're a genius.
Before I added the extra bit of code that you suggested I had a look in /Pi and sure enough there was a file called subprocess.pyc. That jogged my memory, I made that file in one of my many attempts to get "shutdown" happening and forgot to delete it.
The print out after the extra code......
WELCOME TO MY NIGHTMARE  Fri Sep 30 11:49:44 AEST 2016
   INITIALISING >>>>>>
goodbye
<module 'subprocess' from '/home/pi/subprocess.pyc'>
<type 'module'>
sudo shutdown --P
<type 'str'>
  File "blinkescape.py", line 30, in <module>
You can see why most of my posts are in "Beginners" :roll:
I think it might be me that is upside down!!
Ace Rimmer
Fri Sep 30, 2016 2:13 am
I almost made the mistake of deleting the offending file and running the script again while I was half way through my reply.
A good thing I woke up in time as it now shuts down as it should. 8-)
Thanks again.
tom.slick
Fri Sep 30, 2016 7:22 am
So to recap for the benifet of others, you were importing a file you named subrpocess and not the built-in subprocess module.
print subprocess
/home/pi/subprocess.pyc is the location of an old file you made and not something from the python path
print type(subporcess)
<type 'module'>
sudo shutdown --P
the result of your module having a variable call that was set to "sudo shutdown --P"
<type 'str'>
confirm that it was a string in your module
deleting or moving subprocess.py and/or subprocess.pyc solved your problem as now you import the built-in subprocess module instead of your own module.
Ace Rimmer
Fri Sep 30, 2016 9:50 pm
That's right tom, when the module I wrote didn't work I neglected to delete it before I moved to the next method. Mea culpa.
fdr4prez
Sat Oct 01, 2016 5:56 am
I've successfully used the two samples for shutdown
This code shutdowns when you push a button:
import time
import os
GPIO.setmode(GPIO.BOARD)
GPIO.setup(5, GPIO.IN, pull_up_down = GPIO.PUD_UP)
while True:
    print GPIO.input(5)
    if(GPIO.input(5) == False):
        os.system(“sudo shutdown -h now”)
        break
    time.sleep(1)
This code shutdowns if you hold down a button for 2 seconds:
from gpiozero import Button
from subprocess import check_call
from signal import pause
def shutdown():
    check_call(['sudo', 'poweroff'])
shutdown_btn = Button(19, pull_up=True, hold_time=2) #change 19 into desired GPIO pin
shutdown_btn.when_held = shutdown
pause()
Return to “Python”
