gadgetoid
Re: WiringPython - WiringPi for Python
Mon Sep 03, 2012 9:41 pm
Pushed an update to the repo if anyone would care to test: https://github.com/WiringPi/WiringPi-Python
Haven't wrapped this one up as a PyPI package yet, but it should be good to go.
texy
Tue Sep 04, 2012 6:20 am
Hi Gadgetoid.
So to update, or install from fresh is it :
git clone https://github.com/WiringPi/WiringPi-Python.git
...also going by the 'age' of the various files, the readme has'nt been updated, so we don't know how to use the new features.
Apologies in advance, if I am misunderstanding - I haven't actually tried the update ;)
Texy
kcranley
Wed Sep 12, 2012 8:21 am
Hi Gadgetoid
I previously had WiringPi working but on upgrading my Wheezy from 2012-07-15-wheezy-raspbian to the 2012-08-16-wheezy-raspbian version, I'm getting:
ImportError: No module named _wiringpi
I have tried
sudo apt-get install python-dev python-pip
Then:
sudo pip install wiringpi
but the wiring.py module seems to be having trouble finding _wiringPiGpioMode
I would be very grateful if you could help
Many thanks in advance
KC
sparkyhall
Wed Sep 12, 2012 8:19 pm
As far as I know there is no "wiringPiGpioMode" command, perhaps there used to be in earlier versions?
In your python code to setup wiringpi with gpio pin numbering you should use something like:
import wiringpi
wiringpi.wiringPiSetupGpio()
Regards,
sparkyhall
kcranley
Thu Sep 13, 2012 9:16 am
In my wiringpi.py, there is the following section:
83   def wiringPiGpioMode(*args):
84      return _wiringpi.wiringPiGpioMode(*args)
85   wiringPiGpioMode = _wiringpi.wiringPiGpioMode
and this last line is where it's failing:
AttributeError: 'module' object has no attribute 'wiringPiGpioMode'
sparkyhall
Thu Sep 13, 2012 7:44 pm
It looks like you still have an out of date wiringpi.py there, here's what I have in mine after a "pip install wiringpi":
79  def wiringPiSetupGpio():
80    return _wiringpi.wiringPiSetupGpio()
81  wiringPiSetupGpio = _wiringpi.wiringPiSetupGpio
82
83  def pullUpDnControl(*args):
84    return _wiringpi.pullUpDnControl(*args)
85  pullUpDnControl = _wiringpi.pullUpDnControl
Note: my wiringpi.py is located in /usr/lib/python2.7/site-packages
kcranley
Fri Sep 14, 2012 4:36 pm
Thank you!! I copied wiringpi.py from /usr/local/lib/python2.7/dist-packages to /home/pi where my Python program lives, over-writing the old file - and it now works!! My old version of wiringpi.py was evidently out of date.
ACP_
Fri Sep 14, 2012 6:33 pm
When compiling today's code form git repository gcc has problem finding wiringPi.h on my Raspbian wheezy:
WiringPi/wiringPi/piNes.c:25:22: fatal error: wiringPi.h: No such file or directory
You just need to edit piNes.c and change first include line into:
#include "wiringPi.h"
That fixes the problem.
devnull
Sun Sep 16, 2012 9:46 am
Hi;
Thanks so much for all the work on this, but would it be possible to include wiringpi's latest support for interrupts, ?.
It is exactly what I need to solve a problem that would otherwise involve a tight loop and lots of cpu usage
Many Thanks
> /dev/null 2>&1
texy
Mon Sep 24, 2012 4:20 pm
ACP_ wrote:When compiling today's code form git repository gcc has problem finding wiringPi.h on my Raspbian wheezy:
That doesn't fix it for me - the first line is already
#include <wiringPi.h>
Even if I add your additional line, still get the same error.
The 'pip method does work, however.
Texy
devnull
Mon Sep 24, 2012 11:07 pm
Hi;
The first line needs to be changed to use speech marks, from:
to:
> /dev/null 2>&1
texy
Tue Sep 25, 2012 8:46 am
Surely if it had both versions it should be ok?
Texy
alexeames
Tue Sep 25, 2012 1:20 pm
I've just got past this hurdle...
...and stumbled at the next fence. :(
Now it's bombing out at the GPIO make stage. I get this...
No rule to make target '/usr/local/lib/WiringPi.a' needed by 'gpio'. Stop.
I'm trying to install on August Raspbian, following these instructions
Any ideas?
Alex Eames RasPi.TV, RasP.iO
texy
Tue Sep 25, 2012 1:35 pm
Like I said, using the pip installation method worked for me with the latest raspbian distro.
http://www.raspberrypi.org/phpBB3/viewt ... 00#p162668
Texy
alexeames
Tue Sep 25, 2012 1:47 pm
Thanks Texy. I saw that but didn't understand what it did. Since I was two commands away from finishing...
What does pip do? Does that replace the entire compile and install process?
I think I've got wiringpi installed OK it's the GPIO bit that failed. So thinking about it, I should still be able to use wiringpi if I run the python scripts as sudo, right?
BlackJack
Wed Sep 26, 2012 8:25 am
@alexeames: ``pip`` is not replacing compiling and installing — it is doing exactly that.
while not self.asleep():
    sheep += 1
alexeames
Tue Oct 02, 2012 2:42 pm
OK I've got time to play with this now my Raspberry Jam demo is out of the way.
How would I use wiringpython to read input FROM the serial port?
Serial:
serial = wiringpi.serialOpen('/dev/ttyAMA0',9600) // Requires device/baud and returns an ID
wiringpi.serialPuts(serial,"hello")
wiringpi.serialClose(serial) // Pass in ID
This shows us how to open and close the port and how to print to it (I think), but what about the opposite?
Suppose, purely hypothetically of course, that I'm running a tmp36 temperature sensor on a Gertboard using the Atmega to ADC and convert to a temperature reading which it outputs to serial.
How can I read this signal into a Python program? Is there a serialGets function to go with serialPuts? Or have I missed the point. :lol:
alexeames
Tue Oct 02, 2012 10:00 pm
Perhaps I have missed the point? I've managed to do what I wanted (read the serial port) with pyserial. :lol:
bitbitbit
Tue Oct 16, 2012 8:19 am
Hi.....
I installed wiringpi (the original one in C) and it worked perfectly
Now, I want to try the wiringpi in python....installed it and ran it successfully....
Wrote a very simple code for testing::
#!/usr/bin/python
import wiringpi
from time import sleep
io = wiringpi.GPIO(wiringpi.GPIO.WPI_MODE_SYS)
io.pinMode(13,io.OUTPUT)  # Setup pin 18 (GPIO1)
while True:
    io.digitalWrite(13,io.HIGH)  # Turn on light
    sleep(2)
    io.digitalWrite(13,io.LOW)  # Turn off
    sleep(2)
but nothing happens?? The LED does not blink.... how can I debug the problem? Very much appreciated if somebody could point me to the right direction....as there was no error code coming out and I don't know what went wrong.....
I tried to plug to other pins (if i did the connection wrongly)...and I also tried my LED with the 3.3V, no problem with the LED.....also tried to open python in terminal and type the code line by line, still no results......
Thanks!
Grumpy Mike
Tue Oct 16, 2012 9:51 am
Change this line to:-
io = wiringpi.GPIO(wiringpi.GPIO.WPI_MODE_GPIO)
Does the program just quit on this line?
If so I don't think it has installed correctly.
bitbitbit
Tue Oct 16, 2012 9:58 am
Grumpy Mike wrote:Change this line to:-
Nope....it didn't quit..... :roll:
Grumpy Mike
Tue Oct 16, 2012 1:14 pm
Yes it looks like stuff that used to work now doesn't.
The joy of the snakes and ladders game that is Linux. :cry:
Off to load the latest version of Rasbain and start from square one again.
texy
Tue Oct 16, 2012 2:10 pm
The method I use for my LCD's is slightly different, but still uses wiringpi for python. Try this :
#!/usr/bin/python
import wiringpi
LED  = 1  # gpio pin 12 = wiringpi no. 1
wiringpi.wiringPiSetup()
wiringpi.pinMode(LED, 1) # output
while True:
    wiringpi.digitalWrite(LED, 1)  # Turn on light
    sleep(2)
    wiringpi.digitalWrite(LED, 0)  # Turn off
    sleep(2)
...you may need to format it correctly for python, this is just hand cut & paste.
Texy
Grumpy Mike
Tue Oct 16, 2012 4:26 pm
There isn't a GPIO pin 12 on the Pi?
Do you mean physical pin 12 or WiringPi pin 12 which is GPIO pin 10
Or perhaps you mean Physical pin 12 which is GPIO pin 18.
texy
Tue Oct 16, 2012 4:35 pm
I mean physical pin 12, yes that's bcm GPIO18, aka wiringpi pi 1, as shown here :
https://projects.drogon.net/raspberry-pi/wiringpi/pins/
Cheers,
Texy
Return to “Python”
