danandu
Display jpg image using Image Viewer python 2.7
Wed Jun 23, 2021 5:29 am
Hi ,
i am unable to open jpg image using python 2.7 ImageViewer
from PIL import Image
img = Image.open('butterfly1.jpg')
img.show()
please let me know what to do. i am running this code in raspbian raspberry pi 3 B+
gordon77
Re: Display jpg image using Image Viewer python 2.7
Wed Jun 23, 2021 5:07 pm
Do you get any error messages ?
klricks
Wed Jun 23, 2021 6:23 pm
Where is the image file stored?
Try using the full path.
scruss
Wed Jun 23, 2021 8:53 pm
Hi danandu - welcome to the forum.
You've done nothing wrong here. There's been a package missing from the Raspberry Pi OS desktop forever that stops this from working. You will need a working network connection to fix this Please do this from a terminal:
sudo apt install -y imagemagick
and try running the code again. It should run this time!
Explanation for nerdy folks: This fails silently on the Desktop because PIL or Pillow has a hidden hard-coded dependency on an image viewer. It looks through your PATH for one of three viewers:
  1. display, from ImageMagick;
  2. eog, from Gnome;
  3. xv, from the primordial mists of time. I'm old enough to remember when the (one) web browser couldn't load JPEGs and shelled out to xv to display them …
Since quite a bit of ImageMagick is already installed, it makes sense to install the binaries. eog would require most of an Gnome installation to run, and xv — though tiny — had a nonfree licence and is probably still showing UNREGISTERED to anyone who'd dare to build it. I bought a licence, once, in 1996, but I'm not sure what happened to it.
How you might diagnose silent problems like this: strace. Calling a program via strace prints every system call and its results to stderr. Yes, that's a lot of output. Here's what you get running strace without ImageMagick installed, edited a lot for length:
strace python ./show.py
stat64("/usr/local/sbin/display", 0xbeb9a9d0) = -1 ENOENT (No such file or directory)
stat64("/usr/local/bin/display", 0xbeb9a9d0) = -1 ENOENT (No such file or directory)
stat64("/usr/sbin/display", 0xbeb9a9d0) = -1 ENOENT (No such file or directory)
stat64("/usr/bin/display", 0xbeb9a9d0)  = -1 ENOENT (No such file or directory)
stat64("/sbin/display", 0xbeb9a9d0)     = -1 ENOENT (No such file or directory)
stat64("/bin/display", 0xbeb9a9d0)      = -1 ENOENT (No such file or directory)
stat64("/usr/local/games/display", 0xbeb9a9d0) = -1 ENOENT (No such file or directory)
stat64("/usr/games/display", 0xbeb9a9d0) = -1 ENOENT (No such file or directory)
stat64("/usr/local/sbin/eog", 0xbeb9a9d0) = -1 ENOENT (No such file or directory)
stat64("/usr/local/sbin/xv", 0xbeb9a9d0) = -1 ENOENT (No such file or directory)
I edited the PATH walk down a lot, but it looks for display, then eog, then finally xv. Here it finds none of them.
After installing ImageMagick, there's one line that's critically different:
stat64("/usr/bin/display", {st_mode=S_IFREG|0755, st_size=5596, ...}) = 0
That signals that the binary has been found and all is well.
Update: logged an issue - RPiOS Desktop is missing ImageMagick's display, so PIL.Image.show() Python examples won't work #249
Pronouns: he/him
Return to “Python”
