TamP
Python script from sh
Sat Jun 19, 2021 11:55 am
Both files reside in /home/pi/Documents folder
#!/bin/sh
cd /
cd home/pi/Documents
sudo python TestSpeech.py
cd
The python script runs ok on its own
import pyttsx3
engine = pyttsx3.init()
engine.say("I am talking now ");
engine.setProperty('rate',100)
engine.runAndWait();
When calling the python script from sh it returns the following error
  File "TestSpeech.py", line 1, in <module>
    import pyttsx3
ImportError: No module named pyttsx3
Python 3 on Pi400
any help appreciated
GlowInTheDark
Re: Python script from sh
Sat Jun 19, 2021 12:12 pm
Lose the "sudo".
sudo does not mean please.
Poster of inconvenient truths.
Linux zealot and proud of it.
TamP
Sat Jun 19, 2021 12:37 pm
Removing sudo made no difference
I still get the same error
klricks
Sat Jun 19, 2021 12:44 pm
Python 3 code needs to be started with python3 not python. (python means Python 2)
Why the redundant CD?
The script can be reduced to:
#!/bin/bash
python3 /home/pi/Documents/TestSpeech.py
GlowInTheDark
Sat Jun 19, 2021 1:25 pm
The script can and should be reduced to:
$ cd
$ mkdir bin
$ mv Documents/TestSpeech.py bin
Reboot Pi (See below at *), then:
$ TestSpeech.py
No need for any shell script at all.
Foonote: *) Yes, rebooting is overkill, but let's keep things simple for teaching purposes.
GlowInTheDark
Sat Jun 19, 2021 1:27 pm
Even so, you should remove it - for these reasons:
1) It can mess things up. You will end up with files owned by root instead of being owned by you (user pi).
2) Even if you fix the python2/python3 issue (as suggested by another poster), you will then find that removing the sudo is necessary, since Python seems to keep track of which modules are installed on a per-user basis.
TamP
Sat Jun 19, 2021 2:15 pm
Should it be
or
mv Documents/TestSpeech.py /bin
GlowInTheDark
Sat Jun 19, 2021 2:48 pm
Should it be
or
The first one. As I wrote it.
katesimon123
Sun Jun 20, 2021 6:36 am
Should it be
or
It should be: mv Documents/TestSpeech.py bin
thagrol
Sun Jun 20, 2021 11:51 am
$ cd
$ mkdir bin
$ TestSpeech.py
You forgot a couple of steps:
  1. Make sure the first line of the script is
    #!/usr/bin/env python3
  2. Grant it execute permission:
    chmod +x ~/bin/TestSpeech.py[
I'm a volunteer. Take me for granted or abuse my support and I will walk away
All advice given is based on my experience. it worked for me, it may not work for you.
Need help? https://github.com/thagrol/Guides
GlowInTheDark
Sun Jun 20, 2021 12:12 pm
I also left out:
1) Plug the computer in.
2) Open up a terminal window (or log in on a VC).
Probably a few hundred other steps I left out as well.
I'll try to do better in future.
TamP
Sun Jun 20, 2021 12:54 pm
To recap
My file TestSpeech.py resides in /home/pi/bin
The pyhon script contains the shebang
If I run ./TestSpeech.py from the /home/pi/bin folder it works
How do I now get it to run when the pi boots ?
thagrol
Sun Jun 20, 2021 12:55 pm
I also left out:
Well yeah. But that wasn't the point I was trying to make. OP is clearly a beginner. Had they followed your instructions they wouldn't have been able to run their python script as you suggested.
Guess I could have phrased that post better. Sorry.
thagrol
Sun Jun 20, 2021 1:01 pm
To recap
Best way? A systemd service (seach the forums and/or web)
Second best way? cron:
  1. Code: Select all
    crontab -e
  2. Add the following at the end of the file:
    @reboot /home/pi/bin/TestSpeech.py >/home/pi/TestSpeech.log 2>&1
Least best way? /etc/rc.local
Add this above exit 0
su pi /home/pi/bin/TestSpeech.py >/home/pi/TestSpeech.log 2>&1
The output redirection will help should you need to troubleshoot.
TamP
Sun Jun 20, 2021 2:19 pm
I thank you for your time and patience
I used the crontab option and all is working well
Thanks again
Return to “Python”
