Gatsby25
Initializing variables in a class
Thu Jun 17, 2021 9:18 pm
Hello. I'm writing a class for my NeoPixel LED strip, and before I continue further, I wanted to get some pointers on how to write good classes. Also a couple questions:
  1. How would I make it so that I can make the brightness configurable? Say I wanted to have a default brightness of "0.2" and the user wanted to change it. Let's say it can be changed with a new function called adjustBrightness(brightness_level). Right now the value is defined outside of the class when instantiating NeoPixel.
  2. Is there a way I can just instantiate the outside variables (like numPixels or pixels) inside the class, or would that be bad practice?
My code:
# LEDStripClass.py
import time
import board
import neopixel
# LED Strip Pin Location
LED_STRIP_PIN = board.D12
# LED Strip Initialization
numPixels = 60
pixels = neopixel.NeoPixel(LED_STRIP_PIN, numPixels, brightness=0.2)
class LEDStrip:
    def turnOff(self, pixels):
        pixels.fill((0, 0, 0))
        time.sleep(0.3)
    def turnRedOn(self, pixels):
        pixels.fill((255, 0, 0))
        time.sleep(0.3)
    def turnGreenOn(self, pixels):
        pixels.fill((0, 255, 0))
        time.sleep(0.3)
    def turnBlueOn(self, pixels):
        time.sleep(0.3)
    def rainbowPattern(self, pixels):
        for x in range(0, 9, 1):
            pixels[x] = (255, 0, 0)
            time.sleep(0.1)
        for x in range(9, 18, 1):
            pixels[x] = (255, 70, 0)
            time.sleep(0.1)
        for x in range(18, 27, 1):
            pixels[x] = (255, 255, 0)
            time.sleep(0.1)
        for x in range(27, 36, 1):
            pixels[x] = (0, 128, 0)
            time.sleep(0.1)
        for x in range(36, 45, 1):
            pixels[x] = (0, 0, 255)
            time.sleep(0.1)
        for x in range(45, 54, 1):
            pixels[x] = (75, 0, 130)
            time.sleep(0.1)
        for x in range(54, 60, 1):
            pixels[x] = (128, 0, 255)
            time.sleep(0.1)
Thanks!
ghp
Re: Initializing variables in a class
Fri Jun 18, 2021 6:32 am
Python classes provide an __init__ method which is the 'constructor'. See https://docs.python.org/3/reference/dat ... t.__init__
For your code, it could look like this:
class LEDStrip:
    def __init__(self, pin, numPixels, brightness=0.2):
        self.numPixels = numPixels
        self.brightness = brightness
        self.pixels = neopixel.NeoPixel(pin, self.numPixels, self.brightness)
        self.pixels.fill((0, 0, 0))
        time.sleep(0.3)
pin and numpixels have no default values, as these are most possibly different when you attach a second LED strip.
in the class, as indicated for the turnOff-method, the pixels have to refer to the class field: self.pixels
Creating an instance of the class is like this:
ledStrip = LEDStrip(LED_STRIP_PIN, 60 )
or
ledStrip = LEDStrip(LED_STRIP_PIN, 60, 0.5 )
Gatsby25
Fri Jun 18, 2021 6:41 pm
class LEDStrip:
        time.sleep(0.3)
or
Thanks a lot! I will try that way now.
Gatsby25
Fri Jun 18, 2021 11:48 pm
class LEDStrip:
        time.sleep(0.3)
or
So I tried writing it that way, but I am getting this error: "__init__() takes 3 positional arguments but 4 were given" when I initialize it as "ledStrip = LEDStrip(LED_STRIP_PIN, 60)".
Gatsby25
Fri Jun 18, 2021 11:57 pm
My code:
# LEDStripClass.py
import time
import board
import neopixel
class LEDStrip:
    def __init__(self, pin, numPixels, brightnessValue):
        self.brightnessValue = brightnessValue
        self.pixels = neopixel.NeoPixel(pin, self.numPixels, self.brightnessValue)
    def turnOff(self):
        time.sleep(0.3)
    def turnRedOn(self):
        self.pixels.fill((255, 0, 0))
        time.sleep(0.3)
ledStrip = LEDStrip(board.D12, 60, 0.2)
try:
    while True:
        ledStrip.turnOff()
        time.sleep(0.5)
        ledStrip.turnRedOn()
        time.sleep(1)
except KeyboardInterrupt:
    ledStrip.turnOff()
The exact error in question:
  File "test.py", line 20, in <module>
  File "test.py", line 10, in __init__
TypeError: __init__() takes 3 positional arguments but 4 were given
cleverca22
Sat Jun 19, 2021 12:02 am
i think the problem is on this line
Gatsby25
Sat Jun 19, 2021 12:04 am
Yeah, trying to figure out how to fix it right now. Going crazy :lol:
cleverca22
Sat Jun 19, 2021 12:17 am
compare it to the original line you gave:
that has 2 positional arguments (plus the implied self), and one named argument
Gatsby25
Sat Jun 19, 2021 1:08 am
Hmm I will probably just stick to my original code. Still can't figure it out
cleverca22
Sat Jun 19, 2021 2:04 am
the key difference, is self.brightnessValue vs brightness=self.brightnessValue
https://treyhunner.com/2018/04/keyword- ... in-python/
Gatsby25
Sat Jun 19, 2021 2:55 am
Jeez it's really the minor things that get you. It works now. Thank you!
If I wanted the user to be able to configure red/green/blue intensity, I can just make separate functions that would return those values within the class right?
ghp
Sat Jun 19, 2021 7:34 am
right?
right !
Return to “Python”
