djblex
Python Issues : press a button to change the brightness on Waveshare 3.2C
Sun May 16, 2021 9:51 am
I am asking for your help because I have several problems. I'm starting with Python, my code isn't super clean :)
I have a Waveshare 3.2C, RPI 3A + screen under Retropie.
The objective of my code below is to change the screen brightness under Retropie when I press the screen push button (GPIO24) with 3 brightness values: 900, 350 and 150. (1024 being the max and 1 the minimum). The value ​​changes after each click of the button to switch from one value to another.
My problems are as follows:
1. The Python script takes 100% of the CPU, I don't know how to fix this.
2. Each time the GPIO24 button is clicked, the values ​​do not come out in order, I have to press 8 or 10 times for example to get the value 150 instead of clicking the button 3 times.
3. Under Retropie in a game, when I run gpio -g pwm 18 1024 from the shell, then gpio -g mode 18 pwm, the sound is cutted off, we can hear a big click in the speaker of the Headphone output. Then I type gpio pwmc 1000 and a big noizy sound appears.
Thank you very much for your help.
djblex
#!/usr/bin/env python2.7
import RPi.GPIO as GPIO
import time
import os
from time import sleep
import subprocess
btn = 24
# Pin Setup:
GPIO.setmode(GPIO.BCM) # Broadcom pin-numbering scheme
GPIO.setup(ledPin, GPIO.IN, pull_up_down=GPIO.PUD_UP) # Button pin set as input w/ pull-up
count = 0
isButtonPressed = False
while True:
    if GPIO.input(btn) == GPIO.LOW and isButtonPressed:
        time.sleep(0.1)
    elif GPIO.input(btn) == GPIO.HIGH and not isButtonPressed:
        isButtonPressed = True
        count += 1
        os.system('gpio -g mode 18 pwm')
        os.system('gpio -g pwm 18 900')
        os.system('gpio pwmc 0')
        time.sleep(0.1)
        print ("900b")
        time.sleep(0.1)
        count += 1
        os.system('gpio -g pwm 18 350')
        time.sleep(0.1)
        print ("350b")
        count += 1
        os.system('gpio -g pwm 18 150')
        time.sleep(0.1)
        print ("150b")
    GPIO.cleanup()
try:
	while True:
		# faites ce qui vous plait
		sleep (2)
# on reinitialise les ports GPIO en sortie de script
except KeyboardInterrupt:
    GPIO.cleanup()
GPIO.cleanup()
gordon77
Re: Python Issues : press a button to change the brightness on Waveshare 3.2C
Sun May 16, 2021 10:09 am
1. Put a time.sleep() in your while loop, try small values.
2. Try increasing your other time.sleep() values, could but button bounce
djblex
Sun May 16, 2021 6:04 pm
Thanks for your advices.
Unfortunately, I tried setting the time.sleep higher but it takes a bit longer for the processor to reach 100%.
I reworked the script a little cleaner but it's the same, the processor stays at 100% every time I do the command "gpio -g pwm" value "" in the script (triggered after each click on the button) .
The only way I have found is to place a "break" at the end of each command but the script no longer changes to another value when I click the button.
It would take a condition, but I don't know which one.
If you have any ideas :)
thank you
import time
import os
import subprocess
btn = 24
# Pin Setup:
GPIO.setup(btn, GPIO.IN, pull_up_down=GPIO.PUD_UP) # Button pin set as input w/ pull-up
def pwmMode():
    os.system('gpio -g mode 18 pwm &')
def pwm900v():
    os.system('gpio -g pwm 18 900 &')
def pwm350v():
    os.system('gpio -g pwm 18 350 &')
def pwm150v():
    os.system('gpio -g pwm 18 150 &')
def pwmc():
    os.system(['gpio pwmc 0 &'])
# notre fonction de gestion du bouton
def system_button(CHANNEL):
    # cette variable servira a stocker le temps de pression
    button_press_timer = 0
pwmMode()
count = 0
while True:
        time.sleep(0.01)
        count += 1
        pwm900v()
        print ("900b")
        time.sleep(0.01)
        count += 1
        pwm350v()
        print ("350b")
        time.sleep(0.01)
        count += 1
        pwm150v()
        print ("150b")
        time.sleep(0.01)
try:
	while True:
		sleep (2)
    GPIO.cleanup()
GPIO.cleanup()
gordon77
Sun May 16, 2021 6:36 pm
Try adding time.sleep here
while True:
time.sleep(0.1)
djblex
Sun May 16, 2021 7:34 pm
Thank you ,
it works for the Processor which stop beeing at 100%.
But now, each time i click on the button, i can't obtain the another value than 900b.
Alternatively, i should see printing values :
900b
350b
150b
900b
350b
150b
gordon77
Sun May 16, 2021 8:09 pm
You have 3 lines of elif GPIO.input(btn) == GPIO.HIGH and not isButtonPressed:
It's only ever going to choose the first one...
gordon77
Sun May 16, 2021 8:15 pm
Try this ...
import time
import os
import subprocess
btn = 24
Value = 150
# Pin Setup:
def pwmMode():
def pwm900v():
def pwm350v():
def pwm150v():
def pwmc():
pwmMode()
count = 0
while True:
    time.sleep(0.1)
        time.sleep(0.01)
    elif GPIO.input(btn) == GPIO.HIGH and not isButtonPressed and Value == 150:
        count += 1
        Value = 900
        pwm900v()
        print ("900b")
        time.sleep(0.2)
    elif GPIO.input(btn) == GPIO.HIGH and not isButtonPressed and Value == 900:
        count += 1
        Value =350
        pwm350v()
        print ("350b")
        time.sleep(0.2)
    elif GPIO.input(btn) == GPIO.HIGH and not isButtonPressed and Value == 350:
        count += 1
        Value = 150
        pwm150v()
        print ("150b")
        time.sleep(0.2)
try:
	while True:
		sleep (2)
    GPIO.cleanup()
GPIO.cleanup()
[/quote]
ghp
Sun May 16, 2021 8:21 pm
Let me propose this solution
It separates the detection and debouncing of the button from the other code. A queue is used to send events from the ButtonDebounce class to the main loop.
In the main loop, a state is used to track the brightness levels.
Why do you use the os calls ? You could solve this with rpi.gpio pwm calls also.
Switch to python3. Python2 is obsolete.
#!/usr/bin/env python3
import os
import queue
import subprocess
import sys
import threading
import time
assert sys.version_info >= (3, 7)
btn = 24
debug = True
# Pin Setup:
class ButtonDebounce:
    def __init__(self, btn, event_queue):
        self.btn = btn
        GPIO.setup(self.btn, GPIO.IN, pull_up_down=GPIO.PUD_UP) # Button pin set as input w/ pull-up
        self.event_queue = event_queue
        self.thread = threading.Thread(target=self._run)
        self.thread.start()
    def _run(self):
        """debounce the button and send events to a queue"""
        print("_run")
        high_count = 0
        low_count = 0
        while True:
            time.sleep(0.01)
            if GPIO.input(self.btn) == GPIO.LOW:
                low_count += 1
                high_count = 0
            if GPIO.input(self.btn) == GPIO.HIGH:
                low_count = 0
                high_count += 1
            # print(low_count, high_count)
            if high_count == 10:
                self.event_queue.put("high")
            if low_count == 10:
                self.event_queue.put("low")
event_queue = queue.Queue()
button_debounce = ButtonDebounce( btn, event_queue)
def pwmMode():
    cmd = "gpio -g mode 18 pwm &"
    if debug: print( cmd)
    else:
        """why not execute this os call by a RPI GPIO command ? """
        os.system(cmd)
def pwm900v():
    cmd = "gpio -g pwm 18 900 &"
    else:   os.system(cmd)
def pwm350v():
    cmd = "gpio -g pwm 18 350 &"
def pwm150v():
    cmd = "gpio -g pwm 18 150 &"
def pwmc():
    cmd = "gpio pwmc 0 &"
pwmMode() # ???
count = 0
OFF = "OFF"
LOW = "LOW"
MEDIUM = "MEDIUM"
HIGH = "HIGH"
pwmc()
state = OFF
try:
    while True:
        event = event_queue.get()
        if state == OFF:
            if event == 'high':
                pwm150v()
                state = LOW
        elif state == LOW:
            if event == 'high':
                pwm350v()
                state = MEDIUM
        elif state == MEDIUM:
            if event == 'high':
                pwm900v()
                state = HIGH
        elif state == HIGH:
            if event == 'high':
                pwm150v()
                state = LOW
    GPIO.cleanup()
GPIO.cleanup()
djblex
Sun May 16, 2021 8:35 pm
yeahhh thank you !!! almost done :)
i have two values in alternate. i don't know why the 150b do not appears !
gordon77
Sun May 16, 2021 8:36 pm
Try my code again, fixed hopefully
djblex
Sun May 16, 2021 8:41 pm
My answer below was for you gordon77 :)
gordon77
Sun May 16, 2021 8:42 pm
I know, l replied..
import time
import os
import subprocess
btn = 24
Value = 150
# Pin Setup:
def pwmMode():
def pwm900v():
def pwm350v():
def pwm150v():
def pwmc():
pwmMode()
count = 0
while True:
    time.sleep(0.1)
        time.sleep(0.01)
        count += 1
        Value = 900
        pwm900v()
        print ("900b")
        time.sleep(0.2)
        count += 1
        Value =350
        pwm350v()
        print ("350b")
        time.sleep(0.2)
        count += 1
        Value = 150
        pwm150v()
        print ("150b")
        time.sleep(0.2)
try:
	while True:
		sleep (2)
    GPIO.cleanup()
GPIO.cleanup()
djblex
Sun May 16, 2021 8:48 pm
For Ghp and Gordon77,
i am really a beginner in python language.
Thanks both for your advices and codes, i will try your script too (Ghp) , i need to install python 3. i will make a reply
ghp
Sun May 16, 2021 8:51 pm
in a current "pi raspbian" aka "pi os", python3 is available.
djblex
Mon May 17, 2021 12:14 pm
For Ghp,
I tried your code in changing import queue and assert... for it runs.
The Print Values change really well but there are no action brigtness changement as if my Def do not work.
And i can not exit the script with keyboard (ctrl +c)
Sorry for my lack of knowledge and thank for you help :)
import os
#import queue
import Queue as queue
import subprocess
import sys
import threading
import time
#assert sys.version_info >= (3, 7)
assert sys.version_info >= (3)
btn = 24
debug = True
# Pin Setup:
        self.btn = btn
        self.thread.start()
    def _run(self):
        print("_run")
        high_count = 0
        low_count = 0
        while True:
            time.sleep(0.01)
                low_count += 1
                high_count = 0
                low_count = 0
                high_count += 1
            if low_count == 10:
def pwmMode():
    else:
        os.system(cmd)
def pwm900v():
def pwm350v():
def pwm150v():
def pwmc():
pwmMode() # ???
count = 0
OFF = "OFF"
LOW = "LOW"
MEDIUM = "MEDIUM"
HIGH = "HIGH"
pwmc()
state = OFF
try:
    while True:
        if state == OFF:
            if event == 'high':
                pwm150v()
                state = LOW
        elif state == LOW:
            if event == 'high':
                pwm350v()
                state = MEDIUM
            if event == 'high':
                pwm900v()
                state = HIGH
        elif state == HIGH:
            if event == 'high':
                pwm150v()
                state = LOW
    GPIO.cleanup()
GPIO.cleanup()
ghp
Mon May 17, 2021 12:31 pm
debug = True # <<< change to False !
def pwm350v():
gordon77
Mon May 17, 2021 1:15 pm
is this a bit simpler to get you started...
import time
import os
btn = 24
# Pin Setup:
GPIO.setwarnings(False)
GPIO.setup(18, GPIO.OUT)
pwm = GPIO.PWM(18, 100)
pwm.start(20)
count = 0
while True:
    sleep(0.1)
    if GPIO.input(btn) == GPIO.LOW:
        count += 20
        if count > 100:
            count = 20
        print (count)
        pwm.ChangeDutyCycle(count)
        sleep(0.2)
try:
    while True:
        sleep(2)
    GPIO.cleanup()
GPIO.cleanup()
djblex
Mon May 17, 2021 7:58 pm
Thanks to you both,
your scripts are excellent and i'm learning thanks to you :).
Your last Gordon77 script solves the 3 problems:
1. The Python script is taking 100% of the CPU, I don't know how to fix this problem: SOLVED
2. Each time we click on the GPIO24 button, the values ​​do not come out in order, I have to press 8 or 10 times for example to get the value 150 instead of clicking 3 times on the button: SOLVED
3. Under Retropie in a game, when I run gpio -g pwm 18 1024 from the shell, then gpio -g mode 18 pwm, the sound is muted, we can hear a big click in the speaker of the headphone output. Then I type gpio pwmc 1000 and a big noizy sound appears: SOLVED
I can change the brightness in playing games without cutting off sound or hearing clicks or bizarre Sounds
Thank you for your work :)
Return to “Python”
