ancris00
Program to take pictures of the intruder does not work
Fri May 14, 2021 8:54 pm
Hi all,
I have a sensor (PIR) connected to pin 17
and a relay in pin 27
When motion is detected the program switchs on the relay (supplying energy to a pair of torches)
and ideally, the program starts to take pictures of the thief, but only takes one, why?
from gpiozero import MotionSensor
from gpiozero import LED
from picamera import PiCamera
from datetime import datetime
pir = MotionSensor(17)
relay = LED (27)
camera = PiCamera()
camera.rotation = 180
camera.resolution = (640, 480)
timestamp = datetime.now().isoformat()
while True:
	pir.wait_for_motion()
	relay.on()
	camera.capture('/home/pi/%s.jpg' % timestamp)
	pir.wait_for_no_motion()
	relay.off()
when I move I can listen to the relay switching on and off
please help
:lol: :lol: Pi 4 Model B :lol: :lol:
Raspbian Buster with desktop 4.19
topguy
Re: Program to take pictures of the intruder does not work
Fri May 14, 2021 9:31 pm
You dont update the "timestamp" value in the loop, its just writing the same filename over and over...
ancris00
Sat May 15, 2021 9:36 am
Shall I put this line
inside the loop as well ?
B.Goode
Sat May 15, 2021 12:37 pm
It doesn't need to be 'as well'.
Just inside the loop. Prior to using it to construct the filename. After the wait_for_motion delay is triggered seems a sensible choice.
ancris00
Sat May 15, 2021 1:59 pm
It works! thanks
Return to “Python”
