PinkusJ
RPIO.GPIO does not work when ran from crontab
Sun May 09, 2021 7:49 pm
When I try running a simple script involving the RPi.GPIO module from Thonny IDE or the command line, it works just fine. However, when I try to run it from a crontab, it gives the following error:
  File "/home/pi/Desktop/CanSat/Code/master.py", line 2, in <module>
    import RPi.GPIO as GPIO
  File "/usr/local/lib/python3.7/dist-packages/RPi/GPIO/__init__.py", line 23, in <module>
    from RPi._GPIO import *
RuntimeError: This module can only be run on a Raspberry Pi!
I edited the crontab via "sudo crontab -e" and the crontab instructions are:
PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin
@reboot sleep 30  &&  python3 /path/to/file.py >> /path/to/error_log/ 2>&1
Any ideas as to why this might occur? I tried similar online questions and none of them seemed to work in this case!
Gavinmc42
Re: RPIO.GPIO does not work when ran from crontab
Mon May 10, 2021 2:14 am
I think I remember crontab being very picky about paths, you need to put in the full path name for the file.
"/home pi/....py"
I'm dancing on Rainbows.
MiscBits
Mon May 10, 2021 3:20 am
This is incorrect:
Cron jobs must start with a time structure and not the PATH option.
Unless you where running the command line version under SUDO, then you should be using the user crontab not the root one.
The 'RuntimeError: This module can only be run on a Raspberry Pi!' error if often seen when using older versions - it's possible that the root version and user version is different. Did you load one as sudo and one as the normal user?
I normally create a short shell script to set up any environment and call that from cron if needed and in this case it would be the path, sleep and python commands.
Is a computer language with goto's totally Wirth-less?
Gavinmc42
Mon May 10, 2021 3:35 am
SHELL=/bin/sh
PATH=/sbin/:/bin:/usr/sbin:/usr/bin
* * * * * TZ=EST-10 /home/tc/fridgealarm.sh >> /var/log/error.log
This is what I have in one of mine that has been running for years.
That is the default for running every minute.
By default it uses UTC, that why the timezone is in there.
SurferTim
Tue May 11, 2021 9:45 am
The last time I saw this message was when the user was not a member of the gpio group.
I haven't used crontab in a while so I'm not certain what user it runs as. On the RPi, it appears user root is not a member of the gpio group.
sudo groups
You can apparently assign the user with this. I haven't tried it.
sudo crontab -u pi -e
My advice applies to RaspiOS only. Please mention if you use another OS.
neilgl
Tue May 11, 2021 10:42 am
You want to use the pi user crontab via crontab -e, not root’s crontab via sudo crontab -e
This works for me in pi crontab:
@reboot python3 -u /home/pi/scripts/neo.py >> /home/pi/scripts/neo.log 2>&1
Return to “Python”
