TimWardCam
blinka installation hangs?
Fri May 07, 2021 5:33 pm
This script configures your
Raspberry Pi and installs Blinka
RASPBERRY_PI_4B detected.
Blinka WARNING Default System python version is 2.7.16. It will be updated to Version 3.
Continue? [y/n] y
Updating System Packages
Blinka Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Blinka Get:2 http://archive.raspberrypi.org/debian buster InRelease [32.9 kB]
Blinka Get:3 http://archive.raspberrypi.org/debian buster/main armhf Packages [375 kB]
Blinka Fetched 423 kB in 1s (381 kB/s)
Blinka Reading package lists...
Upgrading packages...
This seems to be sitting there forever rather than the "few minutes" advertised here https://learn.adafruit.com/circuitpytho ... spberry-pi
It worked last time I tried it on a different Pi.
Any ideas? Kill and re-run? Throw away the SD card and start again?
TimWardCam
Re: blinka installation hangs?
Fri May 07, 2021 6:51 pm
Killed it and restarted it. It appeared to work the second time.
Sooo tedious. Yes I know it's difficult to code around all possible network glitches and suchlike, but those of us of a certain age know that, to do something properly, whilst 95% of the work is in the error handling, it is also the case that 95% of the value is in the error handling.
Return to “Python”
