JanvE
Datetime issue
Wed May 05, 2021 5:19 pm
Dear all,
As a starter with Python I have the following issue.
Running this program results in:
d=datetime.datetime.strptime(tijd,'%H:%M')
AttributeError: type object 'datetime.datetime' has no attribute 'datetime'
I think that is has something to do with the import but I don't know what.
I hope that some can help me out here.
Thank you,
Jan van Eeden
Netherlands
 from datetime import datetime, timedelta
from datetime import *
tomorrow = datetime.now() + timedelta(days=+1)
tomorrow_formatted = tomorrow.strftime('%-d-%m-%y')
dnow=datetime.datetime.now()
print(tomorrow_formatted)
print (dnow)
SurferTim
Re: Datetime issue
Wed May 05, 2021 5:40 pm
This runs ok. Couldn't figure out what "tijd" is.
#!/usr/bin/env python3
#d=datetime.datetime.strptime(tijd,'%H:%M')
dnow=datetime.now()
print (dnow)
My advice applies to RaspiOS only. Please mention if you use another OS.
JanvE
Re: Datetime issue
Wed May 05, 2021 5:50 pm
Thank you very much Surfer Tim!
kheylen25
Re: Datetime issue
Wed May 05, 2021 6:29 pm
"tijd" is just a variable, which we don't know where it comes from, maybe from user input. Running only this snippet would result in an error as it is not declared. Try this code to convert to and back from datetime objects:
tijd = '11:45'
d = datetime.strptime(tijd,'%H:%M')
print(d)         # prints 1900-01-01 11:45:00
print(type(d))   # prints <class 'datetime.datetime'>
again_to_string = datetime.strftime(d, '%H:%M')
print(again_to_string)          # prints 11:45
print(type(again_to_string))    # prints <class 'str'>
Also, (they say that) it's good practice to store dates and times as datetime objects, as you can do all kind of calculations with it. Only convert to string when printing.
For timedelta objects, there's no need to add the plus sign, as you are just assigning a value to a keyword argument.
tomorrow = datetime.now() + timedelta(days=1)
print(tomorrow.strftime('%d-%m-%Y  %H:%M'))
(edit: forgot to import timedelta on second example)
Return to “Python”
