GarraTheWinnie
Highest absolute Value in a Dictionary
Wed Apr 14, 2021 3:36 pm
Hey everyone,
I am trying to get the highest absolute value from a dictionary similar to this:
cVal = {'r'=50, 'b'=-55, c=40}
in this case it will be 55
This is how I figured it out
maxVal = abs(cVal[max(cVal, key = lambda y: abs(cVal[y]))])
but that seems to be kinda redundant. I have to iterate through the dictionary twice, and use abs twice.
anyone have a any idea how to make this a little cleaner?
robbes
Re: Highest absolute Value in a Dictionary
Wed Apr 14, 2021 4:12 pm
If you don't need to know the key, you could do something like this:
maxval = max([abs(x) for x in mydict.values()])
GarraTheWinnie
Wed Apr 14, 2021 4:21 pm
Spot on! thank you so much!
scruss
Wed Apr 14, 2021 6:51 pm
From the TIMTOWTDI-EIP¹ department, but with a temporary dictionary:
>>> cVal = {'r':50, 'b':-55, 'c':40}
>>> absVal={abs(x):x for x in cVal.values()}
>>> absVal[max(absVal.keys())]
-55
You might want the sign returned intact, as if you're making control decisions on the value (temperature, say) it really, really matters whether it's -55 °C or 55 °C
There has to be a way to do it without a temporary dict, but it might not be too understandable.
¹: There Is More Than One Way To Do It — Even In Python
Pronouns: he/him
twostage
Thu Apr 15, 2021 4:40 pm
How about...
sorted(list(cVal.values()))[-1]
for signed. I'll have a think about an abs version.
scruss
Thu Apr 15, 2021 10:45 pm
The abs is the important bit. You could just do 'max(list(cVal.values()))' if you didn't need that
Pronouns: he/him
MiscBits
Thu Apr 15, 2021 10:50 pm
How about:
c = {'r':50, 'b':-55, 'c':40}
max(abs(c[max(c)]),abs(c[min(c)]))
Messy and a pain to type on an iPad :D
A more English walkthrough is:
a) Find the key with max value - max(c)
b) Find its value - c[]
c) Find the absolute value
d) Repeat for min
e) Find the max of those two
Note this does loose the sign but that was acceptable in the OPs request...
twostage
Fri Apr 16, 2021 9:13 am
How about...
Oops, that returns the smallest, should have been a zero not -1.
Interesting challenge.
Fri Apr 16, 2021 9:52 am
One thing I have always wondered about with Python - lots of ways to do things, some more or less readable than others, but which is the most efficient? Would simply looping through all the keys manually with a for be faster than some of the more esoteric ways of doing it?
Working in the Application's Team.
twostage
Sat Apr 17, 2021 10:05 am
I know what you mean. Sometimes doing it the simplest but possibly most CPU intensive is best.
I've made a few rpi zero clocks recently using neopixels and scrollphats. My initial attempt at coding I calculated what should be on/off/What colour/how bright at start-up, then work out how it changes every second/minute/hour and do the updates. Eventually realised it was far easier to calculate everything every second (or every tenth of a second in one case).
scruss
Sat Apr 17, 2021 6:43 pm
There should be one-- and preferably only one --obvious way to do it.” in Python, which is obviously bunk. The best way is the one you understand how to write and works (for your current personal definition of 'works'). There's probably a clever and complete algorithm that does this, but the amount of time it would take to find it and get it in your code would be too long. For three entries, any solution will take almost no time. If there are millions of entries? Maybe a more efficient algorithm is called for - until your computer is replaced by something that does it in trivial time.
Pronouns: he/him
Return to “Python”
