I tried the shutdown and it works for me.
Have you checked where and how it's connected ?
I meant it wouldn't shutdown whilst waiting for the coinslot
#!/usr/bin/env python3
import RPi.GPIO as GPIO
import glob
import subprocess
import os, signal
import time
# define GPIO pins used, first 10 for letters, second 10 for numbers
pins = (7,10,15,16,18,19,21,22,23,24,26,29,31,32,33,35,36,37,38,40)
# buttons
stop = 8
shutdown = 11
coinslot = 13
# LEDS
LED1 = 12
LED2 = 5
# define letters
letters = ("A","B","C","D","E","F","G","H","I","J")
# setup GPIO
GPIO.setmode(GPIO.BOARD)
GPIO.setwarnings(False)
for count in range(0,len(pins)):
GPIO.setup(pins[count],GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(stop,GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(shutdown,GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(coinslot,GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(LED1,GPIO.OUT)
GPIO.setup(LED2,GPIO.OUT)
GPIO.output(LED1,GPIO.HIGH) # turn LED1 ON
GPIO.output(LED2,GPIO.LOW) # turn LED2 OFF
# find tracks
tracks = glob.glob("/home/pi/Music/*.mp3")
tracks.sort()
# set starting variables
X = -1
Y = -1
coin_det = 0
time_start = 0
start = 0
while True:
# wait for a coin
while GPIO.input(coinslot) == 1 and coin_det == 0:
time.sleep (.25)
if GPIO.input(shutdown) == 0:
os.system("sudo shutdown -h now")
# coin detected, start timer
if coin_det == 0:
print ("Coin detected")
time_start = time.time()
GPIO.output(LED2,GPIO.HIGH) # turn LED2 ON
coin_det = 1
# if no activity for 60 seconds, cancel coin detected
if time.time() - time_start > 60 and X == -1:
coin_det = 0
print ("Sorry timed out, insert another coin !")
time.sleep(0.1)
print ("Goodbye!")
# check for a letter press
if X == -1 and coin_det == 1:
for A in range(0,int(len(pins)/2)):
if GPIO.input(pins[A])== 0:
X = A
start = time.time()
print ("Letter pressed")
# no number pressed within 5 seconds of a letter, cancel letter
if X != -1 and time.time() - start > 5:
X = -1
print ("Timed out waiting for a number, choose again")
# no letter pressed within 5 seconds of a number, cancel number
if Y != -1 and time.time() - start > 5:
Y = -1
print ("Timed out waiting for a letter, choose again")
# check for a number press
if Y == -1 and coin_det == 1:
for B in range(int(len(pins)/2),len(pins)):
if GPIO.input(pins[B])== 0:
Y = (B - int(len(pins)/2))
start = time.time()
print ("Number pressed")
# if letter AND number pressed play a song
if X > -1 and Y > -1:
# calculate track number from letter and number pressed
Z = 10 * X + Y
if Z < len(tracks):
print ("Playing Track: ", letters[X] + str(Y+1), tracks[Z] )
rpistr = "mplayer " + '"' + tracks[Z] + '"'
p = subprocess.Popen(rpistr, shell=True, preexec_fn=os.setsid)
# check if track still playing
poll = p.poll()
while poll == None: # track still playing
time.sleep(1)
if GPIO.input(stop) == 0:
print ("Track stopped")
os.killpg(p.pid, signal.SIGTERM)
GPIO.output(LED1,GPIO.LOW) # turn LED1 OFF
print ("Goodbye!")
poll = p.poll()
print ("Stopped Playing")
coin_det = 0
X = -1
Y = -1
print ("Insert another coin")
else:
print ("No track found")
coin_det = 0
X = -1
Y = -1
import glob
import subprocess
import os, signal
import time
# buttons
stop = 8
shutdown = 11
coinslot = 13
# LEDS
LED1 = 12
LED2 = 5
# define letters
# setup GPIO
# find tracks
tracks.sort()
X = -1
Y = -1
coin_det = 0
time_start = 0
start = 0
while True:
# wait for a coin
time.sleep (.25)
if coin_det == 0:
coin_det = 1
coin_det = 0
time.sleep(0.1)
print ("Goodbye!")
X = A
start = time.time()
X = -1
Y = -1
start = time.time()
Z = 10 * X + Y
if Z < len(tracks):
poll = p.poll()
time.sleep(1)
print ("Goodbye!")
poll = p.poll()
coin_det = 0
X = -1
Y = -1
else:
coin_det = 0
X = -1
Y = -1
import glob
import subprocess
import os, signal
import time
import random
from random import shuffle
# shuffle tracks played in continuous mode, set to 1 to shuffle
con_shuffle = 0
# buttons
stop = 8
shutdown = 11
coinslot = 13
# LEDS
LED1 = 12
LED2 = 5
# define letters
# setup GPIO
# find tracks
tracks.sort()
X = -1
Y = -1
coin_det = 0
time_start = 0
start = 0
B_pressed = 0
Con_Play = 0
while True:
# wait for a coin
time.sleep (.25)
if coin_det == 0:
coin_det = 1
coin_det = 0
time.sleep(0.1)
print ("Goodbye!")
X = A
start = time.time()
if X == 1:
print ("B Pressed")
B_pressed = 1
if GPIO.input(pins[1]) == 1 and B_pressed == 1:
B_pressed = 0
print ("B Released")
# or continuous play mode if B pressed for > 5 seconds
if B_pressed == 0:
X = -1
else:
print ("B Pressed > 5 secs")
Con_Play = 1
Y = -1
start = time.time()
Z = 10 * X + Y
if Z < len(tracks):
poll = p.poll()
time.sleep(1)
print ("Goodbye!")
poll = p.poll()
coin_det = 0
X = -1
Y = -1
else:
coin_det = 0
X = -1
Y = -1
# Con_Play = 1 so continuous play mode...
if Con_Play == 1:
# shuffle tracks, if selected.
nums = [0] * len(tracks)
for q in range(0,len(tracks)):
nums[q] = q
if con_shuffle == 1:
print ("Shuffled tracks")
shuffle(nums)
Z = 0
while Z < len(tracks) :
print ("Playing Track: ",str(Z+1),"of",str(len(tracks)), tracks[nums[Z]] )
rpistr = "mplayer " + '"' + tracks[nums[Z]] + '"'
poll = p.poll()
#GPIO.output(LED1,GPIO.HIGH)
time.sleep(0.5)
#GPIO.output(LED1,GPIO.LOW)
time.sleep(0.5)
if GPIO.input(pins[2]) == 0: # Next Track (C pressed)
print ("Next Track...")
time.sleep(0.5)
if GPIO.input(pins[0]) == 0: # Previous track (A pressed)
print ("Previous Track...")
time.sleep(0.5)
Z -= 2
if Z < -1:
Z = -1
if GPIO.input(stop) == 0: # Exiting Continuous Play (if STOP pressed > 5 secs)
timer1 = time.time()
while GPIO.input(stop) == 0:
if time.time() - timer1 > 5:
if Con_Play == 1:
Con_Play == 0
Z = len(tracks)
print ("Exiting Continuous Play...")
if GPIO.input(shutdown) == 0: # shutdown
print ("Goodbye!")
poll = p.poll()
Z += 1
print ("Stopped Continuous Playing, all tracks played")
B_pressed = 0
Con_Play = 0
coin_det = 0
X = -1
Y = -1
import glob
import subprocess
import os, signal
import time
import random
con_shuffle = 0
# buttons
stop = 8
shutdown = 11
coinslot = 13
# LEDS
LED1 = 12
LED2 = 5
# define letters
# setup GPIO
# find tracks
tracks.sort()
X = -1
Y = -1
coin_det = 0
time_start = 0
start = 0
B_pressed = 0
Con_Play = 0
while True:
# wait for a coin
time.sleep (.25)
if coin_det == 0:
coin_det = 1
coin_det = 0
time.sleep(0.1)
print ("Goodbye!")
X = A
start = time.time()
if X == 1:
print ("B Pressed")
B_pressed = 1
B_pressed = 0
if B_pressed == 0:
X = -1
else:
Con_Play = 1
Y = -1
start = time.time()
Z = 10 * X + Y
if Z < len(tracks):
poll = p.poll()
time.sleep(1)
print ("Goodbye!")
poll = p.poll()
coin_det = 0
X = -1
Y = -1
else:
coin_det = 0
X = -1
Y = -1
if Con_Play == 1:
nums[q] = q
shuffle(nums)
Z = 0
poll = p.poll()
time.sleep(0.5)
time.sleep(0.5)
time.sleep(0.5)
Z -= 2
if Z < -1:
Z = -1
if GPIO.input(pins[4]) == 0: # 10 Track Fwd (E pressed)
print ("Skip 10 Track forward...")
time.sleep(0.5)
if len(tracks) - Z > 10:
Z += 9
else:
Z = len(tracks) - 2
if GPIO.input(pins[3]) == 0: # 10 Track Back (D pressed)
print ("Skip 10 Track backwards...")
time.sleep(0.5)
Z -= 11
if Z < -1:
Z = -1
if Con_Play == 1:
Con_Play == 0
Z = len(tracks)
print ("Goodbye!")
poll = p.poll()
Z += 1
B_pressed = 0
Con_Play = 0
coin_det = 0
X = -1
Y = -1
What doesn't work ? It's the same code with the latest addition to play continuously.
The github is the last one on here modified for your request to play continuously until stopped. I also added the option to disable the coinslot in case anyone wants to use it without this. The latest version will always be on github.ikn wrote: ↑Tue Jul 28, 2020 6:29 pmIf you have tried the new code and it works, then there might be a fault with my buttons.
You've made several edits on the forum. It's a little difficult to keep up and remember which code did what. I'm not sure which one of your codes has been edited on github.
I have my Pi inside my music player which needs to be opened up to connect mouse , keyboard and tv in order to change codes. I put an old code back in it and all buttons work with that. When I get a chance to open up the music player, I will download the github code again and try the buttons again.
Z +=9
if Z > len(tracks):
Z = Z - len(tracks)
