goodcop911
countdown date helpme pleeeez
Sat May 23, 2020 3:23 pm
I'm a beginner coder in python I'm trying to loop my program that counts down to a specific date June 4th 2020
how do I loop this program:
from datetime import datetime
futuredate = datetime.strptime('Jun 4 2020 13:33', '%b %d %Y %H:%M')
nowdate = datetime.now()
count = int((futuredate-nowdate).total_seconds())
days = count//86400
hours = (count-days*86400)//3600
minutes = (count-days*86400-hours*3600)//60
seconds = count-days*86400-hours*3600-minutes*60
print("{} days {} hours {} minutes {} seconds left".format(days, hours, minutes, seconds))
lugee
Re: countdown date helpme pleeeez
Sat May 23, 2020 4:09 pm
Sat May 23, 2020 4:28 pm
You can do maths on a datetime object to find the time difference.
You can turn a datatime difference into the number of seconds between now and the target date.
If you modulo divide that by 86400 the integer result is the number of days.
If you modulo divide that remainder by 3600 the integer result is the number of hours.
If you modulo divide that remainder by 60 the integer result is number of minutes, the remainder is number of seconds.
I've wrapped some TKinter controls round it to make it a nice friendly pop-up window.
#!/usr/bin/python3
import tkinter as tk
import tkinter.messagebox
class Application(tk.Frame):
    end_date = datetime.strptime('Jun 4 2020 13:33', '%b %d %Y %H:%M')
    def __init__(self, master, *args, **kwargs):
        tk.Frame.__init__(self, master, *args, **kwargs)
        self.master = master
        self.build_interface()
    def build_interface(self):
        self.clock = tk.Label(self, text="00 00:00:00", font=("Courier", 20), width=13)
        self.clock.grid(row=1, column=1, stick="S")
        self.time_label = tk.Label(self, text="days hours mins secs", font=("Courier", 10), width=20)
        self.time_label.grid(row=2, column=1, sticky="N")
        self.timer()
    def calculate(self):
        self.days = divmod(self.seconds_left, 86400)
        self.hours = divmod(self.days[1], 3600)
        self.mins = divmod(self.hours[1], 60)
        self.secs = int(self.mins[1])
        return "{:02} {:02d}:{:02d}:{:02d}".format(int(self.days[0]), int(self.hours[0]), int(self.mins[0]), self.secs)
    def timer(self):
        self.now = datetime.now()
        self.seconds_left = (self.end_date - self.now).total_seconds()
        if self.seconds_left <= 0:
                self.clock.configure(text="Time's up!")
        else:
                self.clock.configure(text=self.calculate())
                self.after(1000, self.timer)
if __name__ == "__main__":
    root = tk.Tk()
    root.title("TIMER")
    Application(root).pack(side="top", fill="both", expand=True)
    root.mainloop()
Return to “Python”
