jadro
Self restart Python script
Wed Aug 09, 2017 1:31 pm
Can I restart Python script from same script with Python code and how if yes?
If I have a.py started, can I have if state to restart (kill and start again) same a.py script?
Thanx,
Jadro
Oracle backend database developer
SmartHome IoT & Microprocessor enthusiast and hobbyist
Tyrael_Archangel
Re: Self restart Python script
Wed Aug 09, 2017 2:15 pm
you can use something like this to restart a python script from within itself
os.execv('/AbsolutePathtoScript/a.py', lst_args)
I use this within a script that handles upgrading the rest of my code to restart itself if it needs to upgrade itself.
jadro
Wed Aug 09, 2017 2:25 pm
thanx, I will try this solution.
Jadro
jadro
Wed Aug 09, 2017 2:53 pm
I try this:
import os
os.execv('/home/pi/myFolder/RestartMySelf.py', [''])
and get error:
SError: [Errno 13] Permission denied
I dont need any permission to that script
Paeryn
Wed Aug 09, 2017 4:01 pm
I try this:
import os
and get error:
Did you set the execute permission bit for /home/pi/myFolder/RestartMySelf.py?
chmod +x /home/pi/myFolder/RestartMySelf.py
She who travels light — forgot something.
Tyrael_Archangel
Wed Aug 09, 2017 5:00 pm
you may also need to add
#!/usr/bin/python
to the very top of your script (first line), I can't remember if this is required or not for it to work but it can't hurt
Paeryn
Wed Aug 09, 2017 5:17 pm
#!/usr/bin/python
Yes it is. If the program isn't a binary executable then you need a shebang line at the top so the system knows what interpreter to run.
Martin Frezman
Wed Aug 09, 2017 5:51 pm
#!/usr/bin/python
It is only required *if* you intend to run your script "directly".
The way I read the most recent post(s) from the OP, it looks like he may have been used to running the script via a command line like: $ python3 /path/to/my/script.py
which, of course, works fine. But then when he tries to run it with the os.execv() thing, he left out the leading "python3". Thus the confusion...
If this post appears in the wrong forums category, my apologies.
jadro
Wed Aug 09, 2017 6:56 pm
I add #!/usr/bin/python
and put my script in this folder /home/pi/myPiConfig/Test/restartMySelf.py
and also add chmod +x /home/pi/myPiConfig/Test/restartMySelf.py
and now it works but with error: Quit with error [Errno 2] No such file or directory !!!!!!! Why?!?!?! This is my directory!!!
This is my code:
#!/usr/bin/python
import os
import time
try:
    while True:
            print "wait for 5 sec..."
            time.sleep(5)
            print "Restarting..."
            os.execv('/home/pi/myPiConfig/Test/restartMySelf.py',  [''])
except KeyboardInterrupt:
    print " Quit"
except Exception as e:
    print " Quit with error " + str(e)
Paeryn
Wed Aug 09, 2017 8:29 pm
This is my code:
#!/usr/bin/python
import os
import time
try:
    while True:
            time.sleep(5)
    print " Quit"
Have you got the filename / path correct including capitalisation? Your earlier post referred to the filename as RestartMySelf.py and now you refer to it as restartMySelf.py
jadro
Wed Aug 09, 2017 9:43 pm
I change the file name when create a new test map. And yes, i copy paste whole path from folder explorer and it does not working. I replace first latter from name and now it is restartMySelf.py
jadro
Fri Aug 11, 2017 10:30 am
Here is my code that restarts but when restart it does not print any line of printable string:
#!/usr/bin/python
import os
import time
import sys
print "Here I'am"
print os.path.abspath(__file__)
try:
    while True:
            time.sleep(5)
           # os.execv('/home/pi/myPiConfig/Test/restartMySelf.py',  [''])
            os.execv(sys.executable, [sys.executable] +  ['restartMySelf'])
    print " Quit"
Result is this:
Python 2.7.9 (default, Sep 17 2016, 20:26:04)
[GCC 4.9.2] on linux2
Type "copyright", "credits" or "license()" for more information.
>>> ================================ RESTART ================================
Here I'am
wait for 5 sec...
Restarting...
and no message is here like Here I'am or so...
Why?
Thanx,
Jadro
Paeryn
Fri Aug 11, 2017 11:33 am
That looks like you're running it from within IDLE. If so then it more than likely isn't working due to how IDLE runs the interpreter. The moment you replace the executable when calling execv() you loose the connection it had to IDLE and the window.
jadro
Fri Aug 11, 2017 11:39 am
Yes, it runs from IDLE for now.
How to do this in IDLE to show print message again within this self script?
How to cll this script right way?
Paeryn
Fri Aug 11, 2017 11:51 am
I don't think you can force a restart like that under IDLE as you have no way of inserting the hooks that IDLE needs.
Do you really need to reload your program from scratch rather than having a controlled loop?
jadro
Fri Aug 11, 2017 11:55 am
Good question... maybe in some situations...
Thanx for the answers.
Jadro
thegripmaster
Sun Jul 21, 2019 4:03 pm
#!/usr/bin/env python3
import sys
import subprocess
#import time
#time.sleep(1)
print("now going to run myself again")
subprocess.call(sys.argv[0], shell=True)
hippy
Sun Jul 21, 2019 8:20 pm
The easiest way I found to do it was to run the Python code from within a shell script which just re-runs the Python code if it had created a 'run me again' file. Python creates the file and then terminates itself, deletes it as soon as it's running.
But that won't work under IDLE.
Return to “Python”
