Jpanu
wxwidgets and python 3.
Fri Jan 11, 2019 4:28 pm
Hello all.
I installed from repos wx2.8, and it is working on 2.x python. But not on 3.x (3.0/3.4).
Then i tried to pip3 install wxpython, which starts to install, but always crashes to :"No package 'gtk+-3.0' found
no
*** Could not run GTK+ test program, checking why...
*** The test program failed to compile or link. See the file config.log for the
*** exact error that occured. This usually means GTK+ is incorrectly installed.
configure: error:
The development files for GTK+ were not found. For GTK+ 2, please
ensure that pkg-config is in the path and that gtk+-2.0.pc is
installed. For GTK+ 1.2 please check that gtk-config is in the path,
and that the version is 1.2.3 or above. Also check that the
libraries returned by 'pkg-config gtk+-2.0 --libs' or 'gtk-config
--libs' are in the LD_LIBRARY_PATH or equivalent."
any ideas?
MrYsLab
Re: wxwidgets and python 3.
Tue Jan 15, 2019 2:42 pm
Have you tried following these instructions: https://wiki.wxpython.org/BuildWxPythonOnRaspberryPi
Return to “Python”
