Ludaris
DHT22 readings onto a web page
Mon May 28, 2018 1:31 am
I am currently facing a problem.
Namely I have the following sensor (DHT22) properly connected to the Raspberry Pi and also installed all the necessary packages.
In the terminal I can already show values ​​via the existing test file (AdafruitDHT.py).
Now I want to show these values ​​on my website. For this I have programmed the following Python script:
import Adafruit_DHT
sensor = Adafruit_DHT.DHT22
pin = 4
humidity, temperature = Adafruit_DHT.read_retry(sensor, pin)
if humidity is not None and temperature is not None:
   print 'Temp:{0:0.1f}*C  Humidity:{1:0.1f}%'.format(temperature, humidity)
else:
   print 'Failed to obtain a reading. Try again!
And matching the PHP program:
<?php
$output = shell_exec("python /var/www/html/python/temperatur.py 22 4");
var_dump ($output);
Unfortunately I can not see anything on my website.
Do you have any ideas why it could be or how I could get it to work?
I also tried and did everything like here: viewtopic.php?t=92629
Thanks in advance.
Best regards
~ Ludaris
MrWhite_2018
Re: DHT22 readings onto a web page
Thu May 31, 2018 6:03 pm
The php code you have, where is it written? Seperate php file or within your index.php (or whatever root document you are serving)?
Are you looking to show the data on the main page, or after a button click?
Also you should add
echo var_dump ($output);
to send it to the page.
Return to “Python”
