Executing a file
Tue Feb 13, 2018 9:41 pm
I want to be able to execute a file called 'sendmidi' in a python script with parameters. This is the normal command:
sendmidi dev 0 pb (variable)
where variable needs to get a variable ofcourse. The Path of the file is /home/pi/SendMIDI
I have tried using subprocess.Popen() but i always get errors doing that.
The variable is called 'pot1'
Re: Executing a file
Wed Feb 14, 2018 7:44 am
Try os.system() instead of popen().
You can just use "+" to concatenate strings.
Wed Feb 14, 2018 12:14 pm
How did you do the call in subprocess.Popen() ?
This is an example of using subprocess.Popen() to call nmap I have added lots of comments explaining each line it might help you solve your problem.
## get subprocess module
import subprocess
## call Nmap command ##
p = subprocess.Popen("sudo nmap -sP -PI -PT | grep -i hosts", stdout=subprocess.PIPE, shell=True)
## Talk with Nmap command i.e. read data from stdout and stderr. Store this info in tuple ##
##Interact with process: Send data to stdin. Read data from stdout and stderr, until end-of-file is reached. Wait for process to terminate. The optional input argument should be a string to be sent to the child process, or None, if no data should be sent to the child.##
(output, err) = p.communicate()
## Wait for nmap to terminate. Get return returncode ##
## This line gets the command exit status and saves it as status this will be 0 if all is well ##
status = p.wait()
## This line saves the output of the namp command as resultline ##
resultline = output
Note the actual line to call nmap is enclosed with " "
Please only ask questions in the forum I will not answer questions sent to me directly via PM
Remember we want information no help
The use of crystal balls & mind reading is not supported
Wed Feb 14, 2018 7:19 pm
Thanks ppl, i got it working but a lot of the times when i run the code its running slowly.
Im sending simple midi signals to the pc.
# -*- coding: utf-8 -*- Simple example of reading the MCP3008 analog
# input channels and printing them all out. Author: Tony DiCola License:
# Public Domain
import time
import os
import Adafruit_GPIO.SPI as SPI
import Adafruit_MCP3008
mcp = Adafruit_MCP3008.MCP3008(spi=SPI.SpiDev(SPI_PORT, SPI_DEVICE))
while True:
 pot0 = str(mcp.read_adc(0) * 16)
 #if pot0c != pot0:
 os.system("./sendmidi dev f_midi pb " + pot0)
So i want to read the MCP3008 A/D Converter and pass it trough the file 'sendmidi'.
I want to be able to control a knob in a software called ableton.
Here's the slow running code: ... 4c7973.mp4
here's the fast running code: ... 937a64.mp4
I think it has something to do with the infinite loop not properly executing. Can you guys help to make it run smooth every time?
Return to “Python”
Who is online
Users browsing this forum: No registered users and 10 guests
