Re: Raspberry pi MQTT
Sat Sep 30, 2017 7:56 pm
sudo systemctl stop dnsmasq
sudo systemctl start dnsmasq
Or hit it harder
sudo killall dnsmasq
Or take the big red switch approach
sudo reboot
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3B*3, 3B+
Please post ALL technical questions on the forum. Do not send private messages.
NIW
Mon Oct 09, 2017 5:05 pm
Could I just change the DHCP range to be greater?
Wed Oct 11, 2017 4:42 pm
As long as your DHCP range is shorted than your subnet range (based on netmask) you can set a longer DHCP range. Stay away from .0 and .255 addresses.
MQTT Evangelist
asandford
Fri Oct 13, 2017 1:35 am
It won't work until you install a broker, have you done that?
Client to client communication isn't possible.
NIW
Fri Oct 20, 2017 7:20 pm
I have moquitto installed.
asandford
Fri Oct 20, 2017 11:20 pm
Did you do the single Pi test as I suggested?
NIW
Sat Oct 21, 2017 3:24 pm
Yes and It worked just fine.
I have gotten the pi's to communicate over a wireless network, but getting them to communicate over the cat5 cable has not worked yet.
DirkS
Sat Oct 21, 2017 3:32 pm
Then you have a network problem. Solve that and MQTT will work too.
How did you configure your cabled network? Normally it should work straight out of the box
NIW
Sat Oct 21, 2017 7:00 pm
I did
and then ran
sudo dnsmasq
and nothing happened. It just went to a new command line.
Did it work?
NIW
Sat Oct 21, 2017 7:33 pm
I tested It and....
IT WORKED :D
Thank you everyone who helped me accomplish this.
This is going to help me build my ROV ( RC sub) so much.
asandford
Sun Oct 22, 2017 2:30 am
I tested It and....
IT WORKED :D
Glad you got it working
Return to “Python”
Who is online
Users browsing this forum: No registered users and 8 guests
