hrgdavid
Import Error: No module named pygtk
Sat Jun 30, 2012 8:44 pm
I'm new to Python and am presumably making a basic error, but this has had me occupied all afternoon and evening trying to google an answer without success. Please help ;-)
I've copied a simple program from the web to put a window up on the screen. The first line is "Import pygtk". When I run it it returns "Import Error: No module named pygtk".
I've also tried this interactively in LXTerminal - same result. And the same thing happens with "Import gtk".
Do I need to do something first to install these modules ? I thought it was part of the standard Python install....?
Thanks for any help.
Regards,
David L.
andyl
Re: Import Error: No module named pygtk
Sun Jul 01, 2012 8:32 am
You need to install pygtk.
Not every Python module in the world is installed by default.
sudo apt-get install python-gtk2
You may want to install the doc package too.
hrgdavid
Sun Jul 01, 2012 11:06 am
andyl wrote:You need to install pygtk.
Andy, you're a star ! Thank you.
kibr3
Mon Nov 05, 2012 5:53 am
That helped me too .Thanks
sisila
Wed Aug 21, 2013 9:26 am
thank you........ :o
jander2099
Fri Feb 13, 2015 7:50 pm
Yes!!! Thank you so much! That fixed it.
paulwratt
Thu Sep 14, 2017 9:10 am
fix still works (2017)
PeterO
Thu Sep 14, 2017 10:23 am
importing PyGTK is the old python interface to Gtk+
You might find this useful for doing it the modern way ! http://www.peteronion.org.uk/PyGobjectGtk+3/PyGtk.html
HTH
PeterO
