kaybee
linux/usage/scripting
Mon Dec 08, 2014 5:48 pm
Follwing the instructions at http://www.raspberrypi.org/documentatio ... ripting.md, results in:
./fun-script: line 1: 1: command not found
I am Using Raspbian, on Raspberry Pi B. Any ideas?
Thanks,
kaybee
DirkS
Re: linux/usage/scripting
Mon Dec 08, 2014 6:33 pm
Are you sure that link is correct? I get a 404 error...
Gr
Dirk.
DirkS
Mon Dec 08, 2014 6:40 pm
I checked the docs on github...
Did you maybe type 'While' instead of 'while'?
Gr.
Dirk.
Mon Dec 08, 2014 7:51 pm
I just tried the script as shown and got the same result.
Changing it from
while 1
do
echo Raspberry Pi!
done
to
while true
do
echo Raspberry Pi!
done
works
B.Goode
Mon Dec 08, 2014 9:16 pm
The man page for /bin/bash says the argument to while must be a command: it is the return status of that command that is checked. Presumably an integer is not processed as a command and does not have a return value.
I have raised this as an 'Issue' on the github site for the RPF documentation. https://github.com/raspberrypi/documentation/issues/134
Joe Schmoe
Mon Dec 08, 2014 10:20 pm
Incidentally, the more "idiomatic" way to do this is:
while :;do
done
B.Goode
Tue Dec 09, 2014 8:59 am
The tutorial referred to has now been corrected.
kaybee
Tue Dec 09, 2014 1:03 pm
All:
Thanks guys, being new to this, I was confused. It's interesting that:
while true
do
echo Raspberry Pi!
done
was actually corrected to:
while :
do
echo Raspberry Pi!
done
on the tutorial. Both work.
Thanks again
