marchello
linux + oracle + sqlplus + awk, script doesn't work
Mon Dec 08, 2014 4:33 pm
Hi all,
We get log_id value empty after migration.
log_id=$(sqlplus -s /nolog <<-EOF|awk 'NR==2 {print $1}'
  set head off
  set feed off
  set pagesize 0
  conn $DBCONN_AUDIT
  select pls_audit.get_id_log from dual;
#EOF)
Maybe (I'm not sure) the problem is in awk.
Last time http://www.raspberrypi.org/forums/viewt ... 31&t=93044 we had problem with
awk -F\t
and changed it to
awk '-F\t'
(works great).
Please someone comment is it problem in awk syntaxis and how to solve.
Thanks ahead.
marchello
Re: linux + oracle + sqlplus + awk, script doesn't work
Mon Dec 08, 2014 8:27 pm
This way it works fine:
echo -e "conn user1/pass1@plspro\nselect pls_audit.get_id_log from dual;" | sqlplus -s /nolog
GET_ID_LOG
  33363309
So I guess it is not Oracle question, it is more linux question about syntaxis...
Maybe someone can kindly help please?
