jgcramer
Raspberry pi play shor movie's (.Net/Mono/DotNet)
Tue Aug 19, 2014 1:58 pm
I have a Raspberry pi what i use to show information on a screen with different screens (jpegs) on it for eatch specific customer.
But now i wanne show short movie's on the Pi, when a specific customer is in front of the screen.
I use .Net to program with Mono on the Pi.
Now my question:
What is the best way to play the movie, also becasuse of the limits of the Pi.
dotnet, mono, .net
RaTTuS
Re: Raspberry pi play shor movie's (.Net/Mono/DotNet)
Thu Aug 21, 2014 1:46 pm
omxplayer file.h264
Covfefe
jgcramer
Thu Aug 21, 2014 1:53 pm
RaTTuS wrote:omxplayer file.h264
This application runs stable and fast on the pi with mono?
I have googled but diddent find some DotNet helping files.
ghans
Thu Aug 21, 2014 7:30 pm
This is a native Linux program which has to be spawned from
within Mono with something like exec() (PHP) or subprocess.call()
(Python). No idea how that is called in C#.
ghans
jgcramer
Fri Aug 22, 2014 7:11 am
Ok!
And if i want to split my screen? (Upper screen movie, lower screen picture. With DotNet within mono.
forenbenutzer
Fri Aug 22, 2014 7:17 am
You can pass parameters to omxplayer, like coordinates X and Y, aswell as width (X2 = X1 + width) and height (Y2 = Y1 + height):
Usage: omxplayer [OPTIONS] [FILE]
Options :
         -h / --help                    print this help
         -n / --aidx  index             audio stream index    : e.g. 1
         -o / --adev  device            audio out device      : e.g. hdmi/local
         -i / --info                    dump stream format and exit
         -s / --stats                   pts and buffer stats
         -p / --passthrough             audio passthrough
         -d / --deinterlace             deinterlacing
         -w / --hw                      hw audio decoding
         -3 / --3d mode                 switch tv into 3d mode (e.g. SBS/TB)
         -y / --hdmiclocksync           adjust display refresh rate to match video (default)
         -z / --nohdmiclocksync         do not adjust display refresh rate to match video
         -t / --sid index               show subtitle with index
         -r / --refresh                 adjust framerate/resolution to video
         -g / --genlog                  generate log file
         -l / --pos n                   start position (in seconds)
              --boost-on-downmix        boost volume when downmixing
              --vol n                   Set initial volume in millibels (default 0)
              --subtitles path          external subtitles in UTF-8 srt format
              --font path               subtitle font
                                        (default: /usr/share/fonts/truetype/freefont/FreeSans.ttf)
              --font-size size          font size as thousandths of screen height
                                        (default: 55)
              --align left/center       subtitle alignment (default: left)
              --lines n                 number of lines to accommodate in the subtitle buffer
                                        (default: 3)
              --win "x1 y1 x2 y2"       Set position of video window
              --audio_fifo  n           Size of audio output fifo in seconds
              --video_fifo  n           Size of video output fifo in MB
              --audio_queue n           Size of audio input queue in MB
              --video_queue n           Size of video input queue in MB
For example upper half of full hd (1920x1080) screen:
omxplayer --win "0 0 1920 540" myfile.mp4
Attention: omxplayer "overlays" your current application. If you create your user interface, be sure to not locate any interactive controls in the area you would like to have your video.
In c# mono it might be something like this:
Process.Start(new ProcessStartInfo("/usr/bin/omxplayer", "--win \"0 0 1920 540\" myfile.mp4") { UseShellExecute = false });
Pitendo - Case And Emulator Project - http://edv-huber.com/index.php/problemloesungen/12-pitendo
jgcramer
Fri Aug 22, 2014 8:51 am
@forenbenutzer thank you, this must work!
