aaa801
Crosscompiling for RaspPi - Explained
Fri Jun 15, 2012 2:25 pm
Compiling big projects is very time-consuming on the raspberry pi. Wouldn't it be great if we could compile our files on a seperate computer and make the changes to the SD Card immediatelly?Normally we'd just mount a remote disk, and chroot into it. The problem is, that the Raspberry PI is an ARM System, and most computers are NOT. This means the binaries on the sdcard are incompactible. We can solve this using qemu, a processor emulator.
All the following procedures are done on the host system, not the raspberry pi!, you will just need the PI's SDCard, not the device itself!
I will assume that your sdcard is unmounted and is located on /dev/sdc. Your sdcard might be located somewhere else, and might be mounted. If you don't know how to umount it, or find out what the name is of your sdcard device, check out the beginners` guide on the wiki : http://elinux.org/RPi_Easy_SD_Card_Setu ... nd_line.29
Lets first mount the correct partition of the sdcard, (the one with the linux file hierarchy). to do this we will issue this command:
$ sudo fdisk -l
You'll see a list of information, try to look for the section which has info about the Disk that matches your SDCard's size, and has a Linux System on one of the devices
Disk /dev/sdc: 2013 MB, 2013265920 bytes
4 heads, 32 sectors/track, 30720 cylinders, total 3932160 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000ee283
   Device Boot      Start         End      Blocks   Id  System
/dev/sdc1            2048      155647       76800    c  W95 FAT32 (LBA)
/dev/sdc2          157696     3414015     1628160   83  Linux
/dev/sdc3         3416064     3807231      195584   82  Linux swap / Solaris
The device with Linux FileSystem, in my case /dev/sdc2 is the one we'll need to mount. I'll just mount it to /mnt.
$ sudo mount /dev/sdc2 /mnt
Now we're going to install the stuff we will need for the processor simulation
$ sudo apt-get install qemu qemu-user qemu-user-static
Now we need to copy over the file for the emulation to the sdcard
$ sudo cp /usr/bin/qemu-arm-static /mnt/usr/bin
Everything should be done now!, we should be able to chroot into the pi's filesystem!
$ sudo chroot /mnt
we'll be prompted with a new commandline! Yay!, lets check if it worked! BTW, we
root:/# gcc -v
Using built-in specs.
Target: arm-linux-gnueabi
Yay, it worked! you can now navigate to your project on your sdcard, for example # cd /home/pi/mybigCProject
and then just run your Makefile or gcc or any ARM Build tool you need, and it will start building.
Once you're done compiling, type in this to exit the chroot
# exit
and then unmount the device
$ sudo unmount /dev/sdc2
Now remove the SDCard, pop it in your raspberry pi, and go try out your compiled project ^^
You won't have to copy over the qemu-arm-static file every time, just once, so next time you just do:
$ sudo chroot /mnt
and off you go!
NOTE: make sure you're using qemu 1.0 at least, older versions might glitch, no good timez. Check it with "qemu-arm-static -version"
Happy developing!
~~ Arian & AAA801
chorlton
Re: Crosscompiling for RaspPi - Explained
Fri Jun 15, 2012 2:57 pm
This is dark voodoo.
I get how chroot works, and I get that the gcc on the mounted partition will target ARM architecture, but that gcc is an ARM binary. I wouldn't have thought it would run on an x86 host?
By copying qemu-arm-static into the /usr/bin of the chroot this will magically just work?
If it does then I'm impressed! :)
ukscone
Fri Jun 15, 2012 3:07 pm
there is another way that is pretty simple. scratchbox2 http://maemo.gitorious.org/scratchbox2 (and if you really want to sbrsh although it does complicate things a little).
scratchbox2 is pretty much idiot-proof and to prove it i've been using it almost exclusively for several years (plus aboriginal & buildroot) and had no problems. i normally use it inside a vm just for convieniance but it doesn't have to be in one. simple instructions can be found here http://pastebin.com/4Jp1WPTb
aaa801
Fri Jun 15, 2012 3:12 pm
chorlton wrote:This is dark voodoo.
Yes it does :)
I tested it by compiling virtualBoyAdvance, (which crashs the pi when you compile on it for some reason)
And it worked out great :D
aaa801
Fri Jun 15, 2012 3:16 pm
This is needed aswell to prevent problems with networking etc
after the
mount ### /mnt
mount -o bind /dev /mnt/dev
mount -o bind /proc /mnt/proc
mount -o bind /sys /mnt/sys
abishur
Fri Jun 15, 2012 3:17 pm
Yes it does :)
Did you get sound and a good frame rate off virtualBoyAdvnaced? (Would you be willing to share the binaries? :-P)
Dear forum: Play nice ;-)
aaa801
Fri Jun 15, 2012 3:19 pm
Yes it does :)
No sound yet :(, but it runs at about 90-100% emulation speed, which is prety dam awesome, il pm you the prebuilt source tree
jecxjo
Fri Jun 15, 2012 3:20 pm
ukscone wrote:there is another way that is pretty simple. scratchbox2 http://maemo.gitorious.org/scratchbox2 (and if you really want to sbrsh although it does complicate things a little).
I use Scratchbox2 for all of my projects at work. Using a cross compiler running natively gives you better performance than running a native compiler in an emulator. Scratchbox is nice since you get execution time in the emulator (qemu) when you need it but when you compile you are using your native cross compilers. Building large projects is much faster this way.
I'm working on converting my old tutorial to the RPi wiki. But for the moment here is the link. You should be able to skip over the parts where you build the cross compilers by hand if you want to use the ones from your distro. I'll be sure to post on here once I've finished rewriting it for the Pi on the eLinux site.
http://biffengineering.com/wiki/index.p ... nvironment
xmpp: [email protected]
Blog: http://jecxjo.motd.org/code
aaa801
Fri Jun 15, 2012 11:17 pm
The advantage of this is also that you also dont have to copy over files etc from and to the pi ;)
ukscone
Fri Jun 15, 2012 11:26 pm
aaa801 wrote:The advantage of this is also that you also dont have to copy over files etc from and to the pi ;)
that's what sbrsh is for. basically it mounts the target device using sshfs or nfs and uses the cross compiler host toolchain to compile but uses the target for running binaries within the building process and the resultant binary is on the target when the compile is completed
KiwiKid
Mon Oct 01, 2012 11:37 pm
For those wondering how this magic works: http://en.wikipedia.org/wiki/Binfmt_misc.
Basically the Linux kernel can be configured with extra executable file formats and which user space application to use to run them. These instructions have you install qemu + the appropriate setup to recognize ARM binaries and run them via QEMU transparently.
Not as fast as scratchbox in terms of performance, but a lot easier to setup; and given how fast many peoples machines are/their expectations, this incredibly simple setup is just amazing.
NOTE: I haven't confirmed if this is still true, but looking at http://wiki.debian.org/QemuUserEmulation it seems that this approach is incompatible with scratchbox/scratchbox2. Don't try setting up both on the same machine unless you're willing to manually change the binary format mappings.
akadata
Wed Oct 10, 2012 2:21 pm
the chroot with qemu-arm is a really nice and quick way of building and compiling for the Raspberry Pi. to this extent i have put a file in dropbox here https://www.dropbox.com/s/xwlnu8eq7566i ... map=%5B%5Dand posted a link on the Facebook Group https://www.facebook.com/groups/raspberry.pie/ with arm-chroot, a complete minimal base install of raspbian
I hope everyone finds this usefull. there are no accounts and no passwords and its just a second stage debootstraped environment.
akadata
Wed Oct 10, 2012 2:53 pm
akadata wrote:the chroot with qemu-arm is a really nice and quick way of building and compiling for the Raspberry Pi. to this extent i have put a file in dropbox here https://www.dropbox.com/s/xwlnu8eq7566i ... map=%5B%5Dand posted a link on the Facebook Group https://www.facebook.com/groups/raspberry.pie/ with arm-chroot, a complete minimal base install of raspbian
Note there is an x86_64 static linked /usr/local/bin/qemu-arm file that i compiled on my Debian system. as it is a static binary the chroot should work on any x86_64 Linux box.
to enter the chroot with this command
"enter-chroot.sh ."
i have modified the enter chroot file to setup the arm-binfmt bits
one extra thing you may have to do to make it work on your setup is copy arm-chroot/usr/loca/bin/qemu-arm to your /usr/loca/bin . Note. Please make sure you dont overwrite your own custom qemu in /usr/local
diereinegier
Thu Jan 03, 2013 1:09 pm
I did not even know this was possible. Really, really cool.
I just checked this out and it still works with the current debian wheezy image. I used an Ubuntu 12.10 laptop with a 2 GHz Celeron to cross compile since it was the only machine with an SDHC reader available.
I got compile times that are worse than on a 512MB RasPi! Even when using a parallel make.
I can't say if the 2 GHz Celeron, the Kingston SDCard make the cross compile slow or if the native speed on the RasPi was improved during the last months.
As always: your mileage may vary!
Download my repositories at https://github.com/GeorgBisseling
kalectro
Tue Mar 05, 2013 4:10 am
it does not work on the latest Raspbian image. Any suggestions?
http://www.raspberrypi.org/phpBB3/viewt ... 37#p298537
aaa801
Tue Mar 05, 2013 6:39 pm
kalectro wrote:it does not work on the latest Raspbian image. Any suggestions?
tanders12
Tue Mar 05, 2013 7:05 pm
When I was setting this up I came across the following guide:
http://xecdesign.com/qemu-emulating-ras ... -easy-way/
The note towards the top of the page indicates that qemu isn't working with the current Raspbian image. So this has been a problem for at least a few days.
baam
Sun Mar 10, 2013 10:07 pm
is there any chance to get a workaround? would be great :)
baam
Mon Mar 11, 2013 5:43 am
Well, maybe i should have read the thread tanders posted... :roll:
they suggest (post from march 9th)
In order to run the latest image (2013-02-09-wheezy-raspbian.img) you need to comment out the contents of /etc/ld.so.preload.
or compile the kernel for qemu: http://xecdesign.com/compiling-a-kernel/
or compile qemu for arm: http://xecdesign.com/compiling-qemu/
i try to test it today and give you a feedback!
sikku
Wed Mar 13, 2013 2:57 am
Finally I am able to login to Raspberry Pi without any monitor.
My first login was directly from my peer to peer connection.
All I did was I mounted the SD card into my PC and edited this file as follows:
# mount /dev/sdc2 /mnt
# cd /mnt
# vi etc/network/interfaces
Then I made sure the following content is fed into etc/network/interfaces
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
address 192.168.1.3
netmask 255.255.0.0
The ip address of my PC is 192.168.1.3
I changed the ip address of my PC as follows:
# ifconfig p2p1 192.168.1.2 netmask 255.255.255.0 up
Others may have to change the p2p1 with eth0. Or to know what is the name you can check by issueing the command
# ifconfig -a
sikku
Wed Mar 13, 2013 2:58 am
I want to get tightvnc binary file so that I can copy it to the bin directory and use vncviewer to get the GUI.
Can anybody help me in getting binary file of tightvnc?
baam
Wed Mar 13, 2013 9:08 am
@sikku: wrong thread?!
b2t:
i tried their suggestion:
comment out the content from etc/ld.so.preload did work. chroot is doing fine now.
my problem is now that autoconf wont run :/
getting "you need autoconf version 2.59 or newer installed"
if i run /usr/bin/autoconf i get:
This script requires a shell more modern than all the shells that i found on your system.
installed version is 4.2.37(1)-release
i wont test the other options with compiling qemu etc.
aaa801
Wed Mar 13, 2013 10:22 am
baam wrote:@sikku: wrong thread?!
b2t:
try opening bash then try it
baam
Wed Mar 13, 2013 12:39 pm
already tried that.. doesnt work :?
does anyone else have the same problems?
sikku
Fri Mar 15, 2013 12:27 pm
Yeah wrong thread... my mistake...
