eraldino
Set of questions forAGui,Arduino and Matlab Interfacing
Fri Jul 25, 2014 5:04 pm
Hello to everyone. I am new to RPi and yet to buy my own.
I have a set of questions.
First, I want you to know my project. I am reading values via sensors from my arduino analog pins. A0 to A15.
Currently, I am using matlab and the Arduino I/O script which allows matlab to connect to the arduino via usb. I've created a GUI which displays values via analogRead.
Now what I want to do is change from a PC-matlab interface into the Raspberry Pi.
First question:
Is it possible to read values per AnalogPin from arduino to RPi? Cause ive read some articles and all i see is serial read from the two and that only flashes data in a stream. Is there a way to read the pins individually?
Second Question:
Whats the best GUI program for RPi that i can use for displaying the AnalogData
Third:
If all this fails, can i just use my Matlab GUI and compile it make it run on RPi?
Sorry for the long post. I want to ask all this before I dive into the RPi environment.
Thank you!
