Hello all,
I am a c++ developer with little experience with web applications or GUI tool kits. (The only GUI I have done is using Win32.)
I am writing a tutoring tool which needs a rich user interface. The UI should be responsive and should not be sluggish.
1. What are your suggestions for writing GUI applications for the raspberry?. I am looking at PyGTK. Would it be slow on the pi?
2. Would you suggest that it is better to write a web application so that it can be run in a browser?. Is there a standard web application UI framework that is used in the Pi?
Any thoughts would be most helpful.
Best
Kaushik
Re: Best UI programming framework?
Under Linux+X likely anything will be a bit slow. There is NanoX/Microwindows, should be easy to compile for ARM Linux+FB and provides a Win32 API subset + FLTK. And to note your best bet regardless of GUI on Linux is likely FLTK.
On the flip side AROS (the version without Linux) Provides a good fast GUI, as does Plan9, and RISC OS, just to name a few in case you are not tied to Linux. The fastest is of cource RISC OS as it is written mostly in Assembly, and it does provide UI Libs for C and C++ if you wish to use them.
Though take your choice, there are plenty of options.
RPi = The best ARM based RISC OS computer around
More than 95% of posts made from RISC OS on RPi 1B/1B+ computers. Most of the rest from RISC OS on RPi 2B/3B/3B+ computers
For a GUI application to be run in Linux on the RPi I would highly recomend avoiding ANY scripting language (Python, WEB base JS etc).
- Raspberry Pi Engineer & Forum Moderator
- Location: The unfashionable end of the western spiral arm of the Galaxy
Does interpreted vs compile really make any difference under X? As I understand it, the clocks cycles for the actual applications are negligible to those needed by X to actually render things. I am certain that the lightest C program using gtk under X will be slower than an equivilent python program using openvg or an opengl es gui toolkit.
Anyway, I'd suggest you try pygtk and see how you go with it. You don't lose anything by getting experience with different toolkits until you find the one you like.
If you want to develop a GUI using C++, Qt would (IMHO) be the best choice, and has a nice IDE in Qt Creator--setting this up to work on the RasPi is a bit tricky, but it has been covered before in these forums.
And that is why i recomended compiling the FrameBuffer (non X) version of NanoX, as this gives FTK in an enviroment that is much faster than the current X on the RPi.ShiftPlusOne wrote:Does interpreted vs compile really make any difference under X? As I understand it, the clocks cycles for the actual applications are negligible to those needed by X to actually render things. I am certain that the lightest C program using gtk under X will be slower than an equivilent python program using openvg or an opengl es gui toolkit.
As the OP seems to be interested in effeciency; under Linux I would not use X. The faster options include NanoX/MicroGUI, W Windowing System, FBWindows, and many more. FLTK is available for NanoX/MicroGUI, and this would be a good starting point as the OP also has experience with the Win32 API, and a subset of said API is provided.dr_d_gee wrote:If you want to develop a GUI using C++, Qt would (IMHO) be the best choice, and has a nice IDE in Qt Creator--setting this up to work on the RasPi is a bit tricky, but it has been covered before in these forums.
Hello all,
Sorry for being away. Thanks for the comments. I will look at FLTK. One thing I wanted to mention is - I am not particular about using C++. I was mentioning that, C++ is all I have worked with. However, I am happy to learn anything except java
