Alex555
Run a script every 30 seconds
Sat Jun 08, 2013 6:34 pm
Hello everyone,
I have a bluetooth keyboard connected to my Pi, but it keeps disconnecting automatically after a certain amount of seconds. I was wondering if it is possible to make the Pi run a script every 30 seconds to attempt to re-establish connection with the keyboard. Is it possible to do so?
mahjongg
Re: Run a script every 30 seconds
Sat Jun 08, 2013 6:40 pm
probably but you should never try to suppress the symptoms, you should rather cure the disease, which most probably is power supply related, or is because the bluetooth radio is too near a transmitter of radio disturbances (the PI board itself).
Alex555
Sun Jun 09, 2013 8:05 pm
mahjongg wrote:probably but you should never try to suppress the symptoms, you should rather cure the disease, which most probably is power supply related, or is because the bluetooth radio is too near a transmitter of radio disturbances (the PI board itself).
Well, actually the keyboard just disconnects upon inactivity. I have tested everything else. The keyboard will not disconnect while in use and will do after about 5 mins if inactive.
Now, if you could tell me how to run a script on a delay of about 30-60 secs or any other possible solution, I would very much appreciate it :)
sprinkmeier
Sun Jun 09, 2013 9:35 pm
$ watch --precise --interval 30 -- ./your/script/goes/here
unlike a simple loop this won't drift if your script takes a few seconds to run.
unlike CRON this won't start multiple copes if your script takes a few minutes to run.
Have fun flattening your keyboard battery :-)
