Page 1 of 7
Raspberry Pi Benchmarks
Posted: Fri May 17, 2013 11:57 am
by RoyLongbottom
I have converted my Classic Benchmarks to run on the Linux based Raspberry Pi. These are Whetstone, Dhrystone, Linpack and Livermore Loops. The benchmark source code was also compiled and on a PC running Linux to confirm compatibility. Executable files and source codes can be downloaded by the following. This can be unzipped on the Pi and programs run from a Terminal command.
http://www.roylongbottom.org.uk/Raspber ... hmarks.zip
For details and example results on ARM and Intel processors see.
http://www.roylongbottom.org.uk/Raspber ... hmarks.htm
Speeds from the ARM A6 are not as fast as those from ARM Cortex-A9 on recent Android tablets but, as we know, the Pi is usable as a proper desktop computer running Linux.
The Livermore Loops benchmark was used to accept the first supercomputer. So the main bragging rights are:
In 1978, the Cray 1 supercomputer cost $7 Million, weighed 10,500 pounds and had a 115 kilowatt power supply. It was, by far, the fastest computer in the world. The Raspberry Pi costs around $70 (CPU board, case, power supply, SD card), weighs a few ounces, uses a 5 watt power supply and is more than 4.5 times faster than the Cray 1.
My bragging rights are that I developed and ran benchmarks, including Whetstones, on Serial 1 Cray 1.
Roy
Re: Raspberry Pi Benchmarks
Posted: Fri May 17, 2013 7:52 pm
by eried
Excellent and detailed information. I wonder how other similar boards (in price) do in the same tests, like the BeagleBlack, cheap tp-link routers and pcDuinos, etc
Posted: Sun May 19, 2013 11:00 am
by RoyLongbottom
Classic Benchmarks Stability Test
A long time ago, the Livermore Loops benchmark produced wrong numeric results on an overclocked CPU. So, a reliability mode was included with an execution parameter to control running time and addition checks for the correct result of calculations. I ran a 6 minutes test at 700 MHz and 1000 MHz, measuring temperatures from a different Terminal. Detailed results are in:
Room temperature was 22.6°C. At 700 MHz temperature increased from 48.7 to 53.0°C and, higher at 1000 MHz, from 50.3 to 60.5°C.
Roy
Posted: Wed May 22, 2013 10:10 am
by RoyLongbottom
My memory speed benchmark has now been converted to run on the Raspberry Pi with the program and source code included in:
MemSpeed benchmark measures data reading speeds in MegaBytes per second carrying out calculations on arrays of cache and RAM data, using double and single precision floating point and integer numbers. Calculations are of the form x = x + s * y (integer s + y), x = x + y and x = y. Results are below at normal and overclocked speeds. The overheads on repetitively running the tests cause variations in speeds of the lower data sizes but average overclocked speed gain, using L1 cache, is 1.41 times, compared with 1.43 times CPU MHz. Average RAM speed gains are 1.53 times, similar to expectations. A surprise is for L2 cache based data, where the average gain is 1.72 times and some speeds appear to be faster than using L1 cache. For comparison with Intel processors and other ARM based system see:
                 Results in MegaBytes Per Second
        Raspberry Pi CPU 700 MHz, Core 400 MHz, SDRAM 400 MHz
  Memory   x[m]=x[m]+s*y[m] Int+   x[m]=x[m]+y[m]         x[m]=y[m]
  KBytes    Dble   Sngl  Int32   Dble   Sngl  Int32   Dble   Sngl  Int32
    Used    MB/S   MB/S   MB/S   MB/S   MB/S   MB/S   MB/S   MB/S   MB/S
       8     538    640    930    602    731   1094   1230    465    465 L1
      16     568    602    787    602    731   1023   1000    426    507
      32     292    256    310    276    262    330   1066    426    547 L2
      64     276    238    276    262    238    292    341    269    284
     128     189    170    193    182    170    200    222    196    204
     256     140    129    142    136    129    144    138    119    124 RAM
     512     138    127    138    134    127    144    131    111    119
    1024     136    127    138    134    127    144    124    111    119
    2048     136    127    138    132    128    144    128    111    121
    4096     136    128    138    134    126    144    128    111    119
    8192     138    127    138    136    127    144    126    111    119
 Max MFLOPS   71    160            38     91
 MAX MIPS                  725                  645    423    320    320
        Raspberry Pi CPU 1000 MHz, Core 500 MHz, SDRAM 600 MHz, 6 volts
       8     602    640   1185    930   1163   1662   1422    511    761 L1
      16     787    930   1292    853   1023   1523   1777    537    761
      32     487    426    487    465    426    568   1939    820   1142 L2
      64     465    393    465    426    393    511    592    457    508
     128     330    310    341    320    301    365    341    301    341
     256     208    200    213    204    200    217    196    170    189 RAM
     512     204    200    213    200    200    213    196    176    182
    1024     213    200    208    200    200    217    196    170    182
    2048     204    196    213    204    200    217    196    170    182
    4096     204    200    213    200    200    217    196    170    182
    8192     204    200    213    200    200    218    204    169    182
 Max MFLOPS   98    232            58    145
 MAX MIPS                 1007                  980    667    563    785
Roy
Posted: Sat May 25, 2013 11:47 am
by RoyLongbottom
Latest conversion is BusSpeed with the benchmark and source code included in:
This benchmark is designed to identify reading data in bursts over buses, with measurements covering caches and RAM. The program starts by reading a word (4 bytes) with an address increment of 32 words (128 bytes) before reading another word. The increment is reduced by half on successive tests, until all data is read.
Following shows results on the Pi with default speed settings. Variations indicate that data is read in bursts from caches and RAM. For the latter, 8 word or 32 byte bursts are suggested or 8 transfers of 4 bytes. An estimate of maximum speed is 8 x 34 = 272 MB/second, a long way from the specification. It is the same story on Andoid/ARM based devices but throughput can increase linearly with the number of CPU cores being used. Intel based PCs do not suffer to nowhere near the same extent (but at what cost?). For further details and comparisons see:
   Maximum speed 400 x 2 (DDR) x 4 Width = 3.2 GB/sec
   BusSpeed 32 Bit V1.1 Wed May 22 15:28:01 2013
     Reading Speed 4 Byte Words in MBytes/Second
  Memory  Inc32  Inc16   Inc8   Inc4   Inc2   Read
  KBytes  Words  Words  Words  Words  Words    All
      16    290    304    568    984   1125   1142 L1
      32    133    116    131    133    225    465 L2
      64    116     98    116    109    192    409
     128     60     54     62     68    126    273
     256     34     34     34     43     88    192 RAM
     512     34     34     34     45     91    200
    1024     34     31     34     45     91    181
    4096     32     33     33     45     87    183
   16384     32     32     34     44     83    186
   65536     34     32     34     44     88    186
        End of test Wed May 22 15:28:13 2013
Roy
Posted: Thu May 30, 2013 4:06 pm
by RoyLongbottom
The newest conversion is a Java version of the Whetstone Benchmark. For details of both of these see latest:
This benchmark is heavily dependent on floating point calculations. As many will know, the Java compiler produces hardware independent .class files that need a Java RunTime Environment (JRE) to convert this to runnable on specific hardware. Programs can be compiled to run off-line, and with small changes, to run on-line as Applets via an HTML page. This Whetstone Benchmark is provided in both formats.
Initial research suggested installing JRE 6 (icedtea-plugin). This ran the benchmarks, but slowly. That also applied when JRE 7 was installed. Further searching indicated that JRE 8 was needed for hard float and this was much faster. Finally, the following provided ways of making JRE 6 and 7 faster (using JamVM):
http://www.raspberrypi.org/phpBB3/viewt ... 81&t=45132
Following are results of the 8 different tests and overall MWIPS rating, including using maximum overclocking. There is not much difference in overall MWIPS on using JamVM and the original is faster on the COS/EXP tests, but much slower on the other tests. Similarly, JRE 8 averages about four times faster than JRE 7 with JamVM, if the COS/EXP results are excluded. The moral is don’t compare performance using a single number.
  Version     JRE  MWIPS  ------MFLOPS-------   -------------MOPS---------------
                              1      2      3    COS    EXP  FIXPT     IF  EQUAL
  Off-line
  Original      6   18.3    4.4    6.4    3.3   0.99   0.30    7.9    2.9    2.5
  Original      7   18.7    4.3    6.2    3.5   0.98   0.30    7.9    2.9    2.6
  JamVM         6   23.4    9.4   10.0    8.9   0.69   0.23   17.8    8.1    5.4
  JamVM         7   25.7   12.3   11.7    9.7   0.74   0.24   23.6   10.9    6.2
  Original      8   47.8   49.4   47.8   26.7   1.19   0.36   93.3   27.8   40.0
  1000 MHz      8   75.1   71.4   69.2   39.8   2.10   0.53  134.9   40.3   57.8
  On-line
  JamVM         6   25.3    9.9   10.3    7.7   0.63   0.25   17.9    8.5    5.1
  1000 MHz      6   39.0   14.1   13.7   11.2   1.30   0.40   25.4   12.2    7.2
              MHz
  C Version   700  270.5   97.8  100.8   85.7   5.90   2.70  425.3  698.6  499.0
  V7-A9 Java 1000  286.5   51.8   85.2   63.6  13.10   5.30  176.1   68.6   35.0
Roy
Posted: Thu May 30, 2013 8:23 pm
by eried
Cacao JVM is very fast compared to the default one. Can you compare that jvm too? (there are like 3 available jvms but cacao is the fastest in my tests, almost 2x more speed)
Posted: Thu May 30, 2013 9:17 pm
by RoyLongbottom
eried wrote:Cacao JVM is very fast compared to the default one. Can you compare that jvm too? (there are like 3 available jvms but cacao is the fastest in my tests, almost 2x more speed)
How do I install/enable Cacao - I tried a suggested command earlier but it was not recognised.
Posted: Thu May 30, 2013 9:59 pm
by eried
Check apt-cache search jvm | grep cacao
I tested a image recognizer:
pi@raspberrypi ~/Desktop/Mono/MatriculasTest2 $ time java -jar javaanpr.jar -recognize -i test_001.jpg
PP587A0
real	0m31.387s
user	0m30.670s
sys	0m0.290s
With jamvm:
pi@raspberrypi ~/Desktop/Mono/MatriculasTest2 $ time java -jamvm -jar javaanpr.jar -recognize -i test_001.jpg
PP587A0
real	0m18.316s
user	0m17.750s
sys	0m0.220s
With cacao vm:
pi@raspberrypi ~/Desktop/Mono/MatriculasTest2 $ time java -cacao -jar javaanpr.jar -recognize -i test_001.jpg
PP587A0
real	0m14.687s
user	0m11.700s
sys	0m0.750s
With server vm:
pi@raspberrypi ~/Desktop/Mono/MatriculasTest2 $ time java -server -jar javaanpr.jar -recognize -i test_001.jpg
PP587A0
real	0m28.616s
user	0m27.910s
sys	0m0.290s
It seems every jvm has weakness, so I am not sure how it will affect your tests. But in my case cacao works awesome. After these tests I added another mode to the code + cacao, and each solve operation was under 2 secs after these changes :D (so it is very relevant the spectrum of the thing you execute, I am guessing the server vm gets better times with networking stuff just for the name)
Posted: Fri May 31, 2013 10:45 am
by jamesh
RoyLongbottom wrote:Latest conversion is BusSpeed with the benchmark and source code included in:
Roy
This is probably down to the cache not having a stride detecting prefetcher on L2 cache. Any ordered traversal of memory benchmark would benefit from that.
Note that we have optimised the various memxxx() functions to the Armv6 architecture, which would be worth experimenting with.
Posted: Fri May 31, 2013 12:53 pm
by RoyLongbottom
Herewith results. Yes, Cacao is much faster than JamVM, except for the COS/EXP tests, but not as fast as JRE 8.
  Original    6&7   18.3    4.4    6.4    3.3   0.99   0.30    7.9    2.9    2.5
  Cacao         6   32.7   25.5   36.7   25.7   0.76   0.24   55.2   28.9   25.8
Roy
Posted: Fri May 31, 2013 5:30 pm
by eried
Roy
Excellent! JRE8 was installed from official instructions right? is the 'oracle' official?
Posted: Fri May 31, 2013 8:25 pm
by RoyLongbottom
> Excellent! JRE8 was installed from official instructions right? is the 'oracle' official?<
JRE 8 was installed using commands provided in the following:
http://raspberrypi.stackexchange.com/qu ... spberry-pi
I was a little concerned about the License Agreement which seemed to imply that results should not be published.
Posted: Sun Jun 02, 2013 9:57 am
by RoyLongbottom
JavaDraw is the second Java benchmark arranged to run on the Raspberry Pi. It comes in two flavours to run off-line. The first, JavaDrawPC.class (use command java JavaDrawPC), was produced via Linux Ubuntu and JDK 6. The second, JavaDrawPi.class, was compiled on the Pi using JDK 7 (command javac JavaDrawPi.java). The JDK 6 version can be run (so far) via Windows, Linux and Raspbian using any JRE but the Pi compilation, at least, will not run using Ubuntu with JRE 6. The benchmarks and source code are in:
The benchmark uses small to rather excessive simple objects to measure drawing performance. The source code that does the drawing is only 125 lines and might be of interest for others to play with.
There are five tests. The first loads two PNG files and moves them about. This is repeated as slow startup time produces misleading performance. The second test adds two moving multi-coloured circles, again from PNG files. The next tests add 200 random small circles (blobs), then 320 long lines, with the last test filling the screen with 4000 random blobs.
Results are below via various JREs, where, at least, the Pi can be as fast as a Nexus 7 tablet. Note that JRE 8 is particularly slow.
                               Speed in Frames Per Second (FPS)
                           PNG       PNG     +Sweep     +200       +320    +4000
                         Bitmaps   Bitmaps  Gradient    Small      Long     Small
                  JRE       1         2      Circles   Circles    Lines    Circles
  Pi    700 MHz     6      3.6      12.0      11.9       9.5       5.5       1.8
  Pi    700 MHz     6 Cac  0.2      13.6      14.7      12.4       7.2       2.8
  Pi    700 MHz     7      2.4      11.7      11.6       9.5       5.6       1.9
  Pi    700 MHz     8      0.4       2.7       2.6       1.9       0.8       0.4
  Pi   1000 MHz     6     10.1      19.5      19.3      15.9       9.4       3.1
  Pi   1000 MHz     6 Cac  8.3      23.1      21.9      18.2      11.0       4.2
  Pi   1000 MHz     7     11.1      19.2      18.7      16.2       9.5       3.1
  Pi   1000 MHz     8      2.0       4.3       4.2       3.0       1.3       0.6
  Nexus 7 1300 MHz                  20.4      16.5      14.5      11.3       3.8
  Atom    1666 MHz        57.3      83.2      80.1      74.8      53.6      24.5
  Core 2  2400 MHz       271.5     360.6     227.7     237.6     205.2     142.5
                      Cac = Cacao VM
Roy
Posted: Sat Jun 15, 2013 5:23 pm
by RoyLongbottom
I have now converted my Android OpenGL benchmark to run on RPi. As usual, the benchmarks and source code are in:
The benchmark has four tests - wireframe, shaded, more objects shaded, textured. Four loadings are run with 900, 9000, 18000 and 36000 triangles drawn. The run command allows different window sizes to be used. For results using these and further details of the benchmark, see:
Also provided are some Android Java based results, where the RPi appears to be as fast as the Nexus 7 tablet. An example of RPi results at default MHz follow. According to many posts, it seems that the RPi does not implement VSYNC that would limit speed at 60 FPS. However, further tests using an absolute minimum of triangles could not better 100 FPS. so that looks like the minimum overhead on using eglSwapBuffers. Without the latter (and without any picture displayed) 370 FPS was produced (see results).
 Raspberry Pi OpenGL ES Benchmark 1.1, Thu Jun 13 16:04:35 2013
           --------- Frames Per Second --------
 Triangles WireFrame   Shaded  Shaded+ Textured
    900+     100.22    99.97    86.96    78.91
   9000+      40.04    39.85    29.94    23.28
  18000+      20.27    20.24    17.32    12.82
  36000+      10.19    10.18     9.38     6.88
      Screen Pixels 1280 Wide 720 High
      End Time Thu Jun 13 16:07:16 2013
Posted: Fri Jun 21, 2013 3:10 pm
by RoyLongbottom
As reported in the following post, I have produced a simple RPi temperature recording program for use with my benchmarks for testing system stability/reliability.
http://www.raspberrypi.org/phpBB3/viewt ... 31&t=47469
I have added run time parameters to my OpenGL benchmark to execute the most exhaustive tests for extended periods and have run this, along with my Livermore Loops Stability tests to see what happens on overclocking. Note that OpenGL by itself generated only about 50% CPU utilisation, providing scope for multitasking. On the day (cooler than yesterday), maximum temperature running the OpenGL program, for 15 minutes at 700 MHz, was 67°C, increasing to 69.7°C by also running the Livermore Loops. With maximum 1 GHz overclocking and OpenGL, 69.1°C was reached.
With OpenGL and Livermore Loops running on the overclocked RPi, it bombed out after 75 seconds, with an illegal instruction and recorded temperature of 72.9°C. Restarting OpenGL repeated an earlier experience by freezing the display. Details can be found in:
and the temperature recording program, along with benchmarks, in the usual
Posted: Sat Jun 29, 2013 1:38 pm
by RoyLongbottom
I have now converted my DriveSpeed benchmark to run on the Raspberry Pi. It can mearure performance of the main drive plus any USB attached SD cards, USB sticks and disk drives. There are four test procedures:
Test 1 - Write and read three 8 and 16 MB; Results given in MBytes/second
Test 2 - Write 8 MB, read can be cached in RAM; Results given in MBytes/second
Test 3 - Random write and read 1 KB from 4 to 16 MB; Results are Average time in milliseconds
Test 4 - Write and read 200 files 4 KB to 16 KB; Results in MB/sec, msecs/file  and delete seconds.
Example results for the main SD drive are below. A link to the source and execution files, results on external devices, along with details of how to set up the directory paths, are in:
   DriveSpeed RasPi 1.0 Tue Jun 25 14:01:02 2013
 Current Directory Path: /home/pi/benchmarks/drivespeed
 Total MB   14685, Free MB   12737, Used MB    1948
                        MBytes/Second
  MB   Write1   Write2   Write3    Read1    Read2    Read3
   8     9.10     9.15     9.14    22.68    22.73    22.77
  16     9.94    10.26    10.25    22.75    22.78    22.80
 Cached
   8    43.35    37.41    58.10   157.41   156.62   157.34
 Random         Read                       Write
 From MB        4        8       16        4        8       16
 msecs      0.019    0.019    0.043     9.07    15.32     9.45
 200 Files      Write                      Read                  Delete
 File KB        4        8       16        4        8       16     secs
 MB/sec      0.09     0.11     0.16     4.31     7.49    11.40
 ms/file    46.73    72.37   105.14     0.95     1.09     1.44    0.039
                End of test Tue Jun 25 14:02:17 2013
Posted: Wed Jul 17, 2013 10:39 pm
by RoyLongbottom
LAN and WiFi Benchmark Programs
The latest benchmark is a variation of the last one (DriveSpeed) designed to measure performance on passing data over Local Area Networks (LANs) and WiFi. There are three programs to do the job, LanSpeed that runs on the Raspberry Pi/ARM CPU, LanSpdx86Lin for Intel/Linux PCs and LanSpdx86Win for Intel/Windows systems. They are all included in
In this case, Linux PCs, Windows PCs and the RasPi are connected via a Router, also providing WiFi access, and via a Windows Workgroup set up. For each system, different procedures or commands are needed to set up the links, log on and enable access. Details of these and various results are in:
Besides demonstrating likely maximum data transfer speeds, the benchmark programs show that there can be significant performance differences, depending on which system is controlling the transfer. Following shows RPi to Windows, Windows to RPi and RPi to Linux, Linux to RPi MBytes per second, writing and reading 16 MB files.
 Source  Dest                             MBytes/Second
 CPU     CPU/drive     MB  Write1  Write2  Write3   Read1   Read2   Read3
 Rpi     Ph Win        16    7.29    8.13    6.78   11.53   11.60   11.58
 Ph Win  Rpi           16   11.29   11.18   10.70    4.22    2.70    1.97
 Rpi     C2 Lin        16    7.79    7.52    7.84   11.62   11.61   11.66
 C2 Lin  Rpi           16    6.53    6.36    6.23    5.58    5.49    6.01
Then average times for writing and reading small files of 4 KB, 8 KB and 16 KB:
                               milliseconds per file
 Rpi     Ph Win      6.63    6.83    7.68    3.88    5.07    5.98    0.28
 Ph Win  Rpi        14.15   14.21   15.76   10.32   10.52   11.47    1.79
 Rpi     C2 Lin      5.74    6.83    8.96    4.87    5.97    6.74    0.60
 C2 Lin  Rpi         9.87   10.55   11.73    7.13    7.52    8.44    1.30
Other results provided are for random access, local and distant WiFi, and Gigabit LAN.
Posted: Wed Jul 31, 2013 2:47 pm
by RoyLongbottom
The latest additions are MultiThreading Benchmarks, essentially the same as my Android progams described, along with results, in:
http://www.roylongbottom.org.uk/android ... hmarks.htm
All run the benchmarks using 1, 2, 4 and 8 threads. Those that use caches and RAM have data sizes around 12.8 KB, 128 KB and 12.8 MB. Further details and results can be found in
These will be of more use if a Raspberry Pi appears with more than one CPU core. The benchmarks and source codes are available in:
The latter also includes identical code compiled for Intel compatible processors running under Linux.
MP-MFLOPS - measures floating point speed on data from caches and RAM. The first calculations are as used in MemSpeed. Others use more calculations on each data word. Each thread carries out the same calculations but accesses different segments of the data. The result, on cache based calculations, is often performance proportional to the number of cores used.
MP-Whetstone - Multiple threads each run the eight test functions at the same time, but with some dedicated variables. Measured speed is based on the last thread to finish, with Mutex functions, used to avoid the updating conflict by only allowing one thread at a time to access common data. Again performance is generally proportional to the number of cores used. There can be some significant differences from the single CPU Whetstone benchmark results on particular tests due to a different compiler being used.
MP-Dhrystone - This runs multiple copies of the whole program at the same time. Dedicated data arrays are used for each thread but there are numerous other variables that are shared. The latter reduces performance gains via multiple threads and, in some cases, these can be slower than using a single thread.
MP-BusSpeed - This runs integer read only tests using caches and RAM, each thread accessing the same data sequentially. To start with, data is read with large address increments to demonstrate burst data transfers. Performance gains, using L1 cache, can be proportional to the number of cores, but not quite so using L2. The program is designed to produce maximum throughput over buses and demonstrates the fastest RAM speeds using multiple cores.
MP-RandMem - The benchmark has cache and RAM read only and read/write tests using sequential and random access, each thread accessing the same data but starting at different points. It uses the Mutex functions as in Whetstone above, sometimes leading to no performance gains using multiple threads. Random access is also demonstrated as being relatively slow where burst data transfers are involved.
Posted: Fri Oct 11, 2013 10:32 am
by RoyLongbottom
Raspberry Pi Stress Tests
I am currently producing a series of stress tests for the Raspberry Pi, based on my reliability/burn-in programs for Windows and Linux. Links can be found in:
http://www.roylongbottom.org.uk/#anchorReliability
For reliability testing purposes, these programs have run time parameters that determine running time and, sometimes, which particular hardware to use. Most also include performance measurements, reported at regular intervals, to identify speed reductions due to such as overheating or system interference. The test programs can be run via command lines in shell scripts, including allowing multiple programs to be run at the same time, each in its own Terminal window. The commands sometimes include an option for different log file names, for cleaner results when more than one copy of the same program is run. A temperature recording application can be included in the mix. All test programs check numeric answers or data transfers for correct or consistent values and report in the log files if incorrect.
The first example is included in the following benchmark report. This is for a benchmark running in a reliability testing mode, alongside my OpenGL benchmark and temperature measuring program. In this case, the RPi crashed due to overheating when overclocked.
http://www.roylongbottom.org.uk/Raspber ... m#anchor29
There will be three new tests. The first is for floating point instructions, where a run time parameter selects data volume and FPU loading, to test CPU, L1 cache, L2 cache or RAM. The second does the same sort of thing except using integers. The third is a drive test that can be used to test the SD card, USB connected drives or LAN based storage. All can be run for extended periods, if desired. The main use will be to provide peace of mind in showing that particular hardware might not really be faulty. I will start a new topic for these tests.
Posted: Fri Oct 11, 2013 12:13 pm
by jamesh
Odd, the CPU isn't getting hot enough to drop its frequency - think that happens at 80degC which I think is where throttling comes in. So I'd say the fault wasn't caused overheating (of the SoC). Dom will maybe have more information - I'll prod him to take a look.
Have you tried just the one device? And is your GPU firmware up to date? You may have exposed an issue elsewhere that may have been fixed.
Posted: Fri Oct 11, 2013 12:29 pm
by mcgyver83
I'm looking for a test suite that can provide some feelings regarding performances inprovment reached by overclock.
Can you suggest a suite or a single utility that can run a set of test?
Posted: Fri Oct 11, 2013 2:08 pm
by RoyLongbottom
mcgyver83 wrote:Hi,
My benchmarks are described in the following, with normal and overclocked results shown.
Benchmarks and source codes are in the following. Downloaded benchmarks need execution permission setting. You can change source codes if you want - all FREE.
Posted: Fri Oct 11, 2013 2:25 pm
by RoyLongbottom
jamesh wrote:Odd, the CPU isn't getting hot enough to drop its frequency - think that happens at 80degC which I think is where throttling comes in. So I'd say the fault wasn't caused overheating (of the SoC). Dom will maybe have more information - I'll prod him to take a look.
How accurate is the temperature monitor? Although not done scientifically, on a recent test, I poked my temperature probe wire through the hole onto the chip and measurements were similar to the programmed recorder. So is the latter measuring case temperature and does the 80degC spec reflect this or core temperature that will be higher? Then which core CPU or GPU?
I only have one RPi and have not upgraded GPU firmware. Perhaps you could provide a link that tells me how to do it.
Posted: Fri Oct 11, 2013 2:50 pm
by jamesh
sudo rpi-update
gets the latest released firmware. This is bleeding edge, so may have rough edges, but is usually fine. Lots of people use it. If you dont have rpi-update, get it here https://github.com/Hexxeh/rpi-update
The SoC itself is mostly GPU - that takes up the majority of the die area. The temp monitor is on the GPU and is pretty accurate IIRC. Not sure exactly how it works though. It is I believe what is used by the dynamic clocking to ensure the chip doesn't get too hot.
