curlypete
DBD::MYSQL Does anyone use this to write to mysql on a RPI?
Thu May 16, 2013 1:55 pm
I have been look for a way to write 2 values to a mysql database i host on the internet.
What is the best way to do this as i have tried to install lots of modules for PERL which dont seems to install the DBD:mysql part due to a DBI issue apparently!
ive tried lots of things but i am losing the will to live with it
can anyone suggest a better way to write to a mysql database on the internet from a raspberry PI?
thank you
curlypete
Re: DBD::MYSQL Does anyone use this to write to mysql on a R
Thu May 16, 2013 6:28 pm
This is what i get when i try to follow the guide on http://search.cpan.org/~capttofu/DBD-my ... D/mysql.pm
[email protected] ~/DBIstuff/DBD-mysql-4.023 $ perl Makefile.PL
Can't exec "mysql_config": No such file or directory at Makefile.PL line 83.
Cannot find the file 'mysql_config'! Your execution PATH doesn't seem
not contain the path to mysql_config. Resorting to guessed values!
Can't exec "mysql_config": No such file or directory at Makefile.PL line 479.
Can't find mysql_config. Use --mysql_config option to specify where mysql_config is located
PLEASE NOTE:
For 'make test' to run properly, you must ensure that the
database user 'pi' can connect to your MySQL server
and has the proper privileges that these tests require such
as 'drop table', 'create table', 'drop procedure', 'create procedure'
as well as others.
mysql> grant all privileges on test.* to 'pi'@'localhost' identified by 's3kr1t';
You can also optionally set the user to run 'make test' with:
perl Makefile.PL --testuser=username
Failed to determine directory of mysql.h. Use
perl Makefile.PL --cflags=-I<dir>
to set this directory. For details see the INSTALL.html file,
section "C Compiler flags" or type
perl Makefile.PL --help
does anyone know whats up with my OS/ PERL or DBD / DBI from the errors i get when i try to PERL Makefile.PL?
thanks
curlypete
Thu May 16, 2013 6:30 pm
and this when i try to run a code with
USE DBI
USE DBD::mysql
on the first few lines
[email protected] ~/temperature2 $ sudo perl sqlupdate.pl
Can't locate DBD/mysql.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at sqlupdate.pl line 6.
BEGIN failed--compilation aborted at sqlupdate.pl line 6.
Gibble
Fri May 17, 2013 7:14 pm
Not sure if you're overcomplicating things..
sudo apt-get install libdbd-mysql-perl
Shout if you get any errors.
curlypete
Mon May 20, 2013 11:10 am
thanks gibble :)
the software works now.
davidtuti
Sat Mar 01, 2014 11:14 pm
When I try to install these package in the raspberry freezes and I cant install
Any help?
hoholok
Sun Sep 13, 2015 3:51 am
davidtuti wrote:Hi,
Any help?
i have the same problem in arch. I tried install DBI through CPAN, and it also can't find it.
don't know what to do, really don't want to install DBI from source, but it seems like the only working way :c
