If nothing is hooked up to a GPIO pin, does the OS read it as HIGH or LOW. I am trying to run a python script to shut down the Pi safely when a GPIO is set to high. With no GPIO pins connected, pin 2 is reading HIGH. Is this the normal behavior?
import RPi.GPIO as GPIO
import time
import os
GPIO.setmode(GPIO.BCM)
GPIO.setup(2, GPIO.IN)
GPIO.setup(23, GPIO.OUT)
print("Shutdown script started. Wait for shutdown request")
while True:
GPIO.output(23, GPIO.HIGH) // sent HIGH to arduino - lets arduino know PI is running
if(GPIO.input(2)):
print("Request from button to shutdown")
os.system("sudo shutdown -h now")
break
time.sleep(1)
