KRIS537
Installing JMRI
Thu Mar 07, 2013 11:55 pm
Im trying to install the JMRI software http://jmri.org/ (Java Model Railway Interface. I have previously had this running on Windows, but now want it on a RPI as its quicker and takes less room thab the pc will.
But im having issues installing the software. I install rasbian but I cannot get it to install the software. I have looked at various thing but cant find anything on the net to help me. Its basically not reconising the download file and wont extract it.
Cloudcentric
Re: Installing JMRI
Fri Mar 08, 2013 5:09 am
http://jmri.org/install/Linux.html
The installation overview is for x86 architecture, the Pi has ARMv6 Architecture
The Operating System is Raspbian "wheezy" and I presume you installed Java ?
sudo apt-get install icedtea-7-plugin
http://javatester.org "What Version of Java Are You Using?"
also see http://www.raspberrypi.org/phpBB3/viewt ... 65&p=14110
I know everything about nothing"
KRIS537
Re: Installing JMRI
Thu Mar 14, 2013 2:30 pm
hi yes i installed java form here http://jdk8.java.net/fxarmpreview/index.html
which should be version 1.8.0
I have managed to unzip JMRI but I cannot get it to load. in the raspian software.
Spid
Re: Installing JMRI
Thu Mar 14, 2013 6:57 pm
As said it is compiled for x86 intel architecture, you need to build from 'source' for the ARMv6 Pi
I will always assume you are running Raspbian for desktop and Raspbmc for XMBC !
-rst-
Re: Installing JMRI
Sat Mar 16, 2013 6:24 pm
Also note that JMRI seems to use Swing for the user interface - this is not supported in that JDK8 preview - you would need to use one of the OpenJDK variants...
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
