richiepp
html on/off buttons JavaScript(?)
Sat Dec 29, 2012 11:52 pm
Hey All,
I tried to do this with Arduino a couple of years ago and failed. I'm trying to make on/off toggle buttons to use on html pages. Here's the functionality I'm after
Submit button - Could be text but prefer an image "Off"
When I hit that button it links to a shell script <a href="on.sh">
Stays on the same page
Changes image to "On"
Changes link to <a href="off.sh">
Anyone know how to do this?
The solution at the bottom of this page is the closest thing I've found. I'd tweak it but my JavaScript isn't that strong.
http://www.htmlforums.com/html-xhtml/t- ... 15361.html
How can I do swap the images and include swapping hyperlinks?
Any help is appreciated.
Rich
Alesfatalis
Re: html on/off buttons JavaScript(?)
Mon Dec 31, 2012 1:17 am
Hey you can to this with php and ajax. With ajax and php (combination) you can check lets say every 2 seconds for the status of the pi. The when the status change you can display a different image with a different link. I must be all doable with php and ajax. You should have a look at the http://php.net/manual/en/index.php and http://api.jquery.com/category/ajax/ documentation. A good site i recommend for asking programming questions like this is: http://stackoverflow.com/
Hope i could help you a little bit ;)
EdwinJ85
Wed Jan 02, 2013 11:47 pm
You don't even need to use PHP, there are python libraries that can handle serving HTML pages up and handing the response. Saves on installing yet another runtime!
It's all in the education manual posted on the front page of the main site recently, have a gander.
Hello!
richiepp
Fri Jan 04, 2013 9:31 pm
Cool, I'll check this out next time I get some Pi time :P :P
Rich
Xezz
Sat Jan 05, 2013 4:56 pm
A simpler primer for your javascript/html would be to have a look at document.getelementbyid() and then manipulate the dom, aka replace the href value and img src.
My javascript foo is a bit rusty, so you have to look up the correct functionnames and parameters yourself.
<img src="off.png" id="buttongfx">
<a href="on.sh" id="link">
you would then do something like this:
button = document.getElementById("buttongfx");
// do something with this element (change the src to "on.png")
link = document.getElementById("link");
// change href to off.sh
I'd highly recommend you to have a look at jQuery and Ajax, as you can not "just" run a shellscript in a browser. php for example has the possibility to run scripts with the shellexec command.
-rst-
Mon Jan 07, 2013 3:02 pm
For switching the button images the link in the original post is a very nice solution. This should work as is in a 'self-contained' HTML page - maybe you tried it already...
But are you aware that for calling the 'on/off' scripts, you will need web-server (either a full server like Apache or your own app in f.eg. Python)?!
As per your requirement 'stay on the same page', learn to do AJAX calls and preferably do NOT use <a> tags (well, you can tweak these too, but any other elements can handle 'onclick's much cleaner). You could just extend the 'togglestyle' function in that code from the link to do the AJAX calls in addition to switching the images.
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
