finlay-rg1
Can't run snake pygame
Fri Dec 21, 2012 10:16 am
I have written the snake pygame code into IDLE exactly as shown in the Users Guide (pages 162 to 171) but when I try to run it I get the following message.
Python 2.7.3rc2 (default, May 6 2012, 20:02:25)
[GCC 4.6.3] on linux2
Type "copyright", "credits" or "license()" for more information.
>>> ================================ RESTART ================================
File "/home/pi/pygame.py", line 2, in <module>
import pygame, sys, time, random
File "/home/pi/pygame.py", line 3, in <module>
from pygame.locals import *
ImportError: No module named locals
Does anyone out there know what this means and what I should do to run the game?
MattCook
Re: Can't run snake pygame
Fri Dec 21, 2012 11:44 am
It looks like you have a program called pygame.py, which is trying to import the pygame module. If this is the case, I would try saving the program with a different name - probably snake.py or something similar, so you know what it is.
Let us know how that goes, and if it doesn't work, then can you include the first few lines of your source ?
Matt
finlay-rg1
Fri Dec 21, 2012 12:04 pm
Thanks Matt Cook.
I saved using snake.py as suggested but it did not solve the problem. I can open pygames in my pi directory so it seems to have downloaded successfully. Here is the code.
#!/usr/bin/env python
pygame.init()
fpsClock = pygame.time.Clock()
playSurface = pygame.display.set_mode((640, 480))
pygame.display.set_caption('Raspberry Snake')
redColour = pygame.Color(255, 0, 0)
blackColour = pygame.Color(0, 0, 0)
whiteColour = pygame.Color(255, 255, 255)
greyColor = pygame.Color(150, 150, 150)
snakePosition = [100,100]
snakeSegments = [[100,100],[80,100],[60,100]]
raspberryPosition = [300,300]
raspberrySpawned = 1
direction = 'right'
changeDirection = direction
def gameOver():
gameOverFont = pygame.font.Font('freesansbold.ttf', 72)
gameOverSurf = gameOverFont.render('Game Over', True, greyColour)
gameOverRect = gameOverSurf.get_rect()
gameOverRect.midtop = (320, 10)
playSurface.blit(gameOverSurf, gameOverRect)
pygame.display.flip()
time.sleep(5)
pygame.quit(1)
sys.exit()
while True:
for event in pygame.event.get():
if event.type == QUIT:
pygame.quit()
sys.exit()
elif event.type == KEYDOWN:
if event.key == K_RIGHT or event.key == ord('d'):
changeDirection ='right'
if event.key == K_LEFT or event.key == ord('a'):
changeDirection = 'left'
if event.key == K_UP or event.key == ord('w'):
changeDirection = 'up'
if event.key == K_DOWN or event.key == ord('s'):
changeDirection = 'down'
if event.key == K_ESCAPE:
pygame.event.post(pygame.event.Event(QUIT))
if changeDirection == 'right' and not direction == 'left':
direction = changeDirection
if changeDirection == 'left' and not direction == 'right':
if changeDirection == 'up' and not direction == 'down':
if changeDirection == 'down' and not direction == 'up':
if direction =='right':
snakePosition[0] += 20
if direction == 'left':
snakePosition[0] -= 20
if direction == 'up':
snakePosition[1] -= 20
if direction == 'down':
snakePosition[1] += 20
snakeSegments.insert(0,list(snakePosition))
if snakePosition[0] == raspberryPosition[0] and snakePosition[1] == raspberryPosition[1]:
raspberrySpawned = 0
else:
snakeSegments.pop()
if rasperrySpawned == 0:
x = randon.randrange(1,32)
y = randon.randrange(1,24)
rasperryPosition = [int(x*20),int(y*20)]
playSurface.fill(blackColour)
for position in snakeSegments:
pygame.draw.rect(playSurface,whiteColour,Rect(position[0], position[1], 20, 20))
pygame.draw.rect(playSurface,redColour,Rect(raspberryPosition[0], raspberryPosition[1], 20, 20))
if snakePosition[0] > 620 or snakePosition[0] < 0:
gameOver()
if snakePosition[1] > 460 or snakePosition[1] < 0:
gameOver()
for snakeBody in snakeSegments[1:]:
if snakePosition[0] == snakeBody[0] and snakePosition[1] == snakeBody[1]:
gameOver()
fpsClock.tick(20)
gordon77
Fri Dec 21, 2012 2:54 pm
Hopefully it now works as expected.
A few typos, eg Rasperry, Randon, color...and identation missing.
It starts with a blank screen and you have to press an arrow key to start
Gordon77
pygame.init()
greyColour = pygame.Color(150, 150, 150)
snakeSegments = [(100,100),(80,100),(60,100)]
direction = 'right'
def gameOver():
    time.sleep(5)
    pygame.quit()
    sys.exit()
while True:
            pygame.quit()
            sys.exit()
          else:
             snakeSegments.pop()
          if raspberrySpawned == 0:
             x = random.randrange(1,32)
             y = random.randrange(1,24)
             raspberryPosition = [int(x*20),int(y*20)]
             gameOver()
             gameOver()
                gameOver()
                fpsClock.tick(20)
Pnb116
Sun Dec 30, 2012 11:53 am
I have the same problem. I have copied the program from two sources now and it still will not run. This suggests that there is something wrong with the pygame module or where it is stored. Any suggestions anyone?
Pnb116
Sun Dec 30, 2012 1:08 pm
Ok, I have narrowed it down. I can run the program from the LX terminal using python raspberrysnake.py and it runs, but it won't work from Idle3 when I use f5 or run module, it says no module named pygame.
techpaul
Sun Dec 30, 2012 1:34 pm
Because it is python 2 code use IDLE instead of idle3.
pygame I dont believe yet has python3 support
Just another techie on the net - For GPIO boards see http:///www.facebook.com/pcservicesreading
or http://www.pcserviceselectronics.co.uk/pi/
Dancerbear
Fri Sep 01, 2017 2:39 pm
Hi i am new to the pi and was trying the raspberry snake so i copied the code out of the user guide but i cant understand why it isn't working. Here is the code:
#python raspberry snake
pygame.init()
pygame.display.set_caption('raspberry Snake')
snakeSegments = [[100,100], [80,100], [60,100]]
direction = 'right'
def gameOver():
    time.sleep(5)
    pygame.quit()
    sys.exit()
while True:
            pygame.quit()
            sys.exit()
                changeDirection = 'right'
        if direction == 'right':
            raspberrySpawned =0
        else:
            snakeSegments.pop()
            gameOver()
            gameOver()
                gameOver()
        fpsClock.tick (20)
I would find it really helpful if you can point me in the right direction.
Thanks again
Leanne
(p.s. i'm running it in idle 2.7.9)
Moderator added code tags
gordon77
Fri Sep 01, 2017 5:43 pm
Does it report any errors when run?
gordon77
Sun Sep 03, 2017 9:03 am
I tried this and it gives no errors and appears to work OK.
Just press the keyboard arrow keys to move. When you hit the red dot it will move to a new random position, if you hit the edge of the window it will be game over.
Leannehendry
Tue Sep 12, 2017 6:18 pm
hi i am new to the pi and just wanted to do a basic bit of programming to get used to it so i decided to use the raspberry snake but for some reason it isn't running. when we enter the game it doesnt move untill i press a jey bu tit will work with any key and doesnt move all the time like it should. here is the code, would really apprciate some help:
pygame.init()
direction = 'right'
def gameOver():
    time.sleep(5)
    pygame.quit()
    sys.exit()
while True:
            pygame.quit()
            sys.exit()
            raspberrySpawned =0
        else:
            snakeSegments.pop()
            gameOver()
            gameOver()
                gameOver()
        fpsClock.tick (20)
thanks again for any help.
p.s. i running it in python 2.7.9
Leannehendry
Wed Sep 27, 2017 2:33 pm
Same person here (just on another accaount). should the "snake" move on a time basis independent of the direction keys or does it move only when a key is pressed i.e. The longer you hold a key down the further it will move? This type of arcade game normally operates by moving on its own as it were and the operator just changes direction and I thought that was what the fps command at the end of the code would control. Videos we have seen seem to suggest it moves on a time basis.
Thanks for any help you have and can further supply.
