sayhello
the Visual Studio Code - i want to get it to work with the RaspBerry Pi
Wed Sep 18, 2019 3:12 pm
Dear Community,
which extensions do i need to add?
The whole design of Visual Studio Code is so that it should be easily be configured for any development language using these extensions. Do i need to install the Arduino IDE? if i am able to go roound the Arduino IDE - i would be happy.
Like most of the IDE's I have tried, they rely on the Arduino IDE for all the libraries. - but if i am able to work with VS-Stidio-Code and Raspberry Pi directly i would be happy.
how to set it up and to make sure that i have fully configured Visual Studio Code to work with all the necessary add-on for ESP8266
which extensions i should add and install?
note: i am on Windows 7
Re: the Visual Studio Code - i want to get it to work with the RaspBerry Pi
Wed Sep 18, 2019 3:42 pm
This is a Raspberry Pi forum. Not an Arduino or ESP8266 or Windows 7 forum.
Personally I would not use VS Code for the Arduino. I would use the Arduino IDE. How simple could it be?
royhenderson
Thu Sep 19, 2019 11:08 am
VS Code supports remote development although at this time you might still need to use the Insider version. I use it on my Mac to work on an RPi-4 and the results are pretty good. You may need to install the remote extensions, then setup ssh to the Pi and you should be ready to edit directly on the Pi with transparent connection.
DirkS
Thu Sep 19, 2019 11:29 am
Apparently only necessary for 64-bit target environment
https://code.visualstudio.com/docs/remo ... ng-started
