oh7fxk
Onewire temperature logging
Sun Dec 09, 2012 12:35 pm
Evening, I have an DS18S20 chip connected via GPIO to my RPi.
I have tried to get my RPi read temperature once a hour from it and after that to write it in .txt or .html file.
So far, I can get it only make an file, no more.
And my way to do that takes 100% CPU load.
So, how to do that easier?
joan
Re: Onewire temperature logging
Sun Dec 09, 2012 12:55 pm
#!/bin/bash
while true
do
temperature=`your program to read chip`
echo $temperature >>logfile
sleep 3600
done
jamiesk
Sun Dec 09, 2012 2:52 pm
Be much easier to put the program into a cron job. The cron job set to run every hour. Note that any paths etc you need will have to be setup. I usually call the program from a bash script. So the one supplied would look like...
#!/bin/bash
Pi1 (Nov 2012 loft)= 1KW immersion controller for Solar panel
Pi2 (Jan 2013 living room)=Play thing
Pi3 (Feb 2013 mobile)= Play thing with Tandy Ladder board,breakout board,Nokia display
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=26&t=28193
oh7fxk
Sun Dec 09, 2012 3:04 pm
Both ways work well, but there is one problem, it's allways writes over old temperature.
And my way to add timestamp looks explode whole bomb.
jamiesk
Sun Dec 09, 2012 6:37 pm
You are using TWO greater than signs ? One makes the file EXACTLY what you put in to it. Two appends to the end.
Show us your script and we might be able to help.
