Pinado
Temperature Sensors
Fri Jul 26, 2019 3:27 pm
Hello all! I have a RPi 3 B+. I recently got a couple of DAQ HAT(Data Acquisition Hardware attached on Top) sensors from Measurement computing corporation and I would like to set them up to record the temperature continuously, but I am not a very good programmer. I found some code here: https://github.com/mccdaq/daqhats/blob/ ... /mcc118.py but I do not know if it is what I am looking for. Any help would be appreciated!
Or if there is a better spot to put this, please let me know as well
John_Spikowski
Re: Temperature Sensors
Sat Jul 27, 2019 4:15 pm
Can you post the temperature sensor model number so we can get a better idea what the interface requirements might be?
Pinado
Mon Jul 29, 2019 3:38 pm
The temperature sensor number is MCC-118. Also, here is the installation manual I found if it helps: https://mccdaq.github.io/daqhats/hardware.html
John_Spikowski
Sun Aug 18, 2019 2:09 am
It looks from the help reference you posted it is an interrupt driven interface. I haven't tried interfacing with this type of interface yet so hopefully someone that has will chime in.
bensimmo
Sun Aug 18, 2019 9:06 am
You are probably better of asking the makers of the board. They don't seem to give your the Python API they have set up.
Just how to install, the import and an example.
They leave you to study the python module itself.
If you don't know python, that makes it much harder.
I would suggest asking here for example programs and better documentation.
https://www.mccdaq.com/support/support_form.aspx
The is while/if someone works out how they are doing it.
bensimmo
Sun Aug 18, 2019 9:18 am
Is this the HAT
https://www.mccdaq.com/DAQ-HAT/MCC-118.aspx
It looks like it a full blown "Data logging" hat.
You need to attach sensors to it that return their voltage.
So my guess is you attach your thermocouple/thermistor.
Write a program, maybe using the example.they give
#!/usr/bin/env python
# MCC 118 example program
# Read and display analog input values
import sys
from daqhats import hat_list, HatIDs, mcc118
# get hat list of MCC daqhat boards
board_list = hat_list(filter_by_id = HatIDs.ANY)
if not board_list:
    print("No boards found")
    sys.exit()
# Read and display every channel
for entry in board_list:
    if entry.id == HatIDs.MCC_118:
        print("Board {}: MCC 118".format(entry.address))
        board = mcc118(entry.address)
        for channel in range(board.info().NUM_AI_CHANNELS):
            value = board.a_in_read(channel)
            print("Ch {0}: {1:.3f}".format(channel, value))
And I've found the API now it at the bottom.of the docs.
It looks like the MC134 is the one designed for temperature/thermocouples.
