bensimmo
Re: Project Digital Apocalypse Not Now
Tue Jul 16, 2019 9:42 am
I have no idea what popular fictional characters those might be. Perhaps we can find something.
You mean, like if the teletubbies was still popular?
Tue Jul 16, 2019 10:28 am
BINGO!
Teletubies, all grown up and gigantically huge and slow.
Meanwhile Zebedee is still bouncing around and helping people out when they have a difficult problem.
ejolson
Tue Jul 16, 2019 6:05 pm
I'm looking forward to the new picture. I suspect it will be even more popular than the first.
To think, it's all because of the digital apocalypse which started that fateful year in 1976.
timrowledge
Re: A Final Fibonacci Challenge
Fri Jul 19, 2019 5:12 am
gkreidl wrote:
Wed Jun 26, 2019 6:09 pm
Taking out the check for 0 is a good idea. My Python function now looks like this:
{snip}
Nice! That gets the calculation time for Squeak on my Pi3b+ to ~4.5sec. A clear and simple improvement from the ~6secs of the prior version.
Making Smalltalk on ARM since 1986; making your Scratch better since 2012
Fri Jul 19, 2019 5:33 am
timrowledge,
What, do you have a new improved version of your fibo 4784969 solution?
If so I should check it out and up date the Fibo Challenge repository.
I don't follow your mentioning speeds of 4 to 6 seconds on a Pi3b+. When I ran your fibo.cs on an Intel PC it took half a minute.
Or are you talking about some other calculation there?
timrowledge
Sat Jul 20, 2019 3:40 pm
I just took advantage of the nice tweak gkriedel spotted and was pleased to see that it improved the calculation time for the big fib from circa 6secs to circa 4.8. Printing time, obviously, wasn’t changed.
Your 30 second experience was not when using Squeak on an intel machine unless it is a 486 era model. My8 year old i7 iMac does the calculation in less than half a second. Are you perhaps remembering bad experiences with GST?
ejolson
Sat Jul 20, 2019 3:51 pm
The times that have been reported here generally include writing the output to a file. Otherwise the trade-off in doing the calculation more slowly in base 10 to obtain an O(N) print routine that avoids the base conversion doesn't make sense.
Sat Jul 20, 2019 4:30 pm
timrowledge,
It certainly was.
Sadly I no longer have my 486 era machine. Which was a sweet 100MHz AMD K6.
Nope, my "30 second experience" was on an Intel(R) Core(TM) i5-3610ME CPU @ 2.70GHz.
$ time ./bin/squeak -vm-display-null -headless -nosound shared/Squeak5.2-18229-64bit.image  /home/heater/Squeak5.2-18229-64bit-201810190412-Linux/fibo.cs 2>/dev/null | head -c 32
10727395641800477229364813596225
real    0m31.213s
user    0m31.168s
sys     0m0.132s
$ time ./bin/squeak -vm-display-null -headless -nosound shared/Squeak5.2-18229-64bit.image  /home/heater/Squeak5.2-18229-64bit-201810190412-Linux/fibo.cs 2>/dev/null | tail -c 32
4856539211500699706378405156269
real    0m31.279s
user    0m31.208s
sys     0m0.140s
As ejolson notes above, actually producing the decimal output is required to satisfy the challenge. It's kind of pointless otherwise, is it not?
It is interesting that some languages with support for big integer calculation have turned in quite reasonable results for their actual calculation time but fallen down so badly when it comes to actually printing the result. Smalltalk is in good company there with Python and Javascript there.
Gack, don't remind me of that nightmare.
ejolson
Sat Jul 20, 2019 6:20 pm
I suspect the software engineers designing those big number libraries were thinking rather specifically about providing just enough functionality for a textbook implementation of RSA public-key encryption. While that algorithm is running, there is never a need to print out any numbers in base 10 and keys are almost always stored using some sort of base-64 encoding. From a teaching point of view, deriving the doubling formulas necessary to quickly compute large Fibonacci numbers may be a better starting point than trying to understand the dual-base number systems used in the RSA algorithm.
Speaking of encryption, I recently installed WireGuard and found it much easier to use than either IPsec or ssh tunnels. It consists of a kernel module that provides a virtual network device, for example wg0, that participates in a VPN defined using public key pairs. I wonder how easy it would be to network boot a Raspberry Pi over WireGuard?
Unfortunately, unlike the Fibonacci sequence, encryption is not an effective way to prevent the digital apocalypse. Fortunately, those who wish to avoid arithmetic involving rather large numbers but are not similarly scared of anagrams now have something to do.
There has been an separate discussion focusing on whether the C programming language is suitable as a first programming language in this thread. As in the present thread, that discussion has been informed by actual working code in C, Perl, Python, bash and 8th to find all anagrams in the insane British dictionary. Since no example code was given in Basic, I've been wondering whether the onset of the digital apocalypse might be related to bananagrams and the inability of Basic to help with them.
Sun Jul 21, 2019 1:02 am
ejolson,
I suspect the software engineers designing those big number libraries were thinking rather specifically about providing just enough functionality for a textbook implementation of RSA public-key encryption. While that algorithm is running, there is never a need to print out any numbers...
I have been wondering about this...
Given the ridiculously slowness of these languages to actually produce big integer results one wonders why they even bothered adding the feature to the languages. Python, Javascript, Smalltalk for example. I can offer a couple of suggestions...
1) It's cool that ones calculations won't overflow some arbitrary limit imposed by the machines word size that you have forgotten to cater for at some point. A common source of bugs that need not be bugs in languages like C that are happy to produce wrong results and continue for you rather than point out your mistake.
2) I guess that when people do actually want to work with absurdly huge integers often it is not actually required to produce a human readable result, as in your encryption example, so no one worried about the speed of printing results.
But still, things like GMP show that producing the big integer outputs speedily is possible, so why don't these language use those algorithms?
Speaking of Wireguard, I was was recently thinking about checking that out for use in a project. I'd love to hear what your experiences are with it. Perhaps in thread dedicated to it.
I don't see such a secure network boot system making it into the bootloader soon.
jalih
Sun Jul 21, 2019 6:58 am
ejolson,
I think big numbers should be properly integrated into programming language.
With 8th I can print the stack contents and it properly shows:
1    n: 0000000002ddf7e0 1  F 21438616965787467196949606254029645878617458393600018361005357582097219031844287...
8th Converts fibo(47849699) result bfloat to 9999996 digit result 'int' string and outputs into file in just 3984 msecs.
If you include fibo(47849699) calculation time, the result is: 12572 msec
Zebedeee
Sun Jul 21, 2019 11:43 am
Who, me?
Boing. Boing.
Time for bed.
(Sorry this reply is late. Blame the mods, but not too much.)
scruss
Sun Jul 21, 2019 4:35 pm
If only the BASIC interpreters I use (and want to keep using) had hash tables, this would be right easy. But they don't, so it's not.
Pronouns: he/him
John Spikowski
Sun Jul 21, 2019 5:06 pm
ScriptBasic has a hash extension module but I use associative arrays for the same purpose.
ejolson
Sun Jul 21, 2019 6:57 pm
Associative arrays make Script Basic a natural choice for the
Insane British Anagram Challenge.
This challenge is based on the problem originally proposed here.
From my point of view, the anagram challenge is for anyone interested in avoiding the Fibonacci challenge as well as avoiding the digital apocalypse through an increased ability to read and write computer programs. As the present thread is under the "General programming chat and advice for beginners" topic, beginners are especially encouraged to enter as well as the usual crowd and all other forum members.
Specifically, the challenge is
  • Install the insane British dictionary on your Pi using
    $ sudo apt-get install wbritish-insane
  • Choose any suitable or possibly unsuitable programming language.
  • Write a program that
    • Selects only the words consisting of all lower-case characters from the file
      /usr/share/dict/british-english-insane.
    • Outputs those words which are anagrams of each other in the format
    aah: aha
    aahed: ahead
    aahs: ahas
    aal: ala, laa
    aaliis: sialia
    aals: alas, laas, lasa, sala
    zinco: zonic
    zolotink: zolotnik
    zoography: zoogrpahy
    • Note that each word is printed only once. The lines are in alphabetical order and the anagrams on each line are listed in alphabetical order. Note also that zoogrpahy is actually in the dictionary, otherwise it wouldn't be insane.
  • Time how long it takes your program to run on a Raspberry Pi using the command
    # sudo echo performance >/sys/devices/system/cpu/cpufreq/policy0/scaling_governor
    $ time ./myprogram >myoutput.insane
    # sudo echo ondemand >/sys/devices/system/cpu/cpufreq/policy0/scaling_governor
  • Compare your output to the output given by the original Perl implementation.
  • After everything matches report the best total time, the md5sum of the output and what model of Pi.
  • Further post code, tell jokes and ask for help if necessary.
For reference the Perl code is
#!/usr/bin/env perl
# selfgrams.pl - find words that have valid anagrams
# scruss - 2019-07 - may need wcanadian/wbritish/wamerican package
# modified to use the insane British dictionary by ejolson
use v5.20;
my (@words, %grams, @elem, %output, $key, $fh);
# create source word list from system file
open( $fh, '<', '/usr/share/dict/british-english-insane' ) or die "$!\n";
chomp( @words = grep { /^[a-z]+$/ } <$fh> );
close($fh);
# process source word list into hash of anagrams
foreach (@words) {
    # sort word's letters to generate key - eg: 'maps' => 'amps'
    $key = join( '', sort( split( '', $_ ) ) );
    # append word to existing hash match or create if word is new
    @elem =
        ( exists( $grams{$key} ) )
      ? ( @{ $grams{$key} }, $_ )
      : ($_);
    $grams{$key} = [@elem];
# generate output hash of anagrams where key matched > 1 word
foreach ( grep { scalar( @{$_} ) > 1 } values(%grams) ) {
    @elem = @{ $_ };
    $key = shift(@elem);
    $output{$key} = join( ', ', @elem );
foreach ( sort( keys(%output) ) ) {
    say join( ': ', $_, $output{$_} );
exit;
scruss
Sun Jul 21, 2019 7:32 pm
while I'm touched that this has been taken up as a challenge, installing wbritish-insane is considered harmful. It's chock full of typos, so if you use it as your system spelling dictionary, expect troulbe
Pronouns: he/him
ejolson
Sun Jul 21, 2019 7:33 pm
I'm presently working on a version in classic line-numbered Basic that organizes all the anagrams into a heap data structure.
ejolson
Sun Jul 21, 2019 7:38 pm
Note that
$ grep troulbe british-english-insane
shows your troulbe came from someplace else.
From what I understand, as long as you don't also install ibritish-insane there is no danger. It would also be sane to check the default dictionary links in /etc/dictionaries-common to make sure none of them point to anything with insane in the filename.
They've apparently removed zoogrpahy from the dictionary. I wonder if that update made it into the Buster version of Raspbian.
jalih
Mon Jul 22, 2019 10:05 am
I got a version of s:sort word used to sort keys in my 8th program that uses heap from Ron Aaron (8th developer).
Mon Jul 22, 2019 10:07 am
ejolson,
As this seems to be a challenge for anyone who is both British and insane of course I had to step up to the plate. For King and Country and all that. Tally-ho.
Damn you, ejolson, you have just laid waste my entire morning :)
Anyway here is my solution in Javascript:
// selfgrams.js - Find words that have valid anagrams
//                Words sourced from Debian's british-english-insane dictionary
// heater       - 2019-07-22
const readline = require('readline')
const fs = require('fs')
const allLowerCasePattern = /^[a-z]+$/
const anagramSets = {}
const dictionary = readline.createInterface({
    input: fs.createReadStream('/usr/share/dict/british-english-insane'),
dictionary.on('line', function(word) {
    if (allLowerCasePattern.test(word)) {
        let key = word.split('').sort().join('')
        if (anagramSets[key]) {
            anagramSets[key].push(word)
        } else {
            anagramSets[key] = []
dictionary.on('close', function(line) {
    for (let [key, value] of Object.entries(anagramSets)) {
        if (value.length > 1) {
            process.stdout.write(value[0] + ': ' + value[1])
            for (let i = 2; i < value.length; i++) {
                process.stdout.write(', ' + value[i])
            process.stdout.write('\n')
No timings on a Pi yet but this is how it compares to the perl solution on my Debian PC:
$ time node ./selfgrams.js > selfgrams_js.txt
real    0m3.816s
user    0m3.031s
sys     0m1.984s
michael@monster:/mnt/c/Users/michael/conveqs$ time ./selfgrams.pl > selfgrams_pl.txt
real    0m2.531s
user    0m2.078s
sys     0m0.453s
Hmm... 50% slower.
But not so slow that I feel I might have to learn the insanity of a language that is perl thank God.
Technically there is an undefined behavior in that JS. Can anyone spot it?
"zoogrpahy" is still in Buster.
Mon Jul 22, 2019 12:51 pm
After a little tweeking JS can handily match Perl at this:
const file = fs.readFileSync('/usr/share/dict/british-english-insane', 'utf-8');
const dictionary = file.split('\n')
for (let i = 0; i < dictionary.length; i++) {
    const word = dictionary[i]
        } else {
            anagramSets[key] = [word]
let output = ""
        output += value[0] + ': ' + value[1]
            output += ', ' + value[i]
        output += '\n'
process.stdout.write(output)
$ time node selfgrams.js > selfgrams_js.txt
real    0m2.470s
user    0m2.063s
sys     0m0.781s
real    0m2.531s
user    0m2.078s
sys     0m0.453s
scruss
Mon Jul 22, 2019 3:09 pm
… After everything matches report the best total time, the md5sum of the output and what model of Pi.
I believe that the young 'uns do call this “refactoring”
Time: 43.077s (original Perl was 54.713s, so 21% faster)
md5sum: bec74aa3b31577edbb291aeb7269a4d5 (same)
Raspberry Pi Zero, Perl 5 again:
#!/usr/bin/perl -l
# selfgrams4.pl - find words that have valid anagrams
# scruss - 2019-07
my ( %grams, $key, $fh, @out, $k );
foreach ( grep { /^[a-z]+$/ && chomp; } <$fh> ) {
    if ( exists( $grams{$key} ) ) {
        $out[ $grams{$key} ] .= ', ' . $_;
    else {
        $grams{$key} = $k;
        $out[$k] = $_;
        $k++;
close($fh);
print join( "\n", grep { index( $_, ',' ) >= 0 && s/,/:/; } @out );
exit;
Note complete lack of sorting (except for the anagram key) and maintaining the words list's intrinsic sort order by using a keyed array. Perl's hashes are returned in random order while arrays/lists stay sorted. The grep { pattern && effect } @list construct is a gleeful way of subverting the rather pure list processing of the grep function that just came to me. It gives you the list you want and changes it via side effects at the same time!
Let's try Heater's js on the same machine, shall we?
$ time node selfgrams.js > /dev/null
FATAL ERROR: Committing semi space failed. Allocation failed - process out of memory
Aborted
real	2m37.916s
user	1m0.165s
sys	0m2.398s
I am using the ancient Raspbian version of node, but still ...
Pronouns: he/him
ejolson
Mon Jul 22, 2019 5:12 pm
Aborted
real	2m37.916s
user	1m0.165s
sys	0m2.398s
The JavaScript timings look promising. I wonder what needs to be done so that code runs on the Raspberry Pi. The incompatibility reminds me of Basic.
Speaking of Basic, I've almost finished optimizing my classic-line numbered program. The first version took less than an hour to write and verify with a short test dictionary. Unfortunately, the insane O(n^2) algorithm has been processing the British dictionary for the last two days. The digital apocalypse (if not severe global warming) will surely be upon us before it finishes.
While further optimization involving a heap has resulted in an O(n log n) algorithm, it appears the strings have caused the garbage collector to go on strike for disability compensation due to a work-related stutter. Details forthcoming may shed light on whether the same Basic which started the golden age of personal computing was also responsible for its collapse.
With that in mind, it is notable that Raspbian was made possible by Linux. Linux would not exist had there not been Unix, and Unix would not have been successful if not for the efficient portability of C. In this way, one can see that the second age of personal computing initiated by the Raspberry Pi would not have been possible without C.
As with Basic and the golden age this naturally brings up the question, will the C programming language itself ultimately lead to the collapse of the second age of personal computing and an ensuing digital apocalypse?
Mon Jul 22, 2019 5:13 pm
scruss,
...FATAL ERROR...
Ouch! What happened there?
Time to dig out a Pi. Give me two ticks...
jalih
Mon Jul 22, 2019 6:15 pm
Here is a 8th version of the anagram challenge program using heap to sort keys:
m:new var, anamap
a:new var, anakeys
' n:cmp h:new constant strheap
: s:sort \ s -- s
  s:len >r
  strheap  swap ' h:push s:each!
  "" swap
    h:pop
    rot swap s:+ swap
  ) r> times drop ;
: process-words \ word --
  /^[a-z]+$/ r:match if
    r:str nip dup >r
    s:sort
    anamap @
    over
    m:exists? if
      over m:@ r> a:push 2drop
    else
      swap a:new r> a:push m:!
    then
  then drop ;
: read-and-check-words  \ fname --
  f:slurp ' process-words s:eachline ;
: len>=  \ key --
  anakeys @ swap a:push drop ;
: fetch-ana-list \ key array --
  a:len 2 n:cmp
  1 n:+
  nip
  [ ' drop , ' len>= , ' len>= ]
  swap
  caseof ;
: key-val-cmp          \ key1 key2
  anamap @ swap m:@    \ key1 anamap key2val
  0 a:@ nip            \ key1 anamap val2
  swap rot             \ val2 anamap key1
  m:@ nip              \ val2 key1val
  0 a:@ nip            \ val2 val1
  swap                 \ val1 val2
  s:cmp ;
: sort-keys-by-first-word
  anakeys @ ' key-val-cmp a:sort drop ;
: list-words \ value --
  " " a:join . cr ;
: app:main
  0 args "/usr/share/dict/british-english-insane" ?:
  anamap @ ' fetch-ana-list m:each drop
  anamap @ anakeys @ m:@@ nip ' list-words a:each! drop
  anakeys @ a:len nip "\nAnagrams: %d\n" s:strfmt .
  bye ;
