John_Spikowski
Re: Liberation through Computer Literacy
Wed Nov 13, 2019 2:29 am
If you're running ScriptBasic with scriba only, here is how to use an extension module without having to create a config file and set an environmental variable.
1, Download/unzip the attach ta.so extension module to where you like.
2. Modify the the posted tatamix.sb script to use a full path and attribute in the LIB string.
3. time ./scriba tatamix.sb 200
DECLARE SUB do_v    ALIAS "do_v"    LIB "/home/pi/sbrt/examples/ta.so"
DECLARE SUB find_s  ALIAS "find_s"  LIB "/home/pi/sbrt/examples/ta.so"
My ta.so is in the examples directory where tatamix.sb resides.
scriba.zip
(150.42 KiB) Downloaded 21 times
ta.so.zip
(1.89 KiB) Downloaded 20 times
gkreidl
Wed Nov 13, 2019 9:43 am
Some people have been asking for a Python implementation of the Tatami challenge. I wasn't really interested for a number of reasons but finally got caught nevertheless. But I wanted a version that is more versatile (being able to find solutions for larger values of s) and while working on it I found an optimization which should be applicable to most other implementations as well.
Both versions I provide (tatami.py and tatami_opt.py) may take up to two arguments: s and nMax. So it's possible to play arround with different values. The current algorithm will break with nMax >= 147026880, because the stored values may be bigger than 255. So the program uses bytearrays, Python list or arrays from the array module (as a last resort, because it is the slowest), depending on the size of nMax, maximum size of Python lists and memory usage. Here is the standard version (tatami.py):
#!/usr/bin/python3
import sys
from math import sqrt
def tatami(s):
    for i in range(7,nMaxSqrt,2):
        k2 = i + 3
        k3 = i + i - 4
        while ((k2 <= k3) and ((i * k2) < nMax)):
            k4 = (nMax-1) // i
            if k3 < k4:
                k4 = k3
            for j in range(k2,k4+1,2):
                v[i*j] += 1
            k2 += i+1
            k3 += i-1
    for i in range(8,nMaxSqrt,2):
        k2 = i + 3
        k3 = i + i - 4
            k4 = (nMax-1) // i
            if k3 < k4:
                k4 = k3
            for j in range(k2,k4+1):
                v[i*j] += 1
            k2 += i + 1
            k3 += i - 1
    try:
        return v.index(s)
    except:
        return -1
s = 200
nMax = 100000000
if len(sys.argv) > 1:
    try:
        s = int(sys.argv[1])
    except:
        pass
if len(sys.argv) > 2:
    try:
        nMax = int(sys.argv[2])
    except:
        pass
if (nMax & 1) != 0:
    nMax += -1
if nMax > 536870912 and sys.maxsize == 2147483647:
    try:
        from array import array
        v = array('I',[0])*nMax
    except:
        print("Not enough memory!")
        sys.exit(0)
elif nMax >= 147026880:
    try:
        v = [0]*nMax
    except:
        try:
        except:
            sys.exit(0)
else:
    v = bytearray(nMax)
nMaxSqrt = int(sqrt(nMax))
res = tatami(s)
if res > -1:
    print("The smallest room size s for which T(s) = "+str(s)+" is "+str(res))
else:
    print("No solution found for s=" +str(s)+" and nMax="+str(nMax))
    maxs = 0
    maxi = 0
    for i in range(0,nMax):
        if v[i] > maxs:
            maxs = v[i]
            maxi = i
    print("Maximal T(s) found = "+str(maxs)+" for room size = "+str(maxi))
Of course it will run much slower than a C version.:
time ./tatami.py
The smallest room size s for which T(s) = 200 is 85765680
real	1m29,730s
user	1m29,230s
sys	0m0,240s
But it will give a nice performance time when run from pypy3:
time pypy3 ./tatami.py
real	0m16,484s
user	0m16,034s
sys	0m0,430s
The optimization takes into account, that only even room sizes are allowed. Half of the size of the v-Array is never used. So it's possible to reduce the dimension of the v-array to nMax/2. It needs an additional shift by one to the right within the tatami function: v[(i*j) >> 1] += 1. The result has to be multiplied by 2 in the end. The overhead should be small and the search time for the result will be reduced. Here's the code of the optimized Python version (tatami_opt.py):
#!/usr/bin/python3
import sys
def tatami(s):
        k2 = i + 3
        k3 = i + i - 4
            k4 = (nMax-1) // i
            if k3 < k4:
                k4 = k3
                v[(i*j) >> 1] += 1
            k2 += i+1
            k3 += i-1
        k2 = i + 3
        k3 = i + i - 4
            k4 = (nMax-1) // i
            if k3 < k4:
                k4 = k3
                v[(i*j) >> 1] += 1
            k2 += i + 1
            k3 += i - 1
    try:
        return v.index(s)
    except:
        return -1
s = 200
nMax = 100000000
    try:
    except:
        pass
    try:
    except:
        pass
if (nMax & 1) != 0:
    nMax += -1
if nMax > 536870912*2 and sys.maxsize == 2147483647:
    try:
        v = array('I',[0])*(nMax//2)
    except:
        sys.exit(0)
    try:
        v = [0]*(nMax//2)
    except:
        try:
        except:
            sys.exit(0)
else:
    v = bytearray(nMax//2)
res = tatami(s)*2
if res > -1:
else:
    maxs = 0
    maxi = 0
    for i in range(0,nMax//2):
        if v[i] > maxs:
            maxs = v[i]
            maxi = i*2
It runs a bit slower in interpreter mode, but even faster with pypy3:
time ./tatami_opt.py
real	1m39,995s
user	1m39,781s
sys	0m0,140s
time pypy3 ./tatami_opt.py
real	0m15,124s
user	0m14,871s
sys	0m0,210s
Now let us search for a solution for T(s) = 300:
time pypy3 ./tatami_opt.py 300 300000000
The smallest room size s for which T(s) = 300 is 294053760
real	0m49,615s
user	0m48,143s
sys	0m1,400s
All timings are from a RPi 4B/4G
Minimal Kiosk Browser (kweb)
ejolson
Wed Nov 13, 2019 2:56 pm
Storing T(s) only for even values of s is a nice optimisation. In addition to being easier on the cache it takes less memory.
I was talking with the lead developer of FidoBasic about how to present the results of the challenge. The canine coder suggested that everyone should receive stars for any correctly working code submitted. When asked what kind of stars, the developer clicked and found
Wikipedia wrote:Sirius is known colloquially as the "Dog Star", reflecting its prominence in its constellation, Canis Major (the Greater Dog)
Then Fido became barking mad. What? growled the canine coder. That's an egregious error. Sirius is the colloquial; Dog Star is the proper scientific name.
I reflected and then remarked, I not sure we need stars. Didn't someone offer to provide free tatami mats to everyone entering the challenge? However, Fido was busy editing Wikipedia and did not respond. It's amazing how liberating it is to know how to use a computer.
John_Spikowski
Wed Nov 13, 2019 5:15 pm
This sounds like a precursor to threads.
Can X and Y be done In separate threads?
Tatami is rectangles not squares.
scriba tatamixy.sb 200 100
John_Spikowski
Thu Nov 14, 2019 1:08 am
My vote for the next iteration of the Tatami challenge is to pass both X and Y dimensions and not assume the room is square.
Paeryn
Thu Nov 14, 2019 1:41 am
It doesn't assume the room is square, the calculations are on the area of the room, T(s) being the number of rooms with an area of s where the width is not greater than than the height that can't be covered completely. The width <= height prevents counting duplicate identical rooms (e.g. a room of 7x10 is just a rotated copy of 10x7).
Please note that my name doesn't start with the @ character so can people please stop writing it as if it does!
John_Spikowski
Thu Nov 14, 2019 3:04 am
A slight improvement for ScriptBasic. Only the extension module code was changed.
No one has download the scriba or ta.so zips. Was that another waste of my time?
Haven't heard much from Heater. Is he still mapping the universe or him barfing on his keyboard take him offline?
/* Tatami Array Get / Set / Add
UXLIBS: -lm
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "../../basext.h"
#include "cbasic.h"
DIM AS unsigned char v[50000000];
 Extension Module Functions
besVERSION_NEGOTIATE
  RETURN_FUNCTION((int)INTERFACE_VERSION);
besEND
besSUB_START
  DIM AS long PTR p;
  besMODULEPOINTER = besALLOC(sizeof(long));
  IF (besMODULEPOINTER EQ NULL) THEN_DO RETURN_FUNCTION(0);
  p = (long PTR)besMODULEPOINTER;
  RETURN_FUNCTION(0);
besEND
besSUB_FINISH
  DIM AS long PTR p;
  IF (p EQ NULL) THEN_DO RETURN_FUNCTION(0);
  RETURN_FUNCTION(0);
besEND
 Tatami array functions
besFUNCTION(do_v)
  DIM AS long start;
  DIM AS long end;
  DIM AS long value;
  DIM AS long idx;
  besARGUMENTS("iii")
    AT start, AT end, AT value
  besARGEND
  DEF_FOR (idx = start TO idx <= end STEP INCR idx + 2)
  BEGIN_FOR
    v[(value * idx) / 2] += 1;
  NEXT
  besRETURNVALUE = NULL;
besEND
besFUNCTION(find_s)
  DIM AS long s;
  DIM AS long idx;
  besARGUMENTS("i")
    AT s
  besARGEND
  DEF_FOR (idx = 0 TO idx <= 49999999 STEP INCR idx)
  BEGIN_FOR
    IF (v[idx] == s) THEN
      besRETURN_LONG(idx + idx);
         EXIT_FOR
    END_IF
  NEXT
besEND
Output (Laptop)
ubuntu@ubuntu:~/sbrt/examples$ time scriba tatamix.sb 200
real	0m4.859s
user	0m4.815s
sys	0m0.044s
Output (RPI 4B 4GB)
pi@RPi4B:~/sbrt/examples $ time scriba tatamix.sb 200
real	0m23.399s
user	0m23.267s
sys	0m0.121s
ta.so.zip
(1.9 KiB) Downloaded 33 times
John_Spikowski
Thu Nov 14, 2019 5:12 am
Tatami Python 200 (optimized)
Output (Laptop)
ubuntu@ubuntu:~/sbrt/examples$ time ./tatami.py 200
real	0m39.373s
user	0m39.358s
sys	0m0.012s
Output (RPi 4B 4GB)
pi@RPi4B:~/sbrt/examples $ time ./tatami.py 200
real	1m45.614s
user	1m45.450s
sys	0m0.131s
Last edited by John_Spikowski on Thu Nov 14, 2019 5:40 am, edited 2 times in total.
John_Spikowski
Thu Nov 14, 2019 5:36 am
Tatami C (optimized)
Output (Laptop)
ubuntu@ubuntu:~/sbrt/examples$ time ./tatami 200
T(85765680) = 200
real	0m3.312s
user	0m3.258s
sys	0m0.053s
Output (RPi 4B 4GB)[/b]
pi@RPi4B:~/sbrt/examples $ time ./tatami 200
T(85765680) = 200
real	0m10.417s
user	0m10.025s
sys	0m0.392s
Thu Nov 14, 2019 5:58 am
John_Spikowski,
Still here, following along intently.
Strangely enough mapping is exactly what I have been doing. Only a small corner of the universe mind.
Was hoping to make a Rust version of one of the recent optimized C tatami codes. That might have to wait till the week end.
John_Spikowski
Thu Nov 14, 2019 6:18 am
Thanks for the update. A Rust version would be nice.
John_Spikowski
Thu Nov 14, 2019 6:40 am
It might be possible to run the two FOR/NEXT routines that update the V arrary as threads updating their own instance of V and returning the arrays as strings.
The final FOR/NEXT that searches for S could take the two thread array return strings as arguments and combine them before finding the S index.
Wouldn't searching backward from UBOUND towards zero be faster?
John_Spikowski
Thu Nov 14, 2019 7:06 am
Removed invalid code.
Last edited by John_Spikowski on Thu Nov 14, 2019 4:01 pm, edited 1 time in total.
John_Spikowski
Thu Nov 14, 2019 7:55 am
Show us the code!
ejolson
Thu Nov 14, 2019 9:57 am
Doing the reverse search shaved off a bit more time.
Searching from large values of s until T(s)=n does not necessarily find the least s that does the same. The fact that the same value for s is returned when n=200 is coincidence, so this approach does not count as working code. To further see this try solving T(s)=1 without changing smax and note that the correct answer of s=70 is not returned.
John_Spikowski
Thu Nov 14, 2019 3:55 pm
I'm going to take a shot at doing this in ScriptBasic as a string for V. It won't be as fast a the extension module version but should be able to do 200 native.
John_Spikowski
Thu Nov 14, 2019 5:24 pm
Tatami threaded
Thanks!
The pthread_join() function waits for the thread specified by thread to terminate. If that thread has already terminated, then pthread_join() returns immediately. The thread specified by thread must be joinable. If retval is not NULL, then pthread_join() copies the exit status of the target thread (i.e., the value that the target thread supplied to pthread_exit(3)) into the location pointed to by retval. If the target thread was canceled, then PTHREAD_CANCELED is placed in the location pointed to by retval. If multiple threads simultaneously try to join with the same thread, the results are undefined. If the thread calling pthread_join() is canceled, then the target thread will remain joinable (i.e., it will not be detached).
ejolson
Thu Nov 14, 2019 5:41 pm
jalih wrote:
Tue Nov 12, 2019 9:30 pm
Here are updated Tatami codes for PL/1, Fortran and 8th. I use ancient PL/1 compiler for Windows but it still produces the fastest code of the bunch. PL/1 code takes about 3 seconds to run, Fortran code doubles that time and runs in about 6.5 seconds.
I suspect the Fortran code would gain performance by using a one or two-byte integer data type for the v array. A similar optimisation could be done with my Visual Basic code.
It is likely the speed of the simple but memory intensive tatami.c algorithm is constrained by memory bandwidth. This makes it more of a memory benchmark than a test of processor speed. On the other hand, limited.c may depend more on processor speed and less on memory.
As searchs for plotting packages which create stars with tatami tilings as the background are coming up short, it looks like a new programming challenge may be in the making: Write a custom plotting program. I did, however, find
Could Minecraft be used to present the results of the tatami challenge?
jalih
Thu Nov 14, 2019 7:16 pm
Fortran integer types are signed, 8-bit and 16 bit integers are nonstandard and might not be supported by all compilers. Some compilers also accepts unsigned integer types as an extension. I tested using (kind=2) 16 bit signed integer but it did not make any difference in program run time and my ide warned about possible loss of precision.
jalih
Thu Nov 14, 2019 7:51 pm
Here is a two threaded version of tatami for 8th:
100000000 constant N-MAX
N-MAX n:sqrt n:int constant N-MAX-SQRT
N-MAX b:new true b:writable constant v
: swap+-  \ a b c f -- a (a+b+1) (a+c-1)
  drop
  swap 2 pick n:+ n:1+
  swap 2 pick n:+ n:1- ;
: l4  \ i k2 k3 k4 -- i k2 k3 k4
  \ i k2 k3 k4 j
  4 pick over n:*
  v over b:@ n:1+ rot swap b:! 2drop ;
: l3
  \ i
  dup 3 n:+             \ i k2=i+3
  over dup n:+ 4 n:-    \ i k2 k3=i+i-4
  repeat  \ i k2 k3
    2dup n:> not 2over n:* N-MAX n:< and if
      N-MAX n:1- 3 pick n:/ n:int     \  i k2 k3 k4
      2dup n:< if
        drop dup
      then
      ' l4 3 pick 2 pick loop   \ i k2 k3 k4
      swap+-
    else
      break
    then
  again
  2drop drop
  2 step ;
: l2  \ i k2 k3 k4 -- i k2 k3 k4
  \ i k2 k3 k4 j
  4 pick over n:*
  2 step ;
: l1
  \ i
  repeat  \ i k2 k3
      2dup n:< if
        drop dup
      then
      ' l2 3 pick 2 pick loop   \ i k2 k3 k4
      swap+-
    else
      break
    then
  again
  2drop drop
  2 step ;
: tatami  \ n -- s
  a:new
  ( ' l1 7 N-MAX-SQRT n:1- loop ) t:task a:push
  ( ' l3 8 N-MAX-SQRT n:1- loop ) t:task a:push
  t:wait
  v swap 1 a:close b:new b:search nip ;
: app:main
  200 tatami null? not if
    "The smallest room size s for which T(s) = 200 is %d.\n" s:strfmt .
  else
    drop "Not found\n" .
  then
  bye ;
John_Spikowski
Fri Nov 15, 2019 12:07 am
I use my laptop for development. My phone is used for everything else.
Last edited by John_Spikowski on Fri Nov 15, 2019 1:33 am, edited 1 time in total.
John_Spikowski
Fri Nov 15, 2019 1:21 am
Farm Sim may be a better choice. It has an object IDE and BASIC like scripting engine.
John_Spikowski
Fri Nov 15, 2019 2:50 am
The V as a STRING idea didn't work out. There isn't an efficient way to replace a character within the string.
John_Spikowski
Fri Nov 15, 2019 3:49 am
@jcyr,
It looks like you are using one instance of the V[] array for both threads, Is there no collisions due to each thread updates separate (odd / even) elements?
Can this be done in C rather than C++?
Is it possible to do multiple areas and combined them?
